Brand new Tundra with major paint bubbles under clear coat
Discussion in '3rd Gen Tundras (2022+)' started by waves, Nov 22, 2022.
  1. Nov 22, 2022 at 11:27 AM
    waves
    waves [OP] New Member
    Got the truck on Saturday. It was dirty for the test drive and after 4 hours waiting to sign the papers we were really hungry, went to dinner and then it got dark. Next morning I got to the truck and noticed issues on the paint. Got closer and it seems that there's air bubbles under the clear coat on the hood and front right fender. Drove to the dealer right away and since service dept was closed, they said to come back on Monday to open a case. To make matters worse, I'm 3h away from the dealer and in a different state. Was there anyone in the same situation and if yes, what was the outcome?
  2. Nov 22, 2022 at 11:32 AM
    Taco-Spike
    Two Trucks
    You sure it's not the protective film?
    Aerindel, Donas, GODZILLA and 2 others like this.
  3. Nov 22, 2022 at 11:35 AM
    waves
    I'm not sure of anything. Do they come with a clear film on them? I know most manufacturers ship them with a white film.
    Toyokuhl likes this.
  4. Nov 22, 2022 at 11:35 AM
    4genRunner
    4genRunner New Member
    Southwestern MO
    2022 SR5 CrewMax TRD OR 4x4 CSM
    RB20's, Extang Xceed Cover, Tint.
    My thoughts exactly. Looks more like remnants of the adhesive on the protective film that's on the trucks for shipment.
    Kap1, catalac, Tundra ATL and 3 others like this.
  5. Nov 22, 2022 at 11:43 AM
    Bammer
    Monroe, CT
    How does a dealer clear that for delivery to the customer?
  6. Nov 22, 2022 at 11:43 AM
    DFS
    DFS New Member
    2022 Capstone Tundra
    My Capstone was delivered with very similar marks on the hood, the detail team did a horrendous job and no one knew how to deliver the truck because it was the first one. First time I washed the truck I found a plethora of adhesive from the shipping film and went back to the dealer, they still failed to do a good job so I got the truck professionally detailed and sent the bill to the dealer. The adhesive was all gone, and the dealer was understanding. Hopefully you have a similar result.
    Henry1jg, BTBAKER, Tundra ATL and 2 others like this.
  7. Nov 22, 2022 at 11:45 AM
    waves
    They look like bubbles under a clear film or clear coat, similar to what you get when applying a film over a smart phone's screen, but can't see or feel it at the edges. Dealer said they didn't apply clear bra except for door edges and door handles. It's not going away when rubbing with microfiber cloth and it's definitely not on the surface, it's under either a film or clear coat, surface is really smooth to the touch.
  8. Nov 22, 2022 at 11:55 AM
    DFS
    DFS New Member
    That really sucks, I'd escalate with the dealer that sold it to you as much as possible. They can probably work with your local dealer if need be, that's going to be a corporate claim anyways if it's bubbling under the clear coat.
  9. Nov 22, 2022 at 11:56 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    By the looks of your second picture, I would gamble to say it wasn’t an issue with the factory paint. It seems that the marks went from the hood to the fender in a matching pattern. Most modern vehicles are painted in parts so it would be hard to believe this was caused by paint failure. I wouldn’t rule out that something spilled or was sprayed and got on the adjoining panels.
  10. Nov 22, 2022 at 12:27 PM
    firehawk003
    firehawk003 New Member
    Are you sure yours did not have the port option of clear hood protection? It sure looks like that is what it is.
    GG.Offroad and GODZILLA like this.
  11. Nov 22, 2022 at 12:34 PM
    waves
    TOTAL INSTALLED PACKAGES & ACCESSORIES
    50 State Emissions
    FIO
    $0.00
    All-Weather Floor Liners
    Engineered to precisely fit your vehicle, all-weather floor liners are made from durable, flexible, weather-resistant
    material that cleans easily. . Precise injection molding uses Toyota's original vehicle design data for a perfect fit .
    Includes two rear liners to help provide more complete coverage . Liners feature ribbed channels to better hold
    moisture and a stylish vehicle logo . Skid-resistant backing and driver- side quarter-turn fasteners help keep the
    liners in place. Made in the U.S.A.
    PIO
    $179.00
    Blackout Emblem Overlays
    Molded from tough and durable black ABS plastic, blackout emblem overlays are engineered to precisely fit over
    existing badges, making it easy to customize in minutes. Designed to fit over existing chrome vehicle badging. Easy
    to install-simply remove tape liner and apply over clean badges. Tested against harsh UV exposure to resist fading.
    PIO
    $150.00
    Tailgate Insert Badge - Black
    Tailgate inserts emphasize the Tundra stamp in the tailgate and are an easy way to customize the look of your truck.
    Individual letters strongly adhere into the stamped tailgate logo. Attached with strong adhesive backing. Two colors
    available, bright chrome or flat black.
