  1. Nov 5, 2022 at 12:47 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Spray some white lithium into the side latches. That makes it open like butter.
    Yeah, aren't those the same ones from the other side?
    If you look forward from that angle you should see the backside of the front bolts.
    Lug nut sockets are made in that size for the rust belt.
  2. Nov 5, 2022 at 12:52 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
    Yea I thought I sent those pics yesterday. The front and back.
  3. Nov 5, 2022 at 12:57 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    My bad, here's front.
  4. Nov 5, 2022 at 1:15 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yeah. I'm thinking unless your frame is fubar the wheels slipped when he did the caster swing.
  5. Nov 5, 2022 at 1:40 PM
    Casper421
    In the woods
    06 DC
  6. Nov 5, 2022 at 1:42 PM
    After doing some research on Lexus fill/drain plugs using the same fill/drain plug gaskets we use for the front differential, I decide to call around to see who had the following items in stock:
    Lexus fill plug part no. 90341-18060
    Lexus/Toyota fill plug gasket part no. 12157-10010
    Lexus drain plug part no. 90341-24016
    Lexus/Toyota drain plug gasket part no. 90430-24017
    Unfortunately, all of them seem to close around 4 pm today.
    des2mtn likes this.
  7. Nov 5, 2022 at 3:23 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    I bet Gerald understood that reference.
  8. Nov 5, 2022 at 5:17 PM
    Does anyone recall if there are gaskets required for the fill and drain plugs on the transfer case and rear differential?
    I know there are for the front differential. I just can’t recall if they exist for the others. Common sense would say yes, IMO.
    oscardog86 and KingSequioa007 like this.
  9. Nov 5, 2022 at 5:20 PM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Yes to both. I bought this, https://www.amazon.com/gp/product/B07DFJ24WD?ie=UTF8
    but the description says 2x 12157-10010 for the rear diff and 2x 90430-18008 for the t-case are the OEM part numbers.
  10. Nov 5, 2022 at 5:31 PM
  11. Nov 5, 2022 at 8:29 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    used it to go pick up my deeply discounted frame swap parts for the 1998.
    replacement kits, brake lines, leaf springs, upper arms, lower arms, ball joints, body mounts, front springs, shock mounts, etc. i wasnt going to do all this.. but my boy hooked me up for helping him with his sisters car. total cost to me was... pennies compared to list.. and most of the expensive stuff isnt here yet. be trickling in over the week.. just need to order new 4600s and wait for the frame. then the 1998 will rock again.
    [​IMG] [​IMG][​IMG]
    oscardog86, bmf4069, NUDRAT and 11 others like this.
  12. Nov 6, 2022 at 6:29 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    The frame is good. Never had the Caster issue until i installed the lift. I really doubt the tech slipped on the Caster swing. These guys are the best in my area hands down. Maybe even best in the county.
  13. Nov 6, 2022 at 6:32 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Rear diff yes. Both fill and drain.
  14. Nov 6, 2022 at 9:02 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    Lookout Mtn Georgia
    Popped on my >$300 NFab bars. She's about to get a bath so just this pic for now..
    The wife is happy so all is good in the world!
  15. Nov 6, 2022 at 11:41 AM
    abcinv
    Tommy
    Lookout Mtn Georgia
    Cleaned up a bit (need to hit the mirror arms with a little flat black paint), good shot of the nfab.11-06 with nerf 1.jpg
    Thoughts on the bars?
    Oh, I'll hit 77k tomorrow as I'm driving it to work before covering it up under the pole barn.
  16. Nov 6, 2022 at 12:06 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    The slip would happen due to the vehicle brakes not being held with enough pressure. This could be simply the pedal depressor not pushed hard enough, it being jostled when removing the steering wheel lock for turning the steering wheel, a slow bypass in the brake master cylinder, a leaking caliper/wheel cylinder, brake line, etc. Many reasons it could happen.
    2 3/4° different left and right is a huge amount. Most specs call for 1/2° split. If it's driving fine I'm leaning towards an unintended slip of the front brakes when doing a wheel sweep to measure caster.
    What's the wheel gap between the tire and rear of the fender like on both sides?
  17. Nov 6, 2022 at 12:41 PM
    sflips
    sflips New Member
    Middle Tn.
    2006 DC XSP
    Dang: I stumbled on this a week to late. When you open the door, how many inches from the bottom of the door to the top of the step?
    abcinv[QUOTED] likes this.
  18. Nov 6, 2022 at 1:37 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I have the 2 step version. They get slippery in the rain and will give you a nice bruise on your shin when you slip.
    They also rust quick. I'm on my 3rd warranty set but I'm guessing being in Georgia that won't be too big of an issue for you.
  19. Nov 6, 2022 at 1:41 PM
    abcinv
    Tommy
    Lookout Mtn Georgia
    I remember you sharing your issues / thoughts on these and if not for the great price I wouldn't have moved forward. I'm hoping rust won't be an issue but I did register the purchase for the warranty.
    Festerw[QUOTED] and FirstGenVol like this.
  20. Nov 6, 2022 at 2:25 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    pole barn got a paved/concrete floor? Parking covered over dirt super accelerates rust.
  21. Nov 6, 2022 at 2:33 PM
    abcinv
    Tommy
    Lookout Mtn Georgia
    No concrete but it still looks clean underneath. I thought gravel may be better but it may be just as bad...
    I haven't considered this before but parking on the driveway isn't an option. Guess I have some figuring out to do.
    Thanks for the heads up!
  22. Nov 6, 2022 at 2:34 PM
    Your Northern minds immediately go to rust. :D
    I really doubt @abcinv is going to have any issues.
    shifty` likes this.
  23. Nov 6, 2022 at 2:39 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Even down south you guys have moist in the ground.
    @abcinv lay a thick sheet of plastic on the ground, park on that. It'll stop the damp rising under the truck. Should be good.
    Tundra2 and abcinv like this.
  24. Nov 6, 2022 at 3:08 PM
    abcinv
    Tommy
    Lookout Mtn Georgia
    I've got some staples and a huge tarp that I can lay down. It'll drive the wife crazy; maybe she'll be more on board with me pouring concrete under there..
    bmf4069, shifty` and NUDRAT like this.
  25. Nov 6, 2022 at 4:58 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    way to tight. But, since you can get to those ones, not a big deal to run a flange nut or something, just slower on/off.
    5N0W808[QUOTED] likes this.
  26. Nov 6, 2022 at 4:59 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    I have the same set. You got a great price. Iirc I was closer to 500 when I bought mine. They are useful for the bed as long as you don't grab the bedside to pull yourself up. I think I read the box sides are sorta weak. I go step->tire ->in the box.
    Maybe spray some FF in the tube as they are new?
    I was gonna mention this. Glad I'm not the only one warranting these out every 6 mos to a year. I wash more than average in general and in winter also just to keep the crud off. Doesn't seem to matter.
  27. Nov 6, 2022 at 5:27 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    This was my 10,000th post.
    abcinv, oscardog86, bmf4069 and 2 others like this.
  28. Nov 6, 2022 at 6:36 PM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    w666 likes this.
  29. Nov 6, 2022 at 7:29 PM
    artsr2002
    'Yonder
    Dammit, I should've jumped on those while the price was low. They do look good.
  30. Nov 7, 2022 at 6:15 AM
    oscardog86
    oscardog86 New Member
    Southern California
    I ordered the same gasket kit as @des2mtn, worked great! Still gotta get the front diff drained and filled though. Had to get my skidrow skids off first to access the plugs. Do you guys use an impact on the hex bolts or just a breaker bar for those? Thanks!
    des2mtn likes this.
