Curt BetterWeight Review
Discussion in 'Towing & Hauling' started by baraynavab, Nov 15, 2022.
  1. Nov 15, 2022 at 7:42 PM
    baraynavab
    baraynavab [OP] Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    So I was able to get the Curt BetterWeight device. I think it may be a decent device to get an "accurate enough" weight figure on most vehicles.
    I ran it on my 2007 Tundra 4x4 5.7l SR5 Crewmax truck and found the weight to be consistent (see figures below). Please check below. Which in my case happens to be around 5900lbs (can someone verify if their unmodified Tundra with the same config weighs the same?)
    Additionally, I use the Payload weight function to see if it can weigh me correctly and It was dead on accurate.
    So I was wondering if anyone else tried it out? I think its a good device to get within 100lbs to 500lbs within your vehicle weight. Which is more than enough to make sure you are within your advertise weight limits for your truck.
    let me know what you think... TIA.
