Rattle can paint job help.
Discussion in 'Off-Topic Discussion' started by Scuba, Oct 28, 2019.
  1. Nov 10, 2019 at 7:19 AM
    #61
    Scuba
    Scuba [OP] Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Woke up early this morning so I decided to start mounting the doors.
  2. Nov 10, 2019 at 7:24 AM
    #62
    18" TRD Off Road Wheels
    Nice! Looking good, Scuba.
    Mountun Goat likes this.
  3. Nov 10, 2019 at 12:06 PM
    #63
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Strong work man!
  4. Nov 10, 2019 at 7:51 PM
    #64
    Scuba
    Austin, Tx.
    Thank you everyone. I really appreciate the help.
    I'll consider this thread done for now and will update once I get the fenders.
    A couple take aways:
    Don't paint in direct sunlight. I believe this was my biggest mistake on the hood and it's what caused me to have a very uneven first coat. I got the best results painting the roof of the truck and it was literally right under the florescent light in the garage. I got a nice even glossy coat on the roof without any clear coat.
    Hanging your piece vertical is not always best but may work for you. I got runs on the hood when I painted it when it was hanging.
    I don't know why Rustoleum said they don't recommend clear coat on top of this paint. I used 2K clear on the doors and half of the hood. I sprayed it on shortly after the spraying the final top coat. I got good results from what I can see. It needs some wet sanding and buffing to even it out but otherwise it's fine.
    Test your cans. Test the spray pattern before doing anything. I painted the doors last and by that time I had enough practice to get good results. This helped me figure out the correct distance needed to hold off from the piece. Too close and you'll get runs.. too far you won't get a wet enough coat. Even with my shaky hands once I finally got to the doors I had a better feel for how far away I needed to hold the cans and how quickly I needed to move. I learned that I had to look at the area in front of and behind where I was spraying (and not focusing on just the spot the paint was hitting). That kept me on the right path.
    Move your body and not your hand/ arms. This will help keep the spray can at the same distance the entire time.
  5. Nov 10, 2019 at 8:00 PM
    #65
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I ran into issues with goobers dripping from the can when trying to paint things laying flat, so that's one advantage that I could see to painting the pieces vertically or hanging. As far as the 2k over Rust-Oleum/other enamels, I read that it's fine to do but you should give plenty of time for the base coat to off-gas fully... I don't know if that's going to cause any issues or if it's just a precautionary thing. Looks great though, and it's been a good thread to follow.
  6. Nov 10, 2019 at 8:03 PM
    #66
    Good tips. Thanks for sharing what you've learned.
  7. Nov 10, 2019 at 8:40 PM
    #67
    Scuba
    Austin, Tx.
    Yeah I got a couple of those on the doors. I think that was an issue with the can/ nozzle thought. But you have a very valid point. I think ideally it would have been nice to have the pieces sitting at about a 45* angle to the floor. Then the paint can wouldn’t have to be completely parallel with the ground.
    Hmm. Well only time will tell.
    :eek:
    Thanks for following and supporting. :thumbsup:
    GODZILLA[QUOTED] likes this.
  8. Dec 28, 2019 at 1:51 PM
    #68
    Scuba
    Austin, Tx.
    Fenders are finally done. Truck is put back together and ready to wheel.
    I skipped the clear coat on the fenders. I was able to get a nice even glossy finish with the paint alone so I was happy.
    Overall the paint makes the truck a 10 footer, in my opinion. Very happy with everything.
    Thank you again everyone for your help!
    GODZILLA, Medic343, AZTundra and 3 others like this.
  9. Dec 28, 2019 at 2:17 PM
    #69
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Missing something. Ah-ha! Needs some JD yellow wheels! :D
    Looks awesome. :thumbsup:
  10. Dec 28, 2019 at 2:42 PM
    #70
    Twinky
    Twinky Keep the shinny side up!
