Vents not working
Discussion in '2.5 Gen Tundras (2014-2021)' started by Neicher, Nov 6, 2022.
  1. Nov 6, 2022 at 4:50 AM
    Neicher
    Neicher [OP] New Member
    2016 Toyota Tundra sr5
    The vents to defrost and floor are not working it’s stuck on the face vent what could it be
  2. Nov 6, 2022 at 5:49 AM
    Blend door/actuator.
    Neicher[OP] likes this.
  3. Nov 6, 2022 at 6:05 AM
    Neicher
    How do u fix that
  4. Nov 6, 2022 at 6:11 AM
    I wouldn’t take it to the dealership. Heard some huge repair bills from that route.
    Private shop could be around 7-800.00 to fix.
  5. Nov 6, 2022 at 6:47 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    I replaced the one deep inside the dash of my old 03 Silverado. A pain because I had to rip the whole dash out to get to it.
    The one on my wife’s 01 4Runner was easy. Ten minutes tops. After two years of a whining noise coming from under the passengers side dash, I took it to stealer. They said it wasn’t the actuator but rather the blower motor ($$$$). I knew that wasn’t right because the noise continued even with fan/ac/heat turned off. I played with the controls an saw that nothing changed and I was not getting heat. I was lucky enough to find a comparable actuator and swapped it out. Three screws and a wiring plug later no noise and plenty of heat when I need it.
    If you’re handy go for it.
  6. Nov 6, 2022 at 7:04 AM
    Neicher
    Thank you guys I’ll try this
  7. Nov 6, 2022 at 7:21 AM
    I coworker recently had the Yota dealer replace his. $1400! He tried to do it himself but gave up after wasting a weekend. Dang.....
  8. Nov 6, 2022 at 7:28 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum..
    Please let us know what you end up doing so others can learn..:cool:
