Preventing engine from shutting off when opening door
Discussion in '2.5 Gen Tundras (2014-2021)' started by Oerterg, Oct 5, 2019.
  1. Jan 21, 2020 at 1:18 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Not true. I've seen it with key start vehicle.
  2. Jan 21, 2020 at 1:20 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Woops! :oops:
  3. Jan 24, 2020 at 4:18 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Anyone have a list of 'commamds' for the Fortin Evo One? All I've seen are install and programming instructions. Press the lock fob 3x to start...3x to stop. Unlock to unlock doors while running. Is there anything else?
  4. Feb 20, 2020 at 12:36 PM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    its pretty simple.... that's all it does...
    I removed the factory remote start
    my 2016 key start.... TRUCK TURNS OFF WHEN DOOR OPEN..
    sold it and replaced it with FORTIN. simple
    but it requires dash access.... radio, glove box and some interior trim... but its all plug and play
  5. Feb 24, 2020 at 7:20 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I had to use a couple posi taps but yeah PnP for sure
  6. Apr 8, 2020 at 4:37 PM
    Jom
    Jom New Member
    2020 Gray Tundra Crew Max
    None
    You would think Toyota would allow you to open the door with the key phob. But it’s not working for me either.
  7. Nov 8, 2022 at 7:20 PM
    samschwarzlose
    samschwarzlose New Member
    Sam
    2022 Tundra Platinum Long Box
    Tonneau cover
    I understand that Toyota may shut off the engine after remote start when you open the door to prevent theft. But why will they not allow you to lock the doors while it is running to prevent the same thing? Both features are turrble.
    OHwendTrd likes this.
  8. Nov 8, 2022 at 7:26 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Still does this with the 22 model?
  9. Nov 9, 2022 at 7:06 AM
    samschwarzlose
    Sam
    Tonneau cover
    Yes sir 2022. With all the current updates.
  10. Nov 9, 2022 at 7:19 AM
    Gort
    Gort New Member
    Canada
    2020 Tundra SR5+
    Strange, my 2020 SR5 allows me to open the door and put my key in and turn it to "on" (but not far enough to engage the starter) and from there I can drive without the engine ever shutting off. It's only when I put my foot on any of the pedals that my truck shuts off.
    That is using the factory fob too..
  11. Nov 9, 2022 at 7:34 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    This issue is specific to push-to-start models.
    Gort[QUOTED] likes this.
  12. Nov 9, 2022 at 8:38 AM
    samschwarzlose
    Sam
    Tonneau cover
    I am pretty sure that was a poor attempt at condescending humor. I thought trolls only roamed around facebook and twitter.
  13. Nov 9, 2022 at 10:56 AM
    Gort
    Gort New Member
    Canada
    2020 Tundra SR5+
  14. Nov 10, 2022 at 10:40 AM
    The Californian
    Eric
    Yah, when people don't quote what they are replying to, I imagine them as a crazy person yelling at the wind with no one around.
    bulldog93, 1lowlife, GODZILLA and 2 others like this.
  15. Nov 10, 2022 at 10:44 AM
    king.cong.1119
    king.cong.1119 New Member
    I didn't have factory remote start, installed the 12vsolution remote start and love it.
  16. Nov 11, 2022 at 3:45 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    I'm dying here. :rofl:
  17. Nov 11, 2022 at 3:47 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    I miss having a key :( I know I'm not alone. '18 Didn't shut off, was able to start my truck from the passenger seat ... etc.
  18. Nov 11, 2022 at 4:08 AM
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    All the Toyotas we have either factory or aftermarket will turn off when the door is opened. It's really not much hassle to reach over and press the start button. It's not as if all the heat escapes when the door is opened.
    Is it inconvenient, sure, but barely.
    Doxiedad likes this.
  19. Nov 11, 2022 at 4:27 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    Tundra Owner: Slightest inconvenience
    Non-Toyota Owner: Gotta have your backups
  20. Nov 11, 2022 at 7:13 AM
    #50
    Gort
    Gort New Member
    Canada
    2020 Tundra SR5+
    My thing, and maybe its slightly OCD, is that I don't like starting the engine again and putting more stress on components if I don't need to.
  21. Nov 11, 2022 at 7:29 AM
    #51
    DerfM
    South Dakota
    2021 TRD Pro MBM
    :shrug; Starters are built way better than the old days.
