  1. Nov 22, 2022 at 8:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thanks for asking because I was going to! Lol
  2. Nov 22, 2022 at 8:55 PM
    I guess it sets up automatically and has a nice color display. Not the same form factor though.
  3. Nov 22, 2022 at 8:58 PM
    daveeasa
    SG3 is nice but there is something very cool about the SG2 which is hard to put into words.
  4. Nov 22, 2022 at 9:06 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    It feels more "utilitarian" or "military" or "industrial" based on pics. Smaller too.
    daveeasa[QUOTED] likes this.
  5. Nov 22, 2022 at 9:12 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Alright. Just let me know! I'll probably forget by then!
    Keyword: ROTH
  6. Nov 23, 2022 at 2:44 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I tell you hwat. These dang nab ole LED bolbs is getting 'spensive. I tell you hwat.
    Y'all better hurry, Macy's gonna up the price again after 1h 18m. :D
    Leo's first likes this.
  7. Nov 23, 2022 at 3:25 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Vvti has got to be jiggleing the cam by 3600rpm. Because it raises the peak torque from 3400-3600 rpm. Do the plastic intakes have the acoustic control induction system? With a valve to change from short to long intake runners? I still havent seen anything about 10:1 pistons for 05-06, just for '07+.
    5N0W808 likes this.
  8. Nov 23, 2022 at 4:06 AM
    Mine was 6200. But that was in a corolla xrs. I think in the celica gts it was 6000, or maybe a tad lower. It pissed me off because every time you'd shift you'd be back on the small cam.
    Vvtl-i is 'Variable Valve Timing with Lift - intelligence". With vvtl-i, if im thinking about it right, instead of 1 cam lobe you have a 2nd, higher profile lobe as well. Once you hit the required rpm it switches over to the higher profile cam lobe and completely changes the cam profile, adding more lift and overlap. It also changes the timing.
    My SHOs have something similar, but the intake geometry itself changes, hence the giant intake. When you hit 4k rpm, a little butterfly actuates switching from long runners to short runners. That's why the sound changed so much when getting on it. If it ran perfectly, you can feel it too.
    Here's a dyno of a 2zz-ge, a vvtl-i motor. You can see when the change happens.
    On the SHO, if you look at this closely, you can see how a long runner from the back feeds the front cylinders, but a short runner from the from feed the same cylinders. Hence the 2 intake ports on the head.20181102_203303.jpg
  9. Nov 23, 2022 at 3:22 PM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    bmf4069, NUDRAT[OP], txagg and 4 others like this.
  10. Nov 23, 2022 at 3:40 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Anyone seen anybody with these, or have experienced with these "smart" rearview dash cams?
    I know @NUDRAT steered me towards this suggestion.
    Limited-time deal: WOLFBOX G850 4K Mirror Dash Cam: 12'' Rear View Mirror Camera for Car,Dual Dash Cameras Front and Rear,Super Night Vision,Parking Monitoring,Reversing Assistance,32GB TF Card & GPS https://www.amazon.com/dp/B0B1LLMCS9
    NUDRAT[OP] likes this.
  11. Nov 23, 2022 at 5:32 PM
    I don't bother with nearly any of the products sold exclusively or mostly on scAmazon when the manufacturer name has all-caps, sounds like a gibberish word, and/or the manufacturer doesn't have a website (Wolfbox apparently does, but still...)
    Reviews I was able to quickly find online puts their products around a 4 out of 5. Maybe it's worthwhile. Maybe it's not. I went with Garmin after spending way too long trying to figure out what I needed and it's worked dandy, I don't even see it tucked behind my rear view, and when I've needed to pull video using the app, I did, no prob.
    What I'd stress on you is this: Something is better than nothing when it comes to dashcams. What I'd warn you is: Don't get stuck in "analysis paralysis"! This is what a huge swath of normal people end up doing. Granted, I know you have and/or had a dashcam already. but ...
    Garmin does have a front/rear system. But it's probably significantly more spendy than the Wolfbox stuff.
  12. Nov 23, 2022 at 5:51 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Not the one I have but I've been more than happy with the Autovox backup cam on my truck.
    AUTO-VOX X1 Dash Cam Backup Camera
    https://www.amazon.com/dp/B09TZMZV1B
    NUDRAT[OP] and shifty` like this.
  13. Nov 23, 2022 at 6:46 PM
    NUDRAT
    NUDRAT [OP] 6 lug life
    SW CT
    Between 'Ridgelines'
    "Tactical"?
  14. Nov 23, 2022 at 7:45 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I would own a scan gauge 2 sized unit with a lcd. The 3 is too big in my opinion
  15. Nov 23, 2022 at 7:50 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I specifically chose not to use the word tactical lol
    NUDRAT[QUOTED][OP] likes this.
  16. Nov 23, 2022 at 8:49 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    hey buddy, your left brake light is out.... caps are cool tho
    Sunnier and des2mtn[QUOTED] like this.
  17. Nov 23, 2022 at 8:53 PM
    des2mtn
    SW
    Tonto cover
    Hah! Thanks. Hopefully fixing that this weekend :)
    RUSTYNUTS[QUOTED] likes this.
  18. Nov 23, 2022 at 9:15 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    doubtful. Before I had my F150 towed from my house, I pulled the shell and set it on my AC Tundra. The width would've worked but it was 3-4" too long. The F150 was an '07 but likely the same bedsize as an 97-03. Not 100% on that tho
    FirstGenVol and des2mtn like this.
  19. Nov 23, 2022 at 9:17 PM
    des2mtn
    SW
    Tonto cover
    498 × 372
    FirstGenVol and 5N0W808[QUOTED] like this.
  20. Nov 23, 2022 at 9:22 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    97-03 is 77.5" inside
    06-08 is 77.75" inside
    1/4" difference
    5N0W808[QUOTED] likes this.
  21. Nov 23, 2022 at 9:23 PM
    des2mtn
    SW
    Tonto cover
    Glad you realized hard toppers are superior. After 12 years, mine is starting to form a small crack. Leer has a lifetime warranty but my Pops couldn't find the receipt from install. I'm still going to reach out to Leer about it, but I still have plenty of years out of it.
  22. Nov 23, 2022 at 9:24 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
  23. Nov 23, 2022 at 9:27 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    NUDRAT[OP] and FrenchToasty like this.
  24. Nov 23, 2022 at 9:30 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    i see em on the fb group all the time. Rarely for less than $500
  25. Nov 23, 2022 at 9:31 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Well there ya go. I guess since you don't use your truck for real 'truck stuff', the loss of a tailgate wouldn't matter, right?:boink::rofl:
    CodyP and 5N0W808[QUOTED] like this.
  26. Nov 23, 2022 at 9:36 PM
    des2mtn
    SW
    Tonto cover
    Hah, I'm mostly teasing anyways, don't worry. If I had nothing else and found a good deal on a soft topper, you bet I'd jump on it.
    Even though my cap is starting to crack in one corner and I'm not the happiest about it, I feel like I've gotten so much use out of it and "my moneys' worth".
    RUSTYNUTS and 5N0W808[QUOTED] like this.
  27. Nov 23, 2022 at 9:52 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    no, i think the last one was VA. Couldnt find it, must've sold.
  28. Nov 23, 2022 at 9:54 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I want a high roof topper like isammi. Hopefully close to 40" tall so i could fit the buell in it.
    spacekaps are cool, too.
    bmf4069 and FrenchToasty like this.
  29. Nov 23, 2022 at 10:12 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Blue ridge parkway is a great drive.
    NUDRAT[OP], shifty` and FirstGenVol like this.
  30. Nov 23, 2022 at 10:19 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
