Bright Box Fogster assist
Discussion in '2.5 Gen Tundras (2014-2021)' started by nobodyintexas, Nov 13, 2022.
  1. Nov 13, 2022 at 11:30 AM
    nobodyintexas
    nobodyintexas [OP] What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    just got the Bright Box Fogster thing for my '20 1974
    I'm lazy -
    how do I reach the headlight connection?
    do I need to remove the headlight?
    if so, is it just a couple bolts?
    fog lights...ugh...I know what it takes to reach those.
    and remember - speak to me as if I'm a 5yr old or a golden retriever.
  2. Nov 13, 2022 at 11:49 AM
    Taco-Spike
    Two Trucks
    Some of the connections might be tucked in the inner fender
    remove the grille (push pin clips and some bolts) on top
    Remove the lower headlight panel. If I remember correctly just one push pin clip (per side)
    then a few bolts for the headlight
    Tons of YouTube videos / a lot of them show removing bolts from the inner wheel area for the lower headlight panel, not needed at all
    nobodyintexas[OP] likes this.
