Bent my rail brackets.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, Nov 6, 2022.
  1. Nov 6, 2022 at 4:20 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    Used the truck bed to bring home a giant freezer standing up right in the bed. We secured it down to the rails with my 3300 lb. ratchet straps. My mistake. I should have used the metal loops mounted into the four corner of the bed. Way stronger. And the rails are clearly not designed for such large loads. Lesson learned. I’m a truck noob, what can I say.
    So…time to replace the brackets to the rails. I may be able to bend them back but may just replace them if I can get something stronger. They appear to just be made out of aluminum. I would think a hardier metal like steel might not stay mounted to the side walls very well.
    What are my options? Best to just replace with like aluminum mounting brackets? Or is there something better/stronger/more capable I can get?
    Pretty sure these are just OEM rails. 91B16BB9-E242-4A49-8B2B-269E2319FD4E.jpg
    TTund16 likes this.
  2. Nov 6, 2022 at 4:24 PM
    NoRcptn
    NorCal
    2017 Platinum
    Granted the corner tie downs are stronger , however I've never seen bedrails mounted like that.
    Do you have a retrax cover on there?
    Sierradevil and Saltyhero13 like this.
  3. Nov 6, 2022 at 4:28 PM
    That is a rail drop down kit made by BAK. The kit is required for certain bed covers. The kit is made of aluminum. There are supposed to be 4 on each side. Either your truck didn't have all of them installed or they could have been made by a previous owner. You can probably have some made from steel.
    Edit....it may be 6 on each side depending in if the truck is a Crew Max or DC.
  4. Nov 6, 2022 at 4:29 PM
    Shadowfax1
    I have a Bakflip MX4. I didn’t pay any attention to how the rails were mounted before or after the Bakflip install, which was almost immediately after I bought the truck. How are they supposed to be mounted???
  5. Nov 6, 2022 at 4:32 PM
    NoRcptn
    NorCal
    2017 Platinum
    Ahh. Makes sense.
  6. Nov 6, 2022 at 4:35 PM
    RobertD
    Robert
    DFW, Texas
    I have a crewmax and this is how mine were installed (driver side is the same).
    Shadowfax1[OP] likes this.
  7. Nov 6, 2022 at 4:38 PM
    Basically it's one of the plates at every screw location where the rail mounts to the bed.
  8. Nov 7, 2022 at 5:14 AM
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    Those could be straightened with a bench vise and some brute force :militarypress:
  9. Nov 7, 2022 at 5:28 AM
    From the factory location, these cleats are rated for ~200 lbs if I remember correctly. I’m sure with these aluminum drop brackets it’s much lower now.
  10. Nov 7, 2022 at 7:36 AM
    Beach Toy
    Beach Toy New Member
    SE NC
    2017 White SR5 4x4
    Lomax cover, TRD PRO headlight conversion...so far anyway
    D5101000-D543-43F8-AF93-CC0D770B9368.jpg I have a BAK revolver and these are what my drop brackets look like. 5 per side on a CM.
  11. Nov 7, 2022 at 7:41 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I have an Undercover Flex and it uses the OEM rail location..:eek2:
    EarlyRiser and Shadowfax1[OP] like this.
  12. Nov 15, 2022 at 9:01 AM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    I tried to order the brackets from Undercover for my Bakflip and they would not sell them to me. I use my rails and want them bolted to the body, so I ended up removing the drop brackets and just putting the clamps directly to the bed lips
    Shadowfax1[OP] and 1lowlife like this.
  13. Nov 15, 2022 at 10:23 AM
    TTund16
    TTund16 New Member
    which factory is that? Mine came with the cleats and sprayed bed liner from Toyota. Curious if it was from the factory or dealer did that and is it 200 lbs also? My bed liner and cleats look too good to be from the dealer but who knows. lol
    if it's only 200lbs, OP should be able to easily fix his like @Coastboater said.
  14. Nov 17, 2022 at 2:55 PM
    Shadowfax1
    do you have a photo you can share?
  15. Nov 17, 2022 at 5:08 PM
    biebs96
    PA
    The cover my old man bought had the same drop down brackets.
    he opted for ditching the tie down rails and sold them.
    just another thought if you aren’t happy with others suggestions.
