Front Camera Mounting on TRD Pro Grille WITH RAPTOR LIGHTS
Discussion in '2.5 Gen Tundras (2014-2021)' started by THORYOTA, Nov 22, 2022.
  1. Nov 22, 2022 at 5:52 AM
    THORYOTA
    THORYOTA [OP] God of Thunder
    Thor
    Asgard
    2021 MGM TRD CM "Mjölnir"
    I ordered an Anytime Back Up Cam kit and I am trying to determine the best placement for the camera. If you have a front cam and a TRD pro grille, what do you recommend?
    • Height?
    • Vertical/Horizontal?
    • Buy/Fab Bracket?
    Any other general tips or recs are appreciated!
    :cheers:
  2. Nov 22, 2022 at 6:10 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I'd start with this thread...
    https://www.tundras.com/threads/2014-2021-front-rear-anytime-camera-mod-frac-harness.13633/
    lots of good info in there
    Height, I'd match the height as close to the height of the rear camera.
    I'd definitely mount it horizontal.
    As for the bracket, you could drill into the grill if you'd like or buy/make your own. Here is one I've seen... https://yotaleds.com/collections/tundra/products/tundra-trd-pro-grille-bracket and if I'm not mistaken there may be some 3D printed options linked in the thread above.
  3. Nov 22, 2022 at 6:13 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    THORYOTA[OP] likes this.
  4. Nov 22, 2022 at 6:55 AM
    THORYOTA
    Thor
    Asgard
    Thanks bro!
    I just realized that one of my raptor lights fill the middle void where the YotaLED plate is designed to go. I'm going to see if maybe I can figure out a way to piggy back off the mount for the RL. Now that I think about it, if I mount it above, the light will likely interfere with the picture as well...:monocle:
    I may have to relent and drill into my grille, but I really want to avoid that.