    PIO
    $89.00
    Total Optional Equipment $418.00
  12. Nov 22, 2022 at 12:40 PM
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    I’m currently dealing with Toyota PIO paint protection film issues on my Tundra. I took delivery in June at a dealership several hours away and have had to go through my closer dealer for repair. It has been an absolute nightmare honestly. I’ve had it at the dealer on several different occasions since July and had to eventually open up a Toyota corporate case. I finally have an appointment to have the fender films replaced on both sides of the rear and the passenger side film replaced near the headlight. I have some issues with the hood film as well (admittedly relatively minor on that section) and Toyota has denied that repair as the hair/stippling under the film is “within their spec.” Pretty annoyed about the whole thing. This was a PIO I was forced to pay for if I wanted the truck and it continues to feel like Toyota isn’t willing to do the whole repair properly.
    ryanwgregg likes this.
  13. Nov 22, 2022 at 12:44 PM
    pursuit2550
    pursuit2550 New Member
    I am going to go with protective film bubbles. Look at the edges, should be able to tell if there is one. I don’t see clear coat doing that. They are too big for paint bubbles.
    GODZILLA and aj350925 like this.
  14. Nov 22, 2022 at 1:08 PM
    waves
    I thought of protective film too but when that happens, if you press on one side of the bubbles, air moves towards the other side. Nothing changes when I try to push the air from one side to the other. Feels hard as a rock.
    And like you said, paint bubbles are small and round, not big and long, but honestly I can't figure this out. I hope it's a film cause that would be easy to remove. I won't accept to have it repainted at a body shop.
  15. Nov 22, 2022 at 1:16 PM
    pursuit2550
    It probably cured like that. I get what you mean by moving the bubble around but that when the film is fresh install. I would also want it to be a film. Would hate to have to paint a new truck.
  16. Nov 22, 2022 at 1:16 PM
    Breathing Borla
    AZ
    how the hell can either toyota factory or toyota dealer give that too a customer.
    what a shit sandwich
  17. Nov 22, 2022 at 1:17 PM
    pursuit2550
    I have noticed that after the pandemic, people stop giving a shit.
  18. Nov 22, 2022 at 2:02 PM
    Leif84
    Leif84 New Member
    2023 Tundra TRD PRO
    I hope that it is quickly resolved to your satisfaction. From the photo it does look like an extremely poor job of applying PPF...When done well you can't even it tell it's on.
  19. Nov 22, 2022 at 2:08 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    That definitely looks like the clear protective film, if you look at the second picture right above the reflection of your hand you can see in the gap the plastic starting to peel. It should have been removed prior to delivery, sounds like your dealership did a piss poor job at the PDI (pre-delivery inspection). My Tundra had similar markings on the hood but in dirt rather than air bubbles because they failed to remove all the adhesive like others have mentioned above me.
  20. Nov 22, 2022 at 2:15 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I had some adhesive and light scratching on the rear fender from where protective film or strapping was removed. The dealer brought in their real detail guy and detailed the entire vehicle to perfection. Of course I had to ID it
  21. Nov 22, 2022 at 2:24 PM
    Lou1947
    Lou1947 New Member
    Tundra 1794
    The tundras are shipped with a white protective vinyl over the hood and upper portion of fender, try some WD40 on a small area to see if comes off
  22. Nov 22, 2022 at 2:51 PM
    Breathing Borla
    AZ
    no offense but I wouldn't mess with it at all, let them fix it. if he starts messing with it they will just blame him more
  23. Nov 22, 2022 at 2:59 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sorry this is happening. I suggest calling Toyota USA and get them involved.
  24. Nov 22, 2022 at 3:23 PM
    waves
    That was some white residue, similar to polish residue, that came out easily but they definitely did not polish the truck. They barely managed to wash it due to "not enough staff" and did a poor job at that too. Pretty sure the sales person washed it as she was trying to convince me to have it washed next week. Looking back, I'm wondering if they knew about it and were trying to hide it from me.
  25. Nov 22, 2022 at 5:19 PM
    TundraJeff
    TundraJeff New Member
    2019 Tundra TRD sport crewmax
    What your seeing is moisture under the clear coat it can be removed with I know it sounds dumb but use a heat gun at a safe distance don’t hold it in on place keep it slowly moving around it will slowly disappear
    Retired...finally likes this.
  26. Nov 22, 2022 at 5:23 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    If it was a white residue, how were you able to move a "bubble" w/your finger??
  27. Nov 22, 2022 at 6:13 PM
    jjay
    jjay New Member
    jayjj
    seattle wa
    Use to heat gun or hair dryer lightly after gone
  28. Nov 22, 2022 at 6:34 PM
    When I bought my 22 Frontier, it was clean. I looked it over quite good before my test drive. While signing final paperwork my Frontier was getting a final detail. IE....due diligence. Just sayin. Your dealer sucks BTW. Hope things get corrected for you.
    JLS in WA likes this.
  29. Nov 22, 2022 at 6:56 PM
    waves
    white residue was on the edge of the hood panel where the gap between the fender and the hood is. I wasn't able to move any bubbles.
  30. Nov 22, 2022 at 7:26 PM
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    What??? lol I hope you meant the protective film and not "clear coat paint".
