Happy with OEM exhaust ?
Discussion in 'Performance and Tuning' started by Shawn4x4, Nov 10, 2022.
  1. Nov 17, 2022 at 7:26 AM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    i've upgraded most of the usual suspects (wheels+tires, lift, lighting) and have no plans to change my exhaust. The droning at highway speed on the way to the lake multiple times a year isn't worth the hassle to me.
  2. Nov 17, 2022 at 7:56 AM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    Perfect description - "took resonance feedback away...."
    Never realized it was there until it was gone.
    Tbrandt[QUOTED] likes this.
  3. Nov 17, 2022 at 7:57 AM
    17TundraDCEd
    Ed
    SE Pa
    Rear Sway Bar
    I agree. I was going to mention that, but I figured it was placebo, but it does seem more responsive as well as more refined.
  4. Nov 17, 2022 at 8:00 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    total placebo but the feeling is there
    17TundraDCEd[QUOTED] likes this.
  5. Nov 17, 2022 at 2:48 PM
    Robster80
    Robster80 New Member
    when i swapped my DD 8” for a 12” during the wait period i ran stock with the resonator and it was great. Like u said quiet and smooth. I keep going back and forth about leaving my 12” on cuz i do like the sound at times (at times wanting even louder), but then on long trips i prefer the quietness
    Pbed85 and 17TundraDCEd like this.
  6. Nov 17, 2022 at 3:15 PM
    Pbed85
    Pbed85 New Member
    Pete
    MN
    2019 dbl cab limited cement
    I went 8 then 12 now back to stock w resonater. Sticking w stock. Towing the boat for hours at a time gets old w extra exhaust noise. I've learned that I can deal w too quiet but can't handle too loud. Also getting sick of crawling under the truck to swap exhaust. An expensive keep it stock lesson.
  7. Nov 17, 2022 at 5:00 PM
    jtwags
    jtwags Concrete jungle
    League City, TX
    2018 Tundra CM
    Undercover Elite LX, Xact Contour
    I did the same thing. Also added some door panel deadening. Nice smooth drone free ride but the motor sure is loud when under throttle to let you know a beast is still under the hood.
    Pbed85, Robster80 and Tbrandt[QUOTED] like this.
  8. Nov 17, 2022 at 6:14 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Plus removing the stock exhausts weight savings, the r2d2 sized muffler and pipes weigh 45lbs when I weighed mine. I get why the stock exhaust is so quiet but for me it was just silly to hear the intake more than the exhaust driving around.
  9. Nov 17, 2022 at 6:23 PM
    Tundra Dude 45
    Tundra Dude 45 New Member
    Eric
    2019 SR 4.6L DC 4X4
    8” BAMuffler, TRD airflow accelerator, front window tint/windshield sun stripe, debadged tailgate 4x4 emblem, trimmed mud flaps, antenna removed stainless screw added, TRD rear sway bar, AFE high flow air filter.
    I have the 8” DD exhaust, and added the Toyota black tip. I don’t like single outlet exhausts but from all my research it provides the most power, so I’ll live with it. Even if I could just get a dual outlet tip I’d be happy with that. All of my vehicles have had aftermarket cat back exhausts asap after purchase, because race car.
  10. Nov 17, 2022 at 6:24 PM
    RegGex
    RegGex I noticed you copied my beard
    Oregon
    2021 TRD Pro CM
    You could grab this guy — https://afepower.com/afe-power-49t25374-b12-mach-force-xp-2-1-2-304-stainless-steel-exhaust-tip
    Seen some folks run it and it looks great
  11. Nov 20, 2022 at 7:49 PM
    TundraPJ
    TundraPJ New Member
    JP
    DFW, Texas
    '19 SR5 TRD Off-Road
    Fox TRD Pro Shocks BFG KO2’s Dirty Deeds 14” BAMF n-fab nerf bars
    What did you use to for the sound deadening? How long did it take you, roughly.
    I’ve gone from stock => TRD => Stock + Resonator => 14” DD => stock again.
    In the end, stock is more practical for what I’m wanting - although I miss the throatiness of the DD system when I wanted it a little louder.
  12. Nov 21, 2022 at 7:04 AM
    Tbrandt
    Tbrandt I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    I used the Siless brand from Amazon, spent just over $100 for everything. Cheap, but labor intensive. Hopefully the foam doesn't disintegrate after 10 years.
    https://www.amazon.com/gp/product/B07BLSP8JV?ie=UTF8
    https://www.amazon.com/gp/product/B07LH1X7QX?ie=UTF8&th=1
    https://www.amazon.com/gp/product/B07B75PD8B?ie=UTF8
    Doors ~2 hours each (x4).
    80 mil butyl sound deadening. 1 layer on the outer door panel and 1 layer on inner door panel.
    157 mil foam insulation. 1 layer on inner door panel after butyl layer, plus one layer on the outer door panel behind each speaker.
    Back wall and floor under rear seats ~4 hours
    80 mil butyl sound deadening, then 314 mil foam insulation.
    I left the vapor barrier in place and managed to install all the sound deadening on the outer door panel through the door speaker opening. I hear almost no exhaust noise in the cab, it's 90% intake and engine noise through the dash. Extremely quiet for a V8 truck and it makes a huge difference on sound system quality with the doors deadened/insulated.
    I'm debating dropping the header liner and doing the roof to try to get rid of some wind noise (which is the loudest part of the truck now), but I'm getting lazy as the years go by with putting so much work into my trucks. I haven't felt the need to do the whole floor since my tires are so quiet. I completely stripped the interior of a 2014 FJ Cruiser a few years back and did everything and this truck is already much quieter than that one.
    There are several good threads on the site with a lot more help than I can offer.
    GG13 and TundraPJ[QUOTED] like this.
