Has anyone done an auto up window mod?
Discussion in '2nd Gen Tundras (2007-2013)' started by nuclearlemon, Jul 20, 2017.
  1. Jul 20, 2017 at 9:12 PM
    nuclearlemon
    nuclearlemon [OP] New Member
    wyoming
    2012 dc
    in the land cruiser world, some elmer figured out what size resistor needed to get soldered where to make the drivers window auto up in addition to the factory auto down. now i'm spoiled
    has anyone figure this out for 2nd gen tundras?
  2. Jul 21, 2017 at 9:23 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Nope. The last that I've read is that it necessitates having an entirely different electric regulator swapped in from a vehicle with that function coming standard. Probably prohibitively expensive unless one has a donor vehicle, or you're really quick in the Walmart parking lot.
    Y0TA PR0 and blizz86 like this.
  3. Jul 21, 2017 at 9:41 AM
    PMG
    PMG New Member
  4. Jul 21, 2017 at 9:42 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  5. Jul 21, 2017 at 12:18 PM
    nuclearlemon
    wyoming
    2012 dc
    replied in that thread too. when someone mentioned there's had auto up/down, i did a little digging and found pn 84820-0c040 for a USK56L-CRTLGA shows to be auto up/auto down. would be interesting to know if it's a plug and play or if there is any weird programming involved.
  6. Jul 21, 2017 at 1:15 PM
    MatthewPTguy
    MatthewPTguy Not a new member
    Eugene, Oregon
    2017 Tundra 5.7 DC TRD MGM
    Borla dual cat back exhaust system, K&N replacement air filter, Headlight Revolution 40" Stealth LED light bar, Headlight Revolution LED fog light replacement bulbs, Line X bed liner, de-badge
    No... but I think it's stupid it's not a standard feature.... drives me crazy!
    Derf77, TundraTss, Krezz and 4 others like this.
  7. Jul 21, 2017 at 2:42 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It isn't, different regulator....
  8. Jul 21, 2017 at 8:56 PM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I modded my driver's side window for auto-up by adding a Modual I bought from 'The Hoffman Group' in their 'Auto-Loc' section on their website. Wires in the panel are spiderweb-thin, so it's not the easiest mod I've done.Been working fine for several years,my truck's a 2010.
    Wynnded likes this.
  9. Jul 22, 2017 at 4:07 PM
    nuclearlemon
    wyoming
    2012 dc
    that doesn't make sense. the regulator is just linkage.
  10. Jul 22, 2017 at 4:59 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sorry for being so vague, d'oh.
    If memory serves....there's a different motor and an additional ECU involved. I suspect it's in part to facilitate the ability of the more upscale trims, like the Limiteds, Sequoias, and Land Cruisers to have the ability to roll up/down open/close all the windows/sunroofs with the fob or via the driver's door lock. There are a couple of ways that the smart folks have worked around to get some of the same or similar functions, but it is definitely not just a matter of changing out the switch in the door panel with one from a vehicle that had these functions from the factory. Sorry I don't have the fine details on how to go about doing the mod, I have a Regular Cab and it's my first vehicle with power windows and A/C, so I've been content with what I have. :)
  11. Jul 22, 2017 at 5:27 PM
    nuclearlemon
    wyoming
    2012 dc
    thanks for the clarification...bummer it's not a simple solution like my land cruiser
    Wynnded[QUOTED] likes this.
  12. Jul 27, 2017 at 8:42 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    My Corolla S has the auto up. Maybe I can rob it all out of it and through it in the Tundra??
  13. Oct 18, 2017 at 1:00 PM
    Dougthebeast
    Dougthebeast GTF out of my way!
    Doug
    Newnan GA
    2008 Tundra TRD DC Sapphire Blue
    Yeah, miss that from my old Acura TL. Great feature
  14. Oct 18, 2017 at 1:23 PM
    Theonlyway
    Theonlyway New Member
    User
    autoloc?
  15. Oct 19, 2017 at 12:55 PM
    nuclearlemon
    wyoming
    2012 dc
    no, auto up/auto down on window. some have it, some don't. i don't. :(
  16. Oct 19, 2017 at 1:27 PM
    CMB
    CMB New Member
    Cecil County MD.
    Do a search on the computer machine for 'Autoloc.com',when you scroll down, you'll see what you're looking for.
  17. Oct 19, 2017 at 3:28 PM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    What is this new fangled device you speak of?
    831Tun and nuclearlemon[OP] like this.
  18. Oct 19, 2017 at 5:01 PM
    Theonlyway
    User
  19. Oct 21, 2017 at 2:40 PM
    badams1897
    badams1897 New Member
    Bobby
    2013 Tundra Black Limited with Canyon Red Interior
    3.5" Level Kit in Front and 2" in back. MB TKOs 285/65/20 BFG KO2 ATs
    I once heard and I cannot back this up someone took a toyota highlander one and retro fit into Tundra
    nuclearlemon[OP] likes this.
  20. Oct 27, 2017 at 3:36 AM
    Dougthebeast
    Doug
    Newnan GA
    So, this is not the simple plug and play that the description says? Do you have more details on what you did to make it work.... Very interested in doing this
  21. Oct 27, 2017 at 10:09 AM
    CMB
    CMB New Member
    Cecil County MD.
    Not "plug&play" but it isn't very tough. Toyota's 'spiderweb-thin', wires don't make it any easier. I brought my 12 volts from the battery, instead of looking for one like the instructions say.
    r1-superstar likes this.
  22. Jun 27, 2018 at 9:30 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Quoting you so I can find this thread easier. Thanks for the info.
