  1. Nov 7, 2022 at 6:46 AM
    I used a 14" flex 3/8" ratchet but I always buy new plugs/gaskets every time I do it since it's a 10mm hex. It wasn't a lot of effort to get it off and fortunately, my diff leak is all over the drain plug, so I think that'll come out easily. :fingerscrossed:
    oscardog86[QUOTED] likes this.
  2. Nov 7, 2022 at 7:36 AM
    oscardog86
    oscardog86 New Member
    Southern California
    So in that gasket kit, the front diff has 2 different size gaskets. A large copper one for the drain plug and a smaller gasket for the fill plug. Looking at my front diff yesterday, it looks like they are both 10mm hex plugs that are the same size. Is this because I have a V6 Manual Transmission or are your guys plugs the same? Kinda confused now and wondering if I need to get different gaskets for my set up. Thanks!
  3. Nov 7, 2022 at 7:41 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The drain plug uses the larger gasket. The Allen is the same size. But the plug is larger
  4. Nov 7, 2022 at 7:46 AM
    So, basically, if buying the Lex drain plug, get the Lex drain gasket?
    bfunke likes this.
  5. Nov 7, 2022 at 7:55 AM
    empty_lord
    05 rollover special
    Ehh I don’t see why. The copper gasket from the tundra would work too
    NUDRAT and shifty`[QUOTED] like this.
  6. Nov 7, 2022 at 8:10 AM
    oscardog86
    Southern California
  7. Nov 7, 2022 at 12:35 PM
    The gaskets for the IS350 (11-2013) and 1st gen Tundra front diffs were exactly the same part number. I researched it a few days ago at the Lexus dealer site.
  8. Nov 7, 2022 at 12:50 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    point me in that direction. 3.19:1 !!! Gimme a good excuse to turn my truck into a 2v.
  9. Nov 7, 2022 at 2:59 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    So I did this Saturday. Fuel Vector gunmetal. 17x9 -12. Falken Wildpeaks 275/70/17. It took 2 trips and several hours at America's Tire because, according to their info, they would rub the upper control arms. I took them home and tried one out and it was about 5/16" farther from the spindle. Also Tire Rack showed them as the correct fitment. I can't stop admiring them. Bilstein 6112/5160. Wheeler's Off-Road AAL.
  10. Nov 7, 2022 at 5:44 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Agreed, all those things could have happened. The wheel gap on driver side is off by inch compared to passenger side.
  11. Nov 7, 2022 at 11:48 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Welp. Just went back and realized the numbers they gave are the same for caster amd camber despite the adjusters obviously being moved (as seen in your pics).
    Both rear adjusters are maxed outwards (which is also where I start) but if your an inch off on fender gap there could be more done (or wrong). Tough for me to say what over the internet though (body, frame, bushings, etc.).
    That said your passenger front adjuster is max inwards but the drivers is about 2/3 to 3/4 adjusted outwards. Which would swing the drivers wheel further back towards the cab and away from the bumper.
  12. Nov 8, 2022 at 10:43 AM
    Bought some upgraded Lexus plugs and gaskets for the gear oil change. Always convenient when the Lexus and Toyota dealerships are next to each other under the same ownership.
    I did a comparison of the originals to the new Lexus replacement parts and they match for plug size and thread pitch. The only real difference is that the depth of these plugs are anywhere from 1/2-3/4 the size of the original plugs which shouldn't be an issue.
    sn_85, oscardog86 and Kimosabe like this.
  13. Nov 8, 2022 at 11:54 AM
    oscardog86
    Southern California
    Are these new plugs for the front diff? Might be nice having those versus the 10mm hex version thats stock. I like your thinking!
  14. Nov 8, 2022 at 11:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Towed a Nissan on a Uhaul car dolly today with crackie. Had to put my old throttle position sensor back in on the side of the road.
    That V8 just kept revving, and revving, and revving...
    shifty` and richsadams like this.
  15. Nov 8, 2022 at 12:46 PM
    Yep, front diff only. Cost me $23 with tax at the Lexus dealership.
  16. Nov 8, 2022 at 1:12 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    While its open did you check if the vent tube flows?
