TRD Pro suspension question
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Badge618, Oct 30, 2021.
  1. Oct 30, 2021 at 11:18 AM
    Badge618
    Badge618 [OP] New Member
    Lassen County, Ca
    2019 TRD Pro Voodoo Blue
    Looking at a 2019 TRD Pro at a dealership that is about 5 hours away so doing a lot of the work through emails and pictures. What type of setup does this look like? Stock TRD with spacer?IMG_4392.jpg
  2. Oct 30, 2021 at 12:10 PM
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Definitely a spacer and after market UCA. Maybe a Rough Country??
    Badge618[OP] likes this.
  3. Oct 30, 2021 at 12:55 PM
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    On the pro it would be the fox/trd setup, so maybe make sure a lower picture to verify the resi at the bottom. Other then that the red/trd coil looks like the stock pro coil, but that spacer and uca are not oem as stated already.
    Badge618[QUOTED][OP] likes this.
  4. Oct 30, 2021 at 1:30 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Official welcome... Does look like RC basic UCA
  5. Oct 30, 2021 at 1:51 PM
    Badge618
    Lassen County, Ca
    Thank you for the replies. Having them verify the Fox shocks and send me a picture.
  6. Oct 30, 2021 at 2:05 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Looks like the readylift plus 2 kit for the pros. Might be the fox pro suspension based on the black TRD logo on the coil. My bilstein pro suspension has the TRD in white on the coil. Could be either though.
  7. Oct 30, 2021 at 2:07 PM
    Badge618
    Lassen County, Ca
  8. Oct 30, 2021 at 2:10 PM
    Badge618
    Lassen County, Ca
    That looks like it. Thank you
    GODZILLA likes this.
  9. Oct 30, 2021 at 2:41 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    If you decide to buy it, I’d strongly consider removing that spacer and going with a Westcott Designs lift at the front…you are already up 2” in the front over stock tundras with the pro suspension. The collar lift Westcott uses is a better setup IMO, and is only a few hundred dollars. Will likely ride and last longer than that big aluminum spacer at the front. You can leave the rear alone assuming it is already leveled with the readylift kit
    https://westcottdesigns.net/product/fox-trd-pro-lift-kit/
    Toyotoholic likes this.
  10. Oct 30, 2021 at 5:15 PM
    Badge618
    Lassen County, Ca
    That would be the plan. Was already looking at that setup for the wife’s 2022 4Runner TRD
    1P7R9O4 likes this.
  11. Nov 1, 2022 at 7:48 PM
    Mark73
    Mark73 New Member
    MGM 2020 Tundra TRD PRO
    ReadyLift SST 2” plus 2 Lift Kit, Coach builder +3 shackles & drop kit, Nitto RG 295/70/18
    It’s definitely a ReadyLift SST +2” lift kit Trd Pro Tundra. I have same set up on 2020 Trd Pro Tundra. It drives like stock in my opinion. I eventually removed rear block and added +3 coach builder rear shackles which just improved the ride even more! No issues either way.
    Orangecrush and GarTX526 like this.
  12. Nov 5, 2022 at 9:47 AM
    Orangecrush
    Orangecrush New Member
    Shahzad
    2015 Tundra TRD Pro, Inferno Orange
    None
    @Mark73 what is your wheels & tires setup? And do i see a hidden running board on your truck :)
  13. Nov 5, 2022 at 11:39 AM
    Mark73
    Mark73 New Member
    My wheels are 18x8 TRD stock on 295/70/18 Nitto Ridge Grapplers. I removed front small mud flaps because they rubbed only in reverse. Amp Research powered step is what I have installed. Happy with ride and step is nice and convenient for my kids and wife.
    Orangecrush likes this.
  14. Nov 5, 2022 at 11:45 AM
    Mark73
    Mark73 New Member
    Updated pictures with Bora 1.25 spacers installed. Slightly rubs in reverse on rear mud flaps. I removed them and eliminated the rub but noticed bottom of truck got dirty quickly in rain or mud. Heated mud flaps with heat gun and rounded them down and removed edge. No rub now.
  15. Nov 5, 2022 at 11:52 AM
    18" TRD Off Road Wheels
    The thread is over a year old....
    Orangecrush[QUOTED] likes this.
  16. Nov 5, 2022 at 11:53 AM
    Mark73
    Mark73 New Member
    Here is the Amp Research step I have installed.
