  1. Nov 10, 2022 at 9:29 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
  2. Nov 10, 2022 at 10:29 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Just received my S2's thanks to @Baja Designs. Install is underway for this third brake light.
  3. Nov 10, 2022 at 10:48 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Can't wait to see the finished product @reywcms.
    Best,
    Brandon
    reywcms[QUOTED] likes this.
  4. Nov 10, 2022 at 10:58 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Yup definitely looks like an ELD. It will have GPS, probably can pull diagnostics, and probably has an accelerometer (for capturing harsh driving, etc). I'd be a little concerned if I unknowingly found one installed in my vehicle...
  5. Nov 10, 2022 at 12:37 PM
    marc32
    marc32 New Member
    Mario
    Maryland
    2015 Toyota Tundra SR5 4x4
    That device is usually installed by companies that are managing fleets. I use the same type of system to monitor my work trucks.The only data I've seen it pull off is gps cordinates, traveling speed. Some of these units have the capability to lock out ignition and lock doors. One thing I would though, is call the company where that product is from and with the serial number you can find out if the device was active after the purchase of your truck. Other then that there isn't much to worry about.
  6. Nov 10, 2022 at 2:31 PM
    AGSport
    AGSport New Member
    PA
    21’ AG Sport
    Yeah it would be a pain to ship lol.
  7. Nov 10, 2022 at 2:52 PM
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    Installed the Decked drawers.
    AggiePhil, jpod, Wallygator and 9 others like this.
  8. Nov 10, 2022 at 3:18 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Running the wiring now. Should be sweet!
  9. Nov 10, 2022 at 3:20 PM
    The OEM housing was fun to remove wasn't it? I had to use 3 pry tools to get mine out when I did the wiring conversion.
  10. Nov 10, 2022 at 4:07 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Absolute nightmare lol
    Taco-Spike and cartage1 like this.
  11. Nov 10, 2022 at 4:20 PM
    Velocity72
    Velocity72 New Member
    Upstate SC
    2021 Platinum
    Metal skills. Very nice.
  12. Nov 10, 2022 at 5:55 PM
    STravis
    STravis SOB Fabrication Vendor
    Travis
    Ruidoso, NM
    17 TRD Pro CM, 08 Supercharged Single Cab
    Got my rear cat skid designed and built today. I made bolt brackets that sit on top of the crossmember so you don't need a wrench on top in a hard to reach spot. I did the same with the front skid as well. I'm happy with the way everything came out.
  13. Nov 10, 2022 at 7:25 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Dude that looks awesome. Nice work!
  14. Nov 10, 2022 at 7:29 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    What is a busbar?
  15. Nov 10, 2022 at 8:27 PM
    Nice job.
    STravis[QUOTED] likes this.
  16. Nov 11, 2022 at 3:11 AM
    It is for adding additional power connections for accessories. It gives a cleaner look and eliminates the rats nest look of having multiple wires coming off of the battery terminal.
  17. Nov 11, 2022 at 4:53 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    Turns out I can set this platform on top of the rear seat and sleep on it (or so it seems). I turned it 180° so the legs are in the seat and then propped some stuff up on the other side to level it out. Backseat is 5’ wide and I’m 6’ tall and can still very comfortably lay back there. Going to test it camping this weekend.
    C8A15BBF-7DF3-48E3-8EBC-7A78A16E4916.jpg A6CFAE20-93EC-4DE9-B077-1D9AD77AB9E7.jpg 4377686D-D9D4-448B-B23D-1E6778668FED.jpg
  18. Nov 11, 2022 at 4:57 AM
    Looks comfortable
  19. Nov 11, 2022 at 6:27 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I'm 5'9" and sleeping on a rear bench in my DC a few nights in a row. It is not very comfortable, but 2-3 nights is ok. Was thinking about building a platform, something you've pictured. Thanks for confirming that might work!
    There's also a bed in trunk, but creeping out of the bed at night for beer by-product disposal is absolute nightmare, especially in winter =)
  20. Nov 11, 2022 at 6:31 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    It wouldn’t be difficult at all to make a platform like mine but dedicated to sleeping! I have like $80 and a couple of hours into this one.
    I thought about sleeping in the bed of the truck for more room but I have a tonneau so it would be like a coffin.
  21. Nov 11, 2022 at 6:38 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Mine is ok. The only real problem is access to the bed and lifting the gate.
    If I add an ammo can wood stove burning pellets for half a night or so, I may change my opinion.
  22. Nov 11, 2022 at 10:15 AM
    romad86
    romad86 New Member
    Warrenton, VA
    2021 Limited Cement
    Well done!
  23. Nov 11, 2022 at 11:35 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    In Vegas it's the place you walk up to and order a drink while riding around the strip in a bus with a crap ton of other drunk people :cheers:
    Blowdart, RainMan_PNW, JCBerb and 4 others like this.
  24. Nov 11, 2022 at 12:07 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    :rofl: I know what that is....I meant in regards to that plastic thing:p
  25. Nov 11, 2022 at 12:24 PM
    CaptRussia253
    Ruslan
    Bumper on. Will pull it off and add lights and winch after Christmas. This thing is badass!
  26. Nov 11, 2022 at 1:30 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    that looks great, what bumper is that?
    CaptRussia253[QUOTED] likes this.
  27. Nov 11, 2022 at 2:51 PM
    CaptRussia253
    Ruslan
    @STravis
  28. Nov 11, 2022 at 3:06 PM
    What is the suspension setup and wheel pkg on the 4R? Is it the 4.0 V6 as well?
  29. Nov 11, 2022 at 4:13 PM
    SAGE63
    San Diego County
    greased my delta joints today.... with lucas oil red n tacky #2...appx 3500 miles...since installation. The old grease squirting out still looked almost new. Sorry forgot to take pictures
    GAknight, bulldog93 and Taco-Spike like this.
  30. Nov 11, 2022 at 4:25 PM
    blrroman27
    blrroman27 New Member
    2021 Toyota Tundra SR5 Trail Edition
    n/a
