Maestro iDatalink + Aftermarket HU Dimmer
Discussion in 'Electrical' started by Tbrandt, Aug 9, 2022.
  1. Aug 9, 2022 at 8:27 AM
    Tbrandt
    Tbrandt [OP] I read it on an internet forum, it must be true.
    Tristan
    Kansas City
    2021 SR5 DC TRD Off-Road
    Kenwood DMX907S + Maestro iDatalink RR2 Kenwood DRV-N520 dash cam Kicker Door Speakers TRD rear sway bar Firestone airbags + Daystar cradles Setrab oil cooler, OEM thermostat and hard lines Century High-C topper Bedrug Helmholtz resonator on stock exhaust Sound deadened + insulated cab Platinum 20s, hwy tires Viair 400P
    For anyone with a Maestro iDatalink RR2 and an aftermarket HU - does your OEM dash dimmer also adjust the brightness of the display on your head unit? Mine does not with my Kenwood and I wish it did.
  2. Aug 9, 2022 at 8:35 AM
    The dash dimmer does not dim the radio, but the radio should dim when you turn the parking lights on. If it does not dim at all, then the dimmer wire is not connected or connected to the wrong wire.
    texasrho83 and 1lowlife like this.
  3. Aug 10, 2022 at 7:40 AM
    Tbrandt
    Tristan
    Kansas City
    The radio does dim when the lights come on, but it's so little it's barely noticeable and still uncomfortably bright when driving at night. Maybe it's a Kenwood thing, I found the dimmer control options in the display menu but nothing to adjust brightness. Gotta be a way, I'm probably just not finding it yet.
  4. Aug 10, 2022 at 8:15 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My Kenwood is the same way.
    There are adjustments, that you found, for the dimmers, but there are only like 4 brighter and 4 dimmer levels.
    Even on the lowest dimmest setting, it is still pretty bright.
    One of the few advantages of the Pioneer HUs is more control over stuff like that.
    They have way more adjustments for colors, brightness, screen layout, etc.
    But the Pioneer screen lag sucks and the screen layout is too animated for me...
    omgboost likes this.
  5. Aug 10, 2022 at 8:29 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I just went and looked at mine.
    It has a fixed screen, but there is a viewing angle setting, which might help.
    Also when you are choosing the dimmer selection, there are separate backlight settings for the parking lights on and the parking off.
    It's the same setting, but it retains selections separately.
    So, adjust with the lights on at night and adjust with them off during the daylight.
    I hope that makes sense..
    TRDFerguson likes this.
  6. Aug 10, 2022 at 8:39 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Thanks! This has been driving me nuts.
    1lowlife[QUOTED] likes this.
  7. Aug 10, 2022 at 5:59 PM
    Tbrandt
    Tristan
    Kansas City
    That was exactly what I needed. Had to access the brightness setting by clicking the “Menu” button then the settings icon that pops up in the upper left corner of the screen. Set the brightness with the lights on and then again with the lights off. Perfect.
  8. Nov 7, 2022 at 4:52 AM
    Dimming adjustments were a PITA for me. I have the Pioneer 7600 in my 2020. I adjusted the brightness with the lights on and off. The problem that I had was if using the lights during the day, the screen was too dark. Pioneer has a manual dim button in the app section. I added that to my home screen so all I have to do is turn it on if its too dark during the day, and it doesnt affect the day/night settings.
  9. Nov 7, 2022 at 5:27 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I don't have any issues with either the Kenwood or Pioneer being too bright or dim. I noticed the dimmer setting but didn't fiddle with it. I have noticed the Pioneer's lighting changes with the parking light engagement.
