Torque settings for after-market aluminum alloy wheels
Discussion in 'Wheels & Tires' started by Cthulhu, Nov 25, 2022.
  1. Nov 25, 2022 at 11:00 AM
    Cthulhu
    Cthulhu [OP] The White and Black Goat of the Woods
    Hello all. I’ve spent about an hour searching (don’t want to be that guy :thumbsup:), and can’t find it on Icon’s site, nor general consensus on the interweb. I have the Vector 5’s on my 2018, but I always like to check torque settings after the dealer rotates them. I’m assuming, since these are aluminum alloy wheels, torque should be same as factory at 97 ftlbs, correct? I asked the guys at 4WP, and they said 125 ftlbs, but that would indicate to me a steel wheel torque. Thanks in advance for any help!
  2. Nov 25, 2022 at 1:00 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Ive always seen 97lbs for Toyota Tundras with aluminum wheels, 154 for the steel
    snivilous and Cthulhu[OP] like this.
  3. Nov 25, 2022 at 2:27 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Mine are right about 100 from my local shop.
    I recheck them with my Huskey Torque wrench set to 100.
    Black Rhino Aluminum.
    Cthulhu[OP] likes this.
  4. Nov 25, 2022 at 2:34 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    My Fuel Shoks are torqued to 100 ft-lbs.
  5. Nov 25, 2022 at 2:52 PM
    Cthulhu
    Thanks so much!! 97/100 sounds about right to me too. Preesh gents!
  6. Nov 28, 2022 at 6:27 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    I’d just stick with 97, best bet then to over torque and then brake a lug. Now you have an even bigger problem.
    Cthulhu[QUOTED][OP] likes this.
