Installing heated seats
Discussion in '2nd Gen Tundras (2007-2013)' started by TundraTRD08, Oct 19, 2021.
  1. Oct 19, 2021 at 7:55 AM
    TundraTRD08
    TundraTRD08 [OP] Somehow I fit 37s on a level
    Wesley
    08 Super White TRD Off-Road on 37s
    3.5' RC lifted struts with RC UCA Alcan rear leaf spring upgrade with 300lbs added weight+1" lift built in. Adjustable Alcan Shackles set to add an extra inch which equals to a 2" lift in the rear. 37” Maxxis RAZR M/Ts with 1.5” spacers 8” BAMuffler Tuned by Bully Dog Tuner
    Hey y’all! I was wanting to know if I could wire up some heated seats in a 2008 that does currently not. It’s an sr5 with leather seats with no seat heaters as of now. I know a lot of things are pre wired into these trucks like lights, mirror workings, and trailer brake controllers to name a few. Therefore I was wanting to know if these were too. Any help?
  2. Oct 19, 2021 at 8:33 AM
    socaldiablo
    socaldiablo New Member
    Carlsbad, CA
    2013 White Tundra SR5 Rock Warrior
    Leer camper shell, slight lift kit, TRD Pro BBS wheels
    I have an SR5 that did not have heated seats from the factory but the previous owner installed heated seats. Not sure if they are pre-wired for this but it can be done.
    TundraTRD08[OP] likes this.
  3. Oct 19, 2021 at 11:27 AM
    azimuth
    azimuth New Member
    2010 double cab SR5
    I did it with a kit I bought online. Took about 4 hours and a Dr Pepper. So far they work great and except for one nearly insignificant detail the switches look and perform like OE. Total cost was around 115.00
    Filthyphil and TundraTRD08[OP] like this.
  4. Oct 19, 2021 at 11:28 AM
    1794TX
    Steven
    N.TX
    '20 1794
  5. Oct 19, 2021 at 2:14 PM
    TundraTRD08
    Wesley
    Thank all y’all!
    1794TX likes this.
  6. Oct 19, 2021 at 2:17 PM
    TundraTRD08
    Wesley
    Do you by chance have a link to this kit? Just want to be sure that the one I get works correctly. Also, I love the Dr Pepper part:drunk:
  7. Oct 19, 2021 at 4:55 PM
    azimuth
    azimuth New Member
    2010 double cab SR5
    This is the one. I bought mine on a different site but it is not available there right now. This is the kit I bought though. Looks like you'll save money. Mine was 20.00 more before shipping/tax https://www.ebay.com/itm/173119731051
  8. Oct 19, 2021 at 5:13 PM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Pretty sure I have identical kit and it works great 2 years later.
  9. Oct 19, 2021 at 8:20 PM
    TundraTRD08
    Wesley
    Thank y’all again!
  10. Nov 18, 2021 at 7:57 AM
    TundraTRD08
    Wesley
    Nuther question, do I need to get new seats to do this? My leather seats are kinda rough looking and thinking about seeing if I could get some 1794 seats. However, if I absolutely needed to put them in the old seats how would I do that? Do I need to take the leather off or what? Video or instructions would be helpful.
  11. Nov 18, 2021 at 9:38 AM
    surffj62
    surffj62 New Member
    2011 DBL RW
    I process of doing seats- I have cloth in pretty good shape that don’t want to take apart. The pads have a really sticky tape that I’m putting directly on the fabric and then covering the seats with the wet okole seat covers.
    From my perspective - these are made in China and if one fails, I don’t want to have to redo the tear apart and install process over. Plus I like the wet okoles. The switch for the temp has already failed and is being replaced - ugh China parts.
    For the wiring the harness -I joined the 2 power wires (each has a 15a fuse) wired them to a add a fuse to the “power seats” slot (30a) in kick panel. IIRC - For the “on- off” I did the same but put them on the “sun roof” slot because it is off accessory side-
    Okoles should be here in a week or so.
  12. Nov 18, 2021 at 1:26 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    Maybe this video might help:
  13. Nov 7, 2022 at 7:17 PM
    ChrisLopez
    ChrisLopez New Member
    Christian
    Chicago,Illinois
    2018 Tundra SR5 TRD off road Crew max
    I purchased this kit for my 18 tundra and I’m a little confused with my wiring. Kit came with black ground, yellow, red and another red with a 15amp fuse to connect to battery. How should I do this wiring?
