Headlights staying on
Discussion in '1st Gen Tundras (2000-2006)' started by tyler-brown, Nov 1, 2022.
  1. Nov 1, 2022 at 8:25 PM
    tyler-brown
    tyler-brown [OP] New Member
    Canada, B.C.
    2001 AC Tundra V8 LTD 4x4
    5" tuff country lift 2.5" Eibach front coil overs SPC upper control arms 33x12.5's JBA long tubes Jba mid pipes Jba full exhaust & muffler Dirty deeds 12 hole injectors Front hitch receiver
    Hey guys,
    Loosing faith in my trusty Toyota. Had been so good for long. And now just being bombarded with problems recently with it.
    Neighbour came over and told me my four ways were on...I walk outside and see just my headlights are on. Check the switches. All off. Turn the lights on and off, turn the fourways on and off. Start the truck, turn it off, went for a quick 2 minute drive. Parked it. All lights were off. Perfect. Weird.
    45 minutes later I look out the window...just the headlights are back on. Too dark and getting to late to wanna mess with it, so pulled the left & right lamp fuses for the night.
    Where the heck to start?:confused::notsure:
    Never had this issue before. Do not have an alarm system or remote starter on this truck. (That I am aware of, they can be Sneaky hiding those boxes sometimes)
  2. Nov 1, 2022 at 8:29 PM
    evanhmn
    evanhmn mmm chicken pot pie
    State of Taxes
    2001 TRD Off-Road AC 4x4 Limited in Black
    5100/2885s, 1.5" Add-Leaf, BFF Front Bumper, 265/70/17 KO2s
    Do you have any additional lighting or anything hooked into the wiring of the headlights? Maybe any tinkering done with the fuses and such? Whenever I have had any electrical issues of those sorts I just unhook my ground terminal for 30 seconds and put it back on. Seems to "reset" anything electrical just like turning your wifi on and off.
  3. Nov 1, 2022 at 8:30 PM
    tyler-brown
    Canada, B.C.
    Nope, nothing tied into my headlights. Fog lights are still independent and so is light bar.
    Truck has had the battery unhooked for a week+ while I was waiting for my new starter. But good point.
    I could unhook it for what it's worth.
    Thanks.
    evanhmn[QUOTED] likes this.
  4. Nov 1, 2022 at 9:34 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Does your truck usually have day time running lights?
  5. Nov 2, 2022 at 5:36 AM
    I don't know if it's a feature of earlier models, but my '06 has courtesy lights where it leaves the headlights on for like 30 or 60 seconds after the truck is turned off, and the last door closes. I've noticed in other cars (not necessarily the truck yet) that those lights will say on if a single door is not fully closed. Doubt it's the case, just tossing it out.
    If I had to guess, I'd be suspicions a relay is dying on your truck. Virtually always, headlights and other higher-power devices which benefit from a more-direct-power-feed will have a relay nearby, so that more-direct-power-feed can be triggered on/off (open/closed) using a relay fed by a low-volt signal from another source (in this case, your headlight switch and/or the ECM/security system).
    I'd check the lid of your engine bay fuse/relay box to see if there's a headlight relay there. Or consult the EWD for your truck. In the future, if this persists, you can just pull that relay to get everything to die, also.
  6. Nov 2, 2022 at 7:28 AM
    tyler-brown
    Canada, B.C.
    Yes it does. As I was thinking about it last night, there was no tail lights. Only headlights. And only the lows (those were the fuses I pulled)
    Hmm, okay that sounds good. I'll give a look and try to find the head light/DRL relays and replace em.
    Thanks!
  7. Nov 2, 2022 at 7:40 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Maybe unplug the drl connector?
    NickB_01TRD likes this.
  8. Nov 2, 2022 at 8:36 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    The parking light/turn signal lights were stuck on on my v6 tundra once. I think the diode dynamics relay stuck on. I just pressed the hazard lights button once or twice. Been normal after that.
  9. Nov 2, 2022 at 8:54 AM
    tyler-brown
    Canada, B.C.
    :frusty:
    Probably completely unrelated but now it won't start
    I can hear the starter clicking and everything. Full charge. Had the battery maintainer plugged in, and checked it with a volt meter.
    Anyone wanna buy a first gen?