  17. Nov 8, 2022 at 1:28 PM
    Independent throttle bodies are the answer. Actually, I don’t really know, but those things are awesome.
  18. Nov 8, 2022 at 1:33 PM
    bfunke
    bfunke Tundra Curmudgeon
    @Jack McCarthy - please post the part numbers for plugs and crush washer set
  19. Nov 8, 2022 at 1:46 PM
    The plugs are in that last post, but here they are again:
    Lexus fill plug: 90341-18060
    Lexus drain plug: 90341-24016
    The gaskets are as follows:
    Front diff fill: 12157-10010
    Front diff drain: 90430-24017
    Transfer case fill: 90430-18008 (90430-A0003)
    Transfer case drain: 90430-18008 (90430-A0003)
    Rear diff fill: 12157-10010
    Rear diff drain: 12157-10010
    Note: The transfer case gaskets are really just washers and can probably be reused. They don’t appear to compress.
    bfunke[QUOTED] and oscardog86 like this.
  20. Nov 8, 2022 at 3:48 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Looks good! As long as the backspacing is the same as previous wheels or less it shouldn't rub correct?
    I just called DT yesterday to check what removal/install on new wheels would be and asked if I could request they not use an impact on my new wheels. The guy on the phone told me "they kinda have to after hand tightening the first few threads"? lol. I think I think some of this boils down to the person you get that day. Wheels and rubber look great again.
    oscardog86 likes this.
  21. Nov 8, 2022 at 3:52 PM
    SoCalPaul
    Paul
    I get a slight rub on a rectangular plastic bump on the inside mounting area of the mudflap as the outside edge of the tire passes it while turning. I'm going to try using a heat gun on it to see if I can gain some clearance.
  22. Nov 9, 2022 at 6:16 AM
    oscardog86
    Southern California
    Yea I requested the guys at americas tire dont impact my lug nuts down either. I requested 83 ftlbs or so and he said they would hand torque them. I sat and watched and sure enough, they did!
    NUDRAT and Mr.bee like this.
  23. Nov 9, 2022 at 6:21 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    I only take loose wheels to keep em from stabbing at the lugs like a drunk kid on prom night. The toyota dealer scuffed all the holes on grandpas truck and loosened 3 of his center caps and broke the 4th, which they didnt have in stock.
  24. Nov 9, 2022 at 7:56 AM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    I'd reach out to the sender with photos and tell them that their packaging isn't acceptable with how much money you paid for their gear.
  25. Nov 9, 2022 at 8:16 AM
    "But we put a Fragile sticker on it! It's the carrier's fault, they didn't read the sticker!!"
    CodyP likes this.
  26. Nov 9, 2022 at 12:29 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Ya, I think the blame game would go round and round. Plus, the parts have been mounted for over a month now and are doing great so far.
    shifty`[QUOTED] likes this.
  27. Nov 9, 2022 at 1:43 PM
    I found a can of CRC MAF cleaner in the garage while cleaning out the garage today, and I figure my MAF has probably never been cleaned before, so I went ahead and popped it out to clean it. Will be interesting to see if there's any noticeable idle, performance, mpg gains. I have no doubt it probably had a good 15 years of filth built up on it. Emptied about 1/3 can at it, waiting to warm up and dry out now so I can fire it up.
  28. Nov 9, 2022 at 2:24 PM
    Holy crap the throttle is sensitive now! I was bitching to @912 a while back about how I dunno how the hell he can just burn rubber from a dead standstill, my truck is finally behaving a little more like that. Really surprised, never seen very much difference doing this on other vehicles. Maybe it'll tame back down after the engine re-calibrates. (hope not)
    912, oscardog86, bmf4069 and 7 others like this.
  29. Nov 9, 2022 at 2:25 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Or once it gets dirty again... lol
    bmf4069, abcinv, shifty` and 2 others like this.
  30. Nov 9, 2022 at 4:58 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Mounted some adjustable clevices in the front today. Putting limit straps up there.8D67F3C3-13B0-42D3-96AD-94CE6061C29C.jpg
    oscardog86, Mr.bee, bmf4069 and 4 others like this.
