No heat on passenger side
Discussion in '2.5 Gen Tundras (2014-2021)' started by TCBONSER, Nov 4, 2022.
  1. Nov 4, 2022 at 12:47 PM
    TCBONSER
    TCBONSER [OP] New Member
    2019 Tundra
    2019 Tundra with dual climate control. There are 4 vents across the dash. Only the furthest vent on the driver's side gets hot. The drivers side floor is warm but passenger is cold. When in defrost, driver's side gets warm -- passenger does not.
    The dealerships by me are the biggest crooks going so I want to avoid that at all cost. Any suggestions?
  2. Nov 4, 2022 at 1:43 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    blend door issue? Sound like the door(s) on passenger side are stuck closed?
  3. Nov 21, 2022 at 1:10 PM
    TCBONSER
    2019 Tundra
    Dropped the truck of at the dealer to get the issue checked out. Blend door servo is bad so I need to replace the box. Quoted $4,370 repair !!!
  4. Nov 21, 2022 at 1:19 PM
    TCBONSER
    2019 Tundra
    Is that a ridiculous price? They said they need to rip the dash off to do the repair, but that seems like a lot of money.
  5. Nov 21, 2022 at 1:20 PM
    mgxsequioa
    mgxsequioa New Member
    Is it all labor and do they have to pull the dash off?
  6. Nov 21, 2022 at 1:21 PM
    That's way too much. Coworker bought his box for his 07. Tried to do it himself but gave up. The Yota dealer installed his for around $1500. The box isn't cheap but not $2700! The box was less than $1K. $500 or so.
  7. Nov 21, 2022 at 1:23 PM
    Very, very labor intensive.
    Rocko9999 likes this.
  8. Nov 21, 2022 at 1:26 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    :eek2: For $4370 they should replace the entire HVAC system..:confused:
    Good luck...
    Black Wolf likes this.
  9. Nov 21, 2022 at 1:30 PM
    The "box" is pretty much the whole enchilada. My coworker bought his bad servo first but had a real pain aligning everything all up. Bought the box and still had issues.
    1lowlife[QUOTED] likes this.
  10. Nov 21, 2022 at 1:37 PM
    1lowlife
    DADA
    2014 MGM DC SR5
  11. Nov 21, 2022 at 1:39 PM
    That's pretty much it. Correction....the box has all the blend doors,servos, and such.
  12. Nov 21, 2022 at 1:42 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    It took me all day to replace the silver surround piece around the radio..
    Not my pic but this is what it looked like..
    This is probably only 1/4 of the way to the blower and stuff..:eek2:
    D13BECCC-9304-4BFD-AA90-8F83A77022CE_trM_d244ce3313e7741236f853abc057830525137c22.jpg
    7.62X51 and Black Wolf[QUOTED] like this.
  13. Nov 21, 2022 at 1:43 PM
    That's a frigging nightmare......
  14. Nov 21, 2022 at 1:47 PM
    TCBONSER
    2019 Tundra
    Is it a common problem with Toyotas?
  15. Nov 21, 2022 at 1:49 PM
    Not really. My coworker recently had this issue on his 15 yr old tunny. It's just a royal pain when it happens.
  16. Nov 21, 2022 at 2:00 PM
    TCBONSER
    2019 Tundra
    2019 Tundra. At 89K miles the front differential assembly went bad -- Quoted $3700 for repair. At 110K miles blend door goes bad -- $4300 for repair. $8K in repairs in 3 years -- If I didn't know better I would have thought I bought a Ford!
    batman900, Black Wolf and 1lowlife like this.
  17. Nov 21, 2022 at 2:29 PM
    Definitely sucks. I'm sure you can pay a lot less for the blend door fix. Try other Yota dealers. Take your quote with you.
