Engine Harness Looms Cracked
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Nov 14, 2022.
  1. Nov 14, 2022 at 10:46 AM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    My engine harness looms are getting brittle particularly the wires to the injectors. I've not found any replacements in Toyota OEM gray. Anyone found a solution for repairing our Gen1 wiring harnesses? Thanks
  2. Nov 14, 2022 at 11:00 AM
    This is the same for my injectors and my coils. Whatever that rubbery stuff is has degraded. I have a bunch of 3/8" split loom, strongly considered just looming it and TESA tape over it.
    des2mtn and snivilous like this.
  3. Nov 14, 2022 at 11:06 AM
    bfunke
    @shifty` - I was thinking same. Debating between Tesa tape and the non-adhesive tape GM uses. Kinda worried that any adhesive will be a sticky mess in the heat.
    shifty` likes this.
  4. Nov 14, 2022 at 11:16 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'm in no way an authority on this. Though I am interested given that I have a '97 T-100 that is my daily driver.
    What about the "tape" like material that is used for wrapping motorcycle exhaust header pipes?
    I've never used it so I'm speaking/typing from a bit of ignorance. This? >> https://www.amazon.com/Design-Engin...t=&hvlocphy=9012572&hvtargid=pla-450903913138
    shifty` likes this.
  5. Nov 14, 2022 at 11:49 AM
    IIRC, for the injectors and coils, Toyota opted for a looser-fitting sleeve, I'm assuming it's intentional to create an airgap, reduce heat reaching the wire? Whatever replaces may be worthwhile to use the same. I figure if it's in a loom, and the loom is Tesa-taped, it emulates the old setup. Split in the loom would make it easy to chase over the wires w/o needing to de-pin anything, then the tape will hold the loom shut.
  6. Nov 14, 2022 at 12:59 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Tesa tape is what I did on one of my engines, split loom would work but I don't think it looks as good for short spans like that.
    shifty` and des2mtn like this.
  7. Nov 14, 2022 at 3:46 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I had the same issue on my T4R and used some Tesa tape and then reflective heat tape around the plastic parts that go behind the engine. Worked pretty well and no issues.
    txagg and shifty` like this.
