Is 0W20 oil too thin for 2007 5.7L Tundra?
Discussion in '2nd Gen Tundras (2007-2013)' started by alexusw, Nov 10, 2022.
  1. Nov 10, 2022 at 1:53 PM
    alexusw
    alexusw [OP] New Member
    2007 Desert Sand Mica Tundra LTD
    I was just wondering if this oil weight is too thin or could cause oil consumption issues? Truck is mostly serviced at the dealer and they never mention that it consumes oil which I’m assuming is not much of a problem. I always get oil change between 4,500-5,000 miles. Does anybody else with 07-09 Tundras use 0w20 oil? The reason I ask is because I heard that 0w20 was recommended for 2010+ models, although the oil cap has that it can take 0w20 in prior models. Most say that 5W20 is better and I been using 0w20 year round over the last few years since I’ve had this truck with no issues. Just want to have a piece of mind. I was thinking of switching to 5W20 when it gets hot again, but since it’s getting colder I use 0w20.
  2. Nov 10, 2022 at 1:56 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Yes it’s fine
    snivilous, ColoradoTJ and alexusw[OP] like this.
  3. Nov 10, 2022 at 2:42 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    I have used 5w-30 synthetic in my 2007 - 5.7L since new with no apparent adverse effects. (truck is always garaged and never subject to freezing temps) Serviced at the dealer since new every 4-5000 mi or 1 year, whichever come first. FWIW
    Larly5000 and alexusw[OP] like this.
  4. Nov 10, 2022 at 2:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    In 2k miles with 5w-20 ive burned no oil. With 0w-20 ive burned half a quart in that time for years
    alexusw[OP] likes this.
  5. Nov 10, 2022 at 2:54 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    The difference between the two is almost non-existent unless you live in an area that goes below 0*.
    At operating temps they are the same. On cold start up(in extreme cold temps) the 0w should flow slightly better, til warmed up.
  6. Nov 10, 2022 at 3:18 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    How large a piece do you wish?
    Please express the value in femto-grams.
  7. Nov 10, 2022 at 4:52 PM
    alexusw
    Lol I’m not familiar with femtograms, so I’ll just say the highest value (whatever that is)
    hagrid[QUOTED] likes this.
  8. Nov 14, 2022 at 1:25 PM
    WV_Warrior
    WV_Warrior New Member
    Cody
    West Virginia
    2021 CM TRD Sport
    Run it. Monitor it. Change and repeat.
  9. Nov 14, 2022 at 2:05 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Went from Moble1 0w-20 to this 30k miles ago (3 oil changes now) engine idles much quieter and I think smoother now
    Never had oil consumption issue 150k on the clock
    Terndrerrr likes this.
  10. Nov 14, 2022 at 2:52 PM
    70m4h4wk
    70m4h4wk New Member
    Paris of the Praries
    23 Silverado LT, CCSB, 2.7L Turbo
    2/2 Drop, Ram Daytona Spoiler
    I ran 0w20 in my 07. Supposed to make it a little easier to start in the winter. I'm not sure it matters at -40. I never had any oil-related issues, it ran great.
  11. Nov 14, 2022 at 3:10 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    THIS ^^^. THIS ^^^. THIS ^^^. THIS ^^^. THIS ^^^. THIS ^^^. THIS ^^^. THIS ^^^.
  12. Nov 14, 2022 at 4:37 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    lol why. (amsoil :thumbsup:)
    NWPirate likes this.
  13. Nov 14, 2022 at 5:26 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Changed my oil last week. Had a bunch of Pennzoil platinum in my garage, so I thought I’d just use that up instead of throwing it away.
    My engine is much noisier than it was with the Kirkland I had in there before it.
    So far, Amsoil and Kirkland have been very quiet and smooth. Mobil 1 Advanced Fuel Economy and Pennzoil Platinum have been noisy. I’m going back to Kirkland. Might only go 3k on the Pennzoil, lol…
  14. Nov 14, 2022 at 5:36 PM
    Black
    2014 Tundra Limited CrewMax
    I went to Amsoil 5w30 from Amsoil 0w20 last change and the motor is noticeably more quiet and smooth.
    Bought LiquiMoly Molygen 5w30 for my next change to see if it gets any quieter.
    Hbjeff and OHwendTrd like this.
  15. Nov 14, 2022 at 6:27 PM
    NWPirate
    Zach
    WA
    Interesting.. might have to give this a shot, I've got some Platinum to use first as well. I usually have to give my truck a splash of oil before I change it @ 5-6k miles.
    Leo's first[QUOTED] likes this.
  16. Nov 15, 2022 at 10:39 AM
    Tsm503
    Tsm503 Nothing to see here
    2021 DC SR5
    RC leveling kit GCS Transmission Cooler
    Going to run OEM filter and 0w-20 till the powertrain warranty runs out. Then switching to Kirkland. Oil changes every 3k for the life of the vehicle.
  17. Nov 15, 2022 at 2:42 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Why would one change full synthetic every 3000 miles? Seems like a waste to me unless the Kirkland you're going to use is conventional that is.
    Leo's first likes this.
  18. Nov 15, 2022 at 3:56 PM
    Tsm503
    2021 DC SR5
    It may be a waste, but I feel better about it. I’ve done 5k oil changes and the oil gave off a strong gasoline smell. I don’t mind spending the extra money.
    07DCLimited likes this.
  19. Nov 15, 2022 at 4:20 PM
    Tsm503
    2021 DC SR5
    Preventative maintenance I can afford. I can’t afford an engine rebuild.
    NWPirate and 07DCLimited like this.
  20. Nov 15, 2022 at 5:20 PM
    jbrnigan
    jbrnigan New Member
    Midwest
    If the truck is only driven short distances and never fully warms up, change intervals should be shorter. My truck is driven less than 3000 mile per year so it get changed every spring.
  21. Nov 15, 2022 at 9:04 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Agreed, I use Amsoil as well, not signature but more reasonably priced 5W-30. The mixture process seems like an extra unnecessary step, personally, but hey to each their own and glad your truck runs well with it. Good OCI, clean oil is what I keep hearing is key.
