265/70/18 tire pressure vs 275/65/18 tire pressure?
Discussion in 'Wheels & Tires' started by Philogynist, Nov 21, 2022.
  1. Nov 21, 2022 at 3:17 PM
    Philogynist
    Philogynist [OP] New Member
    NY
    I am now running LT265/70/18 Michelin LTX A/T2 Load Range E.
    These replaced the stock Michelin P275/65/18 A/T2.
    Discount Tire says 40 PSI front and 45 PSI rear for tire pressure for the LT265/70/18.
    Stock tires call for 30 PSI front and 35 PSI rear per nameplate data.
    Does that seem correct? Any replies are appreciated.
    2018 Toyota Tundra SR5 Double Cab TRD Offroad, all stock.
  2. Nov 21, 2022 at 3:32 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    42 front 46 rear according to this. You can use chalk test to dial it in from there.
  3. Nov 21, 2022 at 4:55 PM
    Philogynist
    NY
    Thanks for that. Yes, the chalk test is good advice.
    Saltyhero13[QUOTED] likes this.
  4. Nov 21, 2022 at 5:35 PM
    Saltyhero13
    You got it bud! Anytime.
