Rumbling noise at speed in 4H
Discussion in '2nd Gen Tundras (2007-2013)' started by Mbril, Nov 21, 2022.
  1. Nov 21, 2022 at 9:14 PM
    Mbril
    Mbril [OP] New Member
    I noticed a rumbling noise coming from the front of the vehicle at 60+ mph when letting go off the gas. It only happens when the 4H is engaged.
    It's fairly similar to the sound of a bad wheel bearing.
    Any ideas?
  2. Nov 21, 2022 at 9:16 PM
    AZBoatHauler
    So.Arizona
    Transfer case engaged - is the vehicle new to you or is it louder than it used to be? Has the fluid ever been changed?
  3. Nov 21, 2022 at 9:20 PM
    Mbril
    Yes, got the truck a few months ago. I haven't had to keep the 4H engaged at highway speed until now so never noticed.
    I've never had that sound with my 4Runner. Is this a Tundra thing?
    My guess is the transfer case fluid has never been changed, I will probably get that done.
  4. Nov 21, 2022 at 9:23 PM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    Is it because your going 60mph while in 4H?? :monocle:
  5. Nov 21, 2022 at 9:25 PM
    Mbril
    There is no reason you shouldn't be able to drive 60mph in 4H, just have to shift to 4H when below 60.
    Filthyphil likes this.
  6. Nov 21, 2022 at 9:35 PM
    Cortez11
    Cortez11 New Member
    2013 DblCab 5.7 4x4
    You’re right, manual says you only need to be below 62mph when you shift into 4H.
    I’d follow up with is there a reason why you should drive 60+mph in 4H? I can’t picture a need to drive that fast if conditions warrant 4x4.
    Notarobot, slowpokepete and KNABORES like this.
  7. Nov 21, 2022 at 9:38 PM
    Mbril
    Right now we have freezing rain that creates a lot of black ice patches. I don't have a full understanding of how 4x4 works (I usually only use it to get unstuck when in deep snow, etc) but the truck felt quite a bit more stable once engaged.
  8. Nov 21, 2022 at 9:48 PM
    Mbril
    Sorry I think I kinda misread your question. I have the 4x4 engaged because of ice (driving slow in those conditions). I only go 60+mph when it seems safe to do so (which isn't often).
  9. Nov 21, 2022 at 10:21 PM
    AZBoatHauler
    So.Arizona
    Looking at the fluid wouldn’t hurt but I’m guessing it’s normal. I would describe it as a “whooshing” sound but the driveline definitely can be heard when getting up to speed in 4H or 4L.
  10. Nov 21, 2022 at 10:23 PM
    Mbril
    Ok that's reassuring. Thanks!
    AZBoatHauler[QUOTED] likes this.
