adjustable drop hitch receivers
Discussion in 'Towing & Hauling' started by 2010bigdog, Nov 20, 2022.
  1. Nov 20, 2022 at 3:20 PM
    2010bigdog
    2010bigdog [OP] New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what brand adjustable drop receivers do you guys like and recommend ? Looking to buy one this week!
    Thanks1
  2. Nov 20, 2022 at 3:37 PM
    Reese.....
  3. Nov 20, 2022 at 6:30 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  4. Nov 21, 2022 at 5:42 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    Has anyone used BULLETPROOF or B&W hitches ?
  5. Nov 21, 2022 at 6:08 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
  6. Nov 21, 2022 at 6:14 PM
    BoysandHisToys
    BoysandHisToys New Member
    Central Virginia
    2013 Tundra Crewmax Limited
  7. Nov 21, 2022 at 8:16 PM
    AZTundra
    Paul
    Phoenix, AZ
    B&W stow and go adjustable hitch. No complaints.
    2010bigdog[OP] likes this.
  8. Nov 22, 2022 at 2:45 AM
    B&W and weigh safe hitches.
  9. Nov 28, 2022 at 10:33 PM
    LevelUp
    LevelUp New Member
    2016 DCLB SR5 w/ TRD OR in MGM
    OEM LED headlights, interior ambient lighting, running boards, Firestone airbags, misc led swaps, started blacking out phase and chrome delete, Diamondback HD w/ Yakima Overhaul HD (on the way)
    After extensive research and finding a dealer nearby in CT, I’ve been using a Bulletproof 6” adjustable drop for about a year. Was on my Tacoma and now using it on the Tundra. My 14’ V-nose enclosed trailer sites pretty low and I try to keep it close to level. Really happy with it.. although I’ve scraped it a few times going up steep drives or dips in streets, I guess that’s mostly my fault, but otherwise it’s a nice unit.
    bulldog93 and 2010bigdog[OP] like this.
  10. Dec 2, 2022 at 3:22 PM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    so does it adjust from 1" to 5" ?
    Prostar 190 likes this.
  11. Dec 2, 2022 at 3:32 PM
    From even or 0" to 5".
  12. Dec 2, 2022 at 3:33 PM
    Anohibian
    Anohibian New Member
    Anchorage, AK
    2018 Inferno Crewmax
  13. Dec 2, 2022 at 6:35 PM
    LevelUp
    LevelUp New Member
    You can actually flip the whole receiver over and get the full scale of measurements. So really a 5” adjustment is 10” if it can clear the bumper. It’s rare you’d need to go up that high, just saying… My bulletproof allows this anyway. Something to consider with some of these adjustable hitches.
  14. Dec 2, 2022 at 6:53 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Also have the tri ball B&W with a 7” drop, due to a 2”+ rear lift. American made so they say too. Has the stow and go/anti theft mechanism which works well. Obviously you don’t want too much drop otherwise will hit the ground while towing. 5” drop is ideal for a stock rear height and can then accommodate all trailer heights to level them, takes a bit of experimentation to figure out which setting to level each trailer.
  15. Dec 3, 2022 at 6:14 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I have a lift on my truck (4") so wondering which one I would need
  16. Dec 3, 2022 at 6:43 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    This will give you details on how to measure to know the drop/raise you need. Good info!
    https://www.etrailer.com/faq-ballmount.aspx
  17. Dec 3, 2022 at 7:48 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    I use this guy with my stock height SR5 TRD Offroad. [Edit - found it for $159 at Tractor Supply vs $179 at Northern Tool!] Comes with easily-accessible locking hitch pins so you don't have to worry about it walkin' off with some stranger. Bonus points for being all aluminum so it's incredibly light and easy to remove/install, 12k lbs towing capacity and all 3 possible ball sizes included. Fits easily in one of my under-seat storage bins in my CrewMax. I really like it, actually, I was surprised.
    Think the only thing I'd change about it is to swap the locking pins out for ones like this, that rekey to match the truck key. Fewer keys on my keychain, the better.
  18. Dec 5, 2022 at 10:16 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    I use this one...its usually cheaper than the B&W, bulletproof.. its Curt which is a good known brand that makes towing products..this is a 14000 lbs hitch.
    https://www.curtmfg.com/part/45900
    Hugemoose and 2010bigdog[OP] like this.
  19. Dec 5, 2022 at 11:56 AM
    Dillusion
    Dillusion New Member
    Kyle
    2019 SR5
    I use a
    https://rhinohitch.com/
    Because I can adjust the height with the trailer still attached. I need it at its highest setting to bring my boat down my driveway which is a hill or the trailer tongue will scratch. Bring it down to tow.
    burtlively likes this.
  20. Dec 7, 2022 at 11:04 AM
    Hugemoose
    Hugemoose New Member
    Philly
    2016 Tundra Crewmax
    Not enough....
    I have the same one, had it for probably about 4 years now. Absolutely love this hitch. However, it was WAY cheaper when I bought it, sub $200. My father has the same Curt hitch but in the 2.5" shank version, as well as a FastWay brand adjustable hitch that is a larger 10" drop. Both are nice units.
    I really don't think you can go wrong with any brand, just choose a price range and one with enough drop and you'll be fine.
    baraynavab[QUOTED] likes this.
  21. Dec 7, 2022 at 11:49 AM
    baraynavab
    Atlanta
    100% agree with you @Hugemoose no reason to be loyal to any brand.. go with the best one that fits your needs and budget.
