Occasional water leak on pax side
Discussion in '1st Gen Tundras (2000-2006)' started by Motopilot, Nov 14, 2022.
  1. Nov 14, 2022 at 7:16 AM
    Motopilot
    Motopilot [OP] New Member
    Josh
    NC/FL
    2017 Tundra crewmax 4x4 Platinum edition
    2” level 285/75R17 Falken wild peak RT 34.1”x11.5” bilstein 5100
    seem to have a tiny leak that happens sometimes when it rains…any ideas? It has to be from the general pax windshield/ firewall area.
  2. Nov 14, 2022 at 7:22 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    From what I've seen here; If you pull your cowl under the windshield you might find your area of intrusion, rust in the corners. High probability around the windshield as well.
    shifty` likes this.
  3. Nov 14, 2022 at 7:23 AM
    alb1k
    Left Coast
    It's good
    Does it do that with the heater on when it's not raining?
    shifty` likes this.
  4. Nov 14, 2022 at 7:31 AM
    alb1k likes this.
  5. Nov 14, 2022 at 7:33 AM
    alb1k
    Left Coast
    It's good
    shifty`[QUOTED] likes this.
  6. Nov 14, 2022 at 7:46 AM
    Motopilot
    Josh
    NC/FL
    I will watch and learn! Thanks guys!
  7. Nov 17, 2022 at 5:43 PM
    bfunke
    bfunke Tundra Curmudgeon
    The little nylon nutserts on the cowl have a gasket that deteriorates and allows water in
  8. Nov 21, 2022 at 12:00 PM
    Motopilot
    Josh
    NC/FL
    0E3601C4-D8C5-4390-8E31-A732C099B6D1.jpg 4F1D5DE4-25D5-44CB-8CB7-77A0F26D6FED.jpg This the issue? Or underneath the cowl out of immediate sight?
  9. Nov 21, 2022 at 12:26 PM
    Again, watch the video in the link I posted above. It should be super clear. Click the link, skip straight to the video. Watch it, then scroll back to the "Cowl fasteners (all models)" section of that post to get part numbers and other details you'll need to know to fix it.
    What you need to get to is under just the black cowl cover panel in your pic which is really fun to pop off, because you can break the tophat-shaped receiver in the body, or the black plastic snap in the cowl cover. There are a few ways to fix it, either replacing the part, or using auto-paint-safe sealant and sealing it in place. You'll see exactly which fastener is a problem in that video.