    Doxiedad, Gort[QUOTED] and GODZILLA like this.
  22. Nov 12, 2022 at 7:50 AM
    #52
    Big_Ed
    Big_Ed New Member
    Spring, Tx
    2016 Tundra
    At least the Tundra doesn't shut itself off and restart every time you stop at a stop sign. Well, my 2016 doesnt.
    splitfuse, Mike59 and Gort[QUOTED] like this.
  23. Nov 13, 2022 at 6:24 AM
    #53
    Geezer
    Geezer New Member
    Heart of the Catskills
    2019 Tundra Limited
    When I bought my EVO ONE it was already programmed but there was a programming device available for someone who wanted to change something. I believe it is called 'flashlink', but I may not remember it correctly.
  24. Nov 13, 2022 at 7:28 AM
    #54
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Is it the same platform the Maestro uses?
  25. Dec 30, 2022 at 8:30 AM
    #55
    splitfuse
    splitfuse Dr. Tundra
    AB-CAN
    2020 Cement Tundra Crew TRD
    I can appreciate the security concern, but if this was the design intent, why would they allow a push-button started truck to drive away without the key fob being in range! What a security threat with zero use-case to justify! This is probably my biggest design beef with the whole truck.
    Truck should have been designed to shutoff when brake pedal is pressed, before coming out of park, when the key is not within range. This would address theft of a truck that was started either remotely or push-button. Would also have been nice to allow the doors to lock (from the fob) with the truck running to protect against theft of contents. I'm not sure what Toyota's official explanation is for the curent design, but IMO this looks like poor design logic hiding behind some sort of myth or fabricated reason. This functionality is commonplace with aftermarket remote starters, so it is surely technical feasible.
    TheMuffinMan likes this.
  26. Dec 30, 2022 at 8:51 AM
    #56
    18" TRD Off Road Wheels
    It shuts off for those as well. From Toyota's official site.
    Notice that it looks like they are starting to allow remote connect starts and then driving on select 2023 models. It's the typical slow roll of Toyota. They don't implement new stuff until they think they have it working, and even then it's only select models until it's proven. Look how long it took for push button start and the smart handles to make it to the Tundra vs other Toyota models. This isn't a new pattern, and we just have to be patient. Especially when this is such a minimal issue.
    OhEmmBee likes this.
  27. Dec 30, 2022 at 9:00 AM
    #57
    splitfuse
    AB-CAN
    I'm a big supporter of Toyota's conservative approach to design but gosh, this is pretty basic. Nice to see the design has evolved in the 2023s. It seems like a petty design issue in the gen 2.5s until you live in a cold climate and start your truck to warm up nearly 6 months of the year. Something to either live with or get an aftermarket starter. I'll probably do the later.
  28. Dec 30, 2022 at 9:11 AM
    #58
    My Tundra didn't have it at all and we get plenty cold, so I'm stoked to have it in the Taco. I don't mind restarting it. I don't mind the low quality cameras either, because I never had better ones in anything I've owned so I'm just tickled to have it at all.
    charlieyankee88 and texasrho83 like this.
  29. Dec 30, 2022 at 9:18 AM
    #59
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Cause signals coming from your keyfob RFID transmitter chip can be easily replicated. There are systems out there that can trace and copy signature or unique RFID signals similar to like how people get a hold on credit card info until the chipped cards came out somewhat. If they were to catch 2 of your signals from a your fob, it's really easy just hop in and drive off. Whereas if the vehicle is designed to shut off, It now requires a additional starting signal from the fob that communicates to your anti-theft system built in. The transmitter is designed to do 4 signals like normally it is supposed to. You need the following signals to go through just like any other person driving. Locked mode, accessory mode, On mode and Start/Ignition mode.
    If you had a H-key to start it's about the same thing without the vehicle turning off due to the ignition needing to be set to on.
    If this doesn't make any sense just be glad you don't have a manual where it gets trickier or impossible. Same goes for Diesel.
  30. Dec 30, 2022 at 11:03 AM
    #60
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    My wife always wanted a remote start and I installed the Toyota OEM on her 2017 Camry. She hates that she has to push the button again after she opens the door. Really? It's a button! You push it and boom, the car starts. She won't use it. I have been married to her for 40 years and I still don't understand her.
