O2 Sensors Cut
Discussion in '2.5 Gen Tundras (2014-2021)' started by BrutalBrando, Nov 5, 2022.
  1. Nov 5, 2022 at 8:33 AM
    BrutalBrando
    BrutalBrando [OP] New Member
    2019 Black TSS
    My check engine light came on and I took my truck in to find out why. Turns out someone attempted to steal my Catalytic Converter and cut my O2 sensors. Fortunately that’s as far as they got. I have no idea what I need to buy in order to replace them myself. Can anyone help me? There is one in front of the cat and 1 after. The dealership wants over $800 for parts and labor.
  2. Nov 5, 2022 at 8:55 AM
    There are a total of 4 sensors. The diagram shows #10 and #11 for the sensors. This link is for a 2019 SR5 with the 5.7. It should get you started.
    https://www.sparksparts.com/v-2019-...l-v8-gas/emission-system--emission-components
  3. Nov 5, 2022 at 8:56 AM
    You need to oder cat protection plates as well. If they tried once, they will be back.
    BrutalBrando[OP] likes this.
  4. Nov 5, 2022 at 9:34 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^This..
    All long as they cut it close to the sensor it shouldn't be that hard to replace.
    Seems to be a connector on it.
    Odd that there are different part numbers for right and left..:confused:
    Good luck..
  5. Nov 5, 2022 at 9:52 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Can you snap a photo or 3? If the leads are cut between the sensor and the connector then replacing the sensors would be the way to go, and pretty easy.
    I’d go with Denso sensors as well, that’s what you get in a Toyota box anyway. Should be under $250 USD for 1 upstream AF sensor and 1 downstream O2 sensor.
    1lowlife likes this.
  6. Nov 5, 2022 at 10:52 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    So why do the sensors need replacement? If all they did was cut wires, why not solder them back together?
    mountainpete likes this.
  7. Nov 5, 2022 at 12:50 PM
    Aren't the signals too sensitive for soldering?
  8. Nov 5, 2022 at 3:38 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    I would think that soldering would be OK with heat shrink tubing....not a crimp connector though
  9. Nov 5, 2022 at 3:45 PM
    I just looked it up. Some sites state that solder increases resistance and will throw the readings off. Others state that the wire is stainless steel and wont solder correctly. :notsure:
  10. Nov 5, 2022 at 5:56 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    Why the hell would it be stainless steel if it's insulated? I'm not understanding something.