    Kemah, Texas chillin on my ChrisCraft 480
    07 double cab work horse
    Stereo upgrades: -HU, Pioneer Mvh bs501 -Tweeters, Peerless(vifa) XT25SC90-04 1" Dual Ring Radiator s in custom pods. -Mids, Silver Flute W17RC38-04 6.5" Wool Cone Woofer. -Subwoofer, American Bass XR12. 2.3^3ft tuned @33-34 hz. -Tw Amp, Old School 2ch Sony. -Mids Amp, Old School Autotek Sx275. -Sub Amp, Old School Memphis 16-pr1.1000 -Zero gauge big 3. 0 and 4 gauge copper runs to amps.
    Hell F'ing yeah, man!
    Seriously, you did a great job.
  11. Dec 28, 2019 at 2:46 PM
    #71
    Personally, I would sign the body panels like a famous painter would. That would get hours of enjoyment.
    Turned out really good. Can’t wait to see the hulk hit the trails.
  12. Dec 28, 2019 at 2:50 PM
    #72
    I was out with the Toyota’s last weekend.
    GODZILLA likes this.
  13. Dec 28, 2019 at 5:37 PM
    #73
    Scuba
    Austin, Tx.
    Hmm that’s an interesting thought.
    My friend is making me vinyl decals to replace the door emblems in yellow.
    It’ll say “TOYOTA_Tacoma” and 4 Wheel Drive right under it on each of the doors. Truck has been renamed John from Billy.
    Thank you!
    Of course the Jeep guy would post pictures of his Jeep winching Toyota’s. :rolleyes::p
    GODZILLA and ColoradoTJ[QUOTED] like this.
  14. Dec 28, 2019 at 5:39 PM
    #74
    Actually, I was just pulling him over to change tires. He lost 3 beads that day. Wheeled just fine.
    NewImprovedRon likes this.
  15. Dec 28, 2019 at 5:54 PM
    #75
    Scuba
    Austin, Tx.
    Dang. I would hate to be that guy.
  16. Dec 28, 2019 at 6:18 PM
    #76
    No jack, no air, no white claw. He was screwed three ways to Wednesday
    TRDFerguson likes this.
  17. Dec 28, 2019 at 7:45 PM
    #77
    Scuba
    Austin, Tx.
    I’ve been on runs and seen similar issues. Reminds me to always go prepared.
    And I’ve also been “that guy” once or twice. When this truck was still IFS I broke both front CV axles on Clawhammer right after the plaque. Then I busted a bead while getting pulled out. It was already a long night and that made it worse. We didn’t get back to the lakebed until the sun started coming back.
  18. Dec 28, 2019 at 7:54 PM
    #78
    That reminds me to go get my CO2 Tank filled on Monday....and DEF fluid.
  19. Nov 22, 2022 at 9:36 PM
    #79
    rickyrockrat
    rickyrockrat Project Overload
    2018 Tundra Plat/78Corona/FJ62/three FJ60s
    Tundra is stock 78 Corona 20R decked head and bored out a few thou. 84 FJ60 is stock 85 FJ60 is stock, with Saginaw conversion. 85 FJ60 in progress, SOA, ARB locker back, Aussie locker front, rear stear. 88 FJ62, stock, but with a sick ECU. Soon to be Speeduinoed.
    How is that Krylon paint holding up? We painted some dog agility equipment with both Rustolem and Krylon, and there are two things I noticed.
    1) The Krylon went on much thinner than the Rustolem.
    2) The Krylon is almost completely faded after 2 years and the Rustolem is still the same bright colors as when we painted.
    I wonder since you coated it if it did any good. Sad my first post on this forum was about that. I bought my first Tundra this month. I just wish it had a stick!
    I came across this because the PO tore one of the back plastic bumper covers and I'm looking to order one from Toyota, but they just told me I have to paint the darn thing. I'm sure the dealer would do it for lots of $$.
  20. Nov 22, 2022 at 10:21 PM
    #80
    I somehow missed this update... for a couple years! that thing looks awesome! Do you have more pics of adventures with it?
