rear shock extender
Discussion in 'Suspension' started by TonyT, Nov 21, 2022.
  1. Nov 21, 2022 at 9:23 PM
    TonyT
    TonyT [OP] New Member
    2016 black Tundra SR5
    Hello everyone, I'm new to the forums, I've been looking for some rear shock extender and having a hard time locating one online or at the local shops. anyone with some advice will greatly be appreciated
  2. Nov 21, 2022 at 9:53 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    A shock extender?
    RobertD likes this.
  3. Nov 21, 2022 at 10:33 PM
    RobertD
    Robert
    DFW, Texas
    Yeah, first I have heard of a shock extender.
    What are you trying to do? Have you lifted the rear and your current shocks no longer handle the range so you are wanting an extender? If this, you can normally get some rear shocks that are built for your lift height for a few hundred and they will perform better than a stock shock with an extender (if they make those, I'm now curious).
  4. Nov 21, 2022 at 10:50 PM
    zeekevin
    zeekevin New Member
    Amazon special
    Protune Suspension Rear Shock Extender W/Brake Line Relocation 2-4" Lift Kit fits for Toyota Tundra 07-19 https://www.amazon.com/dp/B08W2NFX97
  5. Nov 21, 2022 at 10:52 PM
    RobertD
    Robert
    DFW, Texas
  6. Nov 21, 2022 at 10:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Tfro33 and NH 2018 Limited like this.
  7. Nov 21, 2022 at 10:56 PM
    zeekevin
    zeekevin New Member
    100% agree, I seen funny stuff replacing dealer installed lift kits with a quality aftermarket shock over the years. And this is one of their cheap profit turning tricks
  8. Nov 21, 2022 at 11:16 PM
    blenton
    blenton New Member
    I’ve seen these before; I, too, dislike them and recommend a new shock with extended length.
  9. Nov 21, 2022 at 11:40 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  10. Nov 22, 2022 at 4:41 AM
    Gfgneo
    Gfgneo New Member
    California
    2021 tundra platinum
    Timbren makes spacers/extenders but idk if they are universal or only work with their bump stops.
    https://timbren.com/search.html?#!year=2021||make=TOYOTA||model=TUNDRA||submodel=ALL MODELS
  11. Nov 22, 2022 at 6:06 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Those are old tech, I remember seeing them as a 16 year old kid in the JC whitney catalog.
    Skip them, nothing but problems. If you need a longer shock due to lifting the rear, there are plenty of decent options for little $.
  12. Nov 22, 2022 at 6:12 AM
    Me personally I would never trust a $25 shock extender much less put weight on it.
  13. Nov 22, 2022 at 8:44 AM
    Beaudog
    Beaudog New Member
    Scott
    2020 Tundra Platinum
    I believe I have a brand new set of those from a lift kit I installed. I didn't use them nor will I comment on their functionality but if you want them, they're yours for shipping cost.
  14. Nov 22, 2022 at 9:00 AM
    Mater
    Mater New Member
    SD
    2016 MGM Platinum
    Not saying I would run them, but Cruz runs shock extensions and he knocks his truck around harder than just about anyone else on this forum. Just something to think about. His also extend from the bottom I believe..
  15. Nov 22, 2022 at 10:45 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    He doesn’t run them as extensions, its a bracket to convert from a oe post mount to an eye. The bracket holding the weight is against the OE location flat on flat. I would bet that is infinitely stronger than a long screw on extension
  16. Nov 22, 2022 at 10:58 AM
    2mchfun
    PRP makes a set for about $20. The world won't stop turning if a shock breaks loose either. Guess it simply depends on how much you like to gamble.Screenshot_20221122-125726.jpg
  17. Nov 22, 2022 at 11:00 AM
    2mchfun
    BTW, welcome from OKC!