    I'm ready for a bigger cab with the bigger family anyways :rofl:
  10. Nov 2, 2022 at 8:56 AM
    Just pull the batt and run it to the store to be tested. Sounds like it's in the shitter, maybe not cell fail, but batt health is shit and not enough CCA. I've had it happen a couple of times before; having a full 12.4+ volts but almost zero CCA. Voltage is only one element of a healthy battery.
    Tundra2 likes this.
  11. Nov 2, 2022 at 9:37 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Jumper wires!
    red to red/black to black
    or whatever you wanna do, im not your dad.
    Tundra2 likes this.
  12. Nov 2, 2022 at 9:39 AM
    Mr.bee likes this.
  13. Nov 2, 2022 at 9:40 AM
    tyler-brown
    Canada, B.C.
    Good call. Sometimes I get frustrated & fed up and don't stop and think. I'll jump it off the dodge and see what happens.
    Hmm...sounds like something my real dad would say...
    Daddy?
    coldcanuk and Mr.bee[QUOTED] like this.
  14. Nov 2, 2022 at 9:49 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Before you pull your battery and run it somewhere, take the leads off and clean them. Many times it's corroded/bad connection, not the actual battery.
  15. Nov 2, 2022 at 10:21 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Can i get a @BubbaW wiring diagram of the integration relay/ headlight foglight circuit?
  16. Nov 2, 2022 at 11:27 AM
    tyler-brown
    Canada, B.C.
    Jumping it didn't work.
    I'm starting to think the clicking is just the relay. It may be a faulty starter that i just put in‍♂️
  17. Nov 2, 2022 at 11:29 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    You put a denso in right?
    shifty` likes this.
  18. Nov 2, 2022 at 11:30 AM
    Was it Denso brand starter, or other?
    If 'other', I wouldn't be the least bit surprised if you got a faulty one. If so, don't feel bad, you're not the 1st person to go non-Denso and get bitten in the ass.
    Still...
    https://www.youtube.com/watch?v=0jWouSQYTnU
    Tundra2 likes this.
  19. Nov 2, 2022 at 11:38 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    Did these issues coincide with rain? Maybe there’s a leak onto some of the relays or other electronics, I don’t know where to suggest looking since I’ve done no electrical work on these trucks, but others might have suggestions; glovebox area?
    Just a thought, not sure where you’re at in BC, but we just had the first good rains of the season around here.
  20. Nov 2, 2022 at 11:39 AM
    tyler-brown
    Canada, B.C.
    You sir.
    Were correct.
    I got the missus to turn the truck over so I could pin point where the clicking was coming from (was the starter) but there was little arcing happening on the positive cables. Pulled those off. Cleaned with a wire brush and sand paper. Started right up.
    Hopefully...the light gremlins don't come back now either.
    Ha
    hammeron, w666, Aerindel and 3 others like this.
  21. Nov 2, 2022 at 11:40 AM
    tyler-brown
    Canada, B.C.
    Nope, got the denso. Was a reman tho
    ($1150 canadian from Toyota, $280 reman denso shipped to my door from a similar site to rockauto)
    shifty`[QUOTED] and Tundra2 like this.
  22. Nov 2, 2022 at 11:49 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Now wash that truck and take a pic for your avatar. I respect the dirty, but you've gotta respect the truck
  23. Nov 2, 2022 at 11:51 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Now you should put some of this on your clean terminals. :thumbsup:
  24. Nov 2, 2022 at 11:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I put anti-sieze on my terminals. Not real sure if it's a good or a bad thing, but I haven't seen any corrosion yet.
  25. Nov 2, 2022 at 12:25 PM
    Ah, I remember this now. Sorry, so many threads, so few brain cells. :rofl:
    Di-electric grease user here, similar enough to anti-seize I guess. And felt washers around the base to catch offgass, curb corrosion.
  26. Nov 4, 2022 at 2:54 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Glad I could help and prevent an unneeded trip to an auto parts store. It's been a couple of days, any update on this? have you're light issues resolved?
  27. Nov 5, 2022 at 8:35 AM
    bfunke
    bfunke Tundra Curmudgeon
    I use a little grease and the red/green felt washers. OEM terminals seem to need cleaning periodically.
