  1. Nov 16, 2022 at 2:45 PM
    Whatcha get?
    RUSTYNUTS and abcinv like this.
  2. Nov 16, 2022 at 2:59 PM
    805Tundra
    805Tundra New Member
    Ben
    Central Coast
    2004 White 4x4 Double Cab
    MD springs. How are the heavy duty ones you got? Did they settle at all?
  3. Nov 16, 2022 at 3:01 PM
    Nice. They did settle, I haven’t measured again nor have I filled the tank to the tippy top, but they handle soooo much better than my old oems with 160k on their shoulders
  4. Nov 16, 2022 at 3:08 PM
    805Tundra
    Ben
    Central Coast
    Love to hear it. Ya I’m 175k on mine with a topper plus about an extra 100lbs. They aren’t sagging to bad surprisingly but are definitely on there way
    oscardog86 likes this.
  5. Nov 16, 2022 at 3:11 PM
    I’m sure it will be a huge improvement, im almost sure I was sitting below stock height, so it was a little odd to see it so high in the air, but I’ve gotten used to it and it looks the way it should when I walk out of the store and eye balling it.
  6. Nov 16, 2022 at 3:17 PM
    805Tundra
    Ben
    Central Coast
    When I talk to Eric at archive he said stock height from axle to frame is about 9.5”. If your below that it’s going to seem like you’re getting more lift.
  7. Nov 16, 2022 at 7:20 PM
    Casper421
    In the woods
    06 DC
  8. Nov 16, 2022 at 7:38 PM
    Siebler
    Siebler Taco Tow Vehicle
    CJ
    Eastern Oregon
    01 AC 4x4,07 Sequoia 4x4, 99 Tacoma Long Travel
    Monstaliner, Kings and Camburg UCA, projector retros, DD injectors, homebuilt bumper/ sliders
    Beefed Taco used to make these on Custom Tacos wayyy back when (he used a Heim though). Ive had one on my truck over a decade. Easy way to get rear brakes to grip once I ditched the bed and did cage (without moving to a manual valve in cab which I will do eventually). Has worked for me!
    Damn even found a pic from him, too cold outside for me to go to Taco and snap one haha.
  9. Nov 16, 2022 at 7:46 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Well, maybe not the first, but it is all OEM except the bracket - but World's First is catchy, lol. Maybe just a coincidence or placebo, but I had to lock up to prevent a rear end this afternoon and damn the truck did it's job.
  10. Nov 16, 2022 at 7:49 PM
    alb1k
    Left Coast
    It's good
    When I put the MD on I was at 9" back there. Went to 11.75. Now I'm guessing 10.50 - 11, but I should measure.
    oscardog86 and 805Tundra[QUOTED] like this.
  11. Nov 16, 2022 at 8:02 PM
    805Tundra
    Ben
    Central Coast
    I would be curious. I’m hoping with the shell and some additional weight I will end up somewhere between 11-11.25. I think I’m hovering just over 9 now
  12. Nov 16, 2022 at 8:22 PM
    alb1k
    Left Coast
    It's good
    @805Tundra I got curious as well. I'm 11.25 and 11.5, with the rear on the higher part of the driveway. The direction I'm parked in the drive makes a big difference on the fronts, not so much the back.
  13. Nov 16, 2022 at 8:39 PM
    805Tundra
    Ben
    Central Coast
    You’re at that now with the drop shackles? How much weight are you carrying?
  14. Nov 16, 2022 at 8:48 PM
    alb1k
    Left Coast
    It's good
    i went back to OEM length after the springs broke in. Fiberglass tonneau, rack, pretty heavy rear bumper. around 400 lbs without the spare and jack up there
  15. Nov 16, 2022 at 9:07 PM
    daveeasa
    Fwiw, Jason says the drop shackles helped my truck. Excited to see it myself.
  16. Nov 16, 2022 at 9:07 PM
    805Tundra
    Ben
    Central Coast
    Ahh so those were initial numbers after install. Looking forward to getting these bad boys on but unfortunately it won’t be for awhile.
  17. Nov 16, 2022 at 9:09 PM
    alb1k
    Left Coast
    It's good
    Those last numbers were tonight. But I'm not on level ground.
    805Tundra[QUOTED] likes this.
  18. Nov 16, 2022 at 10:46 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  19. Nov 16, 2022 at 11:03 PM
    alb1k
    Left Coast
    It's good
    Thank you. I really love the extended box ends even though they are 72 teeth rather than the 90? teeth high dollar ones. I paid full price on my set - $100 is a steal.
    GearWrench does really well on the Project Farm tests. I had to grab the ratcheting standard box ends, $2/wrench. And 61% off the impact sockets? Done.
  20. Nov 16, 2022 at 11:15 PM
    artsr2002
    'Yonder
    I've got some of their ratcheting wrenches. Haven't broken one yet. I also like Metabo and Neiko stuff.
  21. Nov 16, 2022 at 11:21 PM
    alb1k
    Left Coast
    It's good
    I currently have the SAE and Metric ratcheting, and the long box end ratcheting. I've pulled so hard on those long ones that they should break. They don't, they just flex if I don't pull straight and flex back to shape. Even the 8mm. Quite good.
  22. Nov 17, 2022 at 3:42 AM
    Tundra2, oscardog86 and FrenchToasty like this.
  23. Nov 17, 2022 at 4:07 AM
    Oooo. Snap On. Fancy.
  24. Nov 17, 2022 at 4:38 AM
    I assumed I was going to get Rick rolled
  25. Nov 17, 2022 at 6:26 AM
    Yup, this is what we get for not being awake at ~2am over on the best coast.
  26. Nov 17, 2022 at 7:38 AM
    alb1k
    Left Coast
    It's good
    Gonna be sweet!
  27. Nov 17, 2022 at 7:39 AM
    alb1k
    Left Coast
    It's good
    West Coast for the win. Sometimes...
    txagg and shifty`[QUOTED] like this.
  28. Nov 17, 2022 at 7:47 AM
    alb1k
    Left Coast
    It's good
    There is a fine line, over do it and they will lock too quick and fishtail - but yes.
  29. Nov 17, 2022 at 9:30 AM
    alb1k
    Left Coast
    It's good
    Time to get to work…
    NUDRAT, Tundra2, CodyP and 7 others like this.
  30. Nov 17, 2022 at 11:14 AM
    I'm still losing a tiny amount of coolant. Once a year I have to add just a bit to get back to baseline. Anyone else have to do this? The last time I asked some said it's normal while others disagreed.
    KingSequioa007 likes this.
