  1. Nov 4, 2022 at 5:12 PM
    KingSequioa007
    KingSequioa007 Dreaming of URD S/C
    San Diego, CA
    07 Sequoia SR5
    Current mods: AFE Cold air intake, AFE TB Spacer,JBA Long tube headers, DD full cat back race exhaust, pedal commander pedal controller, URD MAF Calibrator tuned by Mike @ Autowave, DD 12 hole 320CC injectors, R9K ECU reflash,Solid Off road mounts. Future upgrades: 4.8 gears and LSD, ,long travel kit.
  2. Nov 4, 2022 at 5:12 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    I'll need to see all 4. Those are both rear ones.
    But if both rear adjusters are all the way outwards and both fronts are inwards, I'd hazard to guess the brakes may have slipped when doing a caster measurement sweep (turning the wheels).
    Another way to kind of check, is the gap between the tires and the fender towards either the rear OR the front about the same?
  3. Nov 4, 2022 at 5:31 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I think it's +1. So what ever the spec is plus 1. I believe.
  4. Nov 4, 2022 at 5:32 PM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    It's a 2WD. I believe only fronts are adjustable.
  5. Nov 4, 2022 at 5:35 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    I’ll post up progress pics later. In the car.
  6. Nov 4, 2022 at 5:37 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    There are 4 adjusters. Two are "behind" the steering rack.
  7. Nov 4, 2022 at 5:39 PM
    alb1k
    Left Coast
    It's good
    I was looking at my bulbs thinking about you this morning
    txagg, bmf4069, Tundra2 and 1 other person like this.
  8. Nov 4, 2022 at 5:40 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    richsadams, artsr2002, txagg and 5 others like this.
  9. Nov 4, 2022 at 5:43 PM
    I’ve been meaning to do this, I made time this afternoon, since I drive semi dawnish hours during the work week
    RUSTYNUTS and Tundra2 like this.
  10. Nov 4, 2022 at 5:45 PM
    alb1k
    Left Coast
    It's good
  11. Nov 4, 2022 at 5:49 PM
    What exactly is this improved upon trans mount supposed to do that’s better than stock?
    Tundra2 likes this.
  12. Nov 4, 2022 at 6:00 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Yep, two for each control arm. 4 total.
    Skid plate may block view from the front but you can look from the rear.
  13. Nov 4, 2022 at 6:08 PM
    alb1k
    Left Coast
    It's good
    For you probably nothing, maybe just cause problems. I have an engine shifting issue that is almost certainly a 2WD thing, and because of other stuff I’ve done. Hopefully this helps me, and doesn’t rip my trans apart. It’s experimental, lol.
  14. Nov 4, 2022 at 6:16 PM
    alb1k
    Left Coast
    It's good
    Here are progress pics. I had to fill 1/4” x 1/4” with the welder to adapt the bushing tube, so, not gorgeous welding by any means. But if it works, it works. If it doesn’t or breaks shit, welp…
  15. Nov 4, 2022 at 6:46 PM
    oscardog86
    oscardog86 New Member
    Southern California
    You guys are seriously awesome, thanks for the help on the torque specs for the rear diff drain and fill plugs! Gonna hopefully break them loose tomorrow as long as the shop didnt torque them on crazy tight.
    Tundra2 likes this.
  16. Nov 4, 2022 at 8:08 PM
    oscardog86
    Southern California
    Oh, so is the rear drain plug a 23 or 24mm? Do I need that unique 23mm? Im guessing 24 works but if 23 is better then I can buy that too! After all, I love spending money on my truck! haha
    shifty` likes this.
  17. Nov 4, 2022 at 8:21 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    According to a few YT videos. It's a 24mm. I think that @Jack McCarthy's is juts plum wallered so it acts like a 23. If I were him, I'd probably just smack a slightly smaller sized socket on the plug, and then glue it on. Or weld it, but thats just me.
  18. Nov 4, 2022 at 8:58 PM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    The hell you say?
  19. Nov 4, 2022 at 9:28 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Hunner fiffy mall Nair
    Plumb wallered out
    artsr2002, shifty`, RUSTYNUTS and 5 others like this.
  20. Nov 4, 2022 at 9:53 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    I've used my 23mm socket a bunch working on some Hyundai Genesis' as they're rear lower control arms use it. Also works well for rusty/swollen lug nuts, the kind that have chromed caps over the nut.
    A 20mm I've only needed once, I think it was on an old school american car of some sort.
    Sometimes it's good to get the no skip sets.
    RUSTYNUTS and oscardog86 like this.
  21. Nov 5, 2022 at 5:39 AM
    I heard your voice when reading this. :D
  22. Nov 5, 2022 at 6:57 AM
    :spy:
    I had to use a 16mm on the RAV4 a few weeks ago to fix the sway bar links. That was odd. I really needed a 16mm box end wrench but of course I don't have that size.
  23. Nov 5, 2022 at 9:13 AM
    Tailgate mechanism lube day
  24. Nov 5, 2022 at 9:16 AM
    I guess I’m the only guy here who’s rear diff fill plug is loose with the 24 mm socket. I tried a 15/16” one, but it’s still a little loose. The drain plug works fine with the 24 mm though. o_O
    KingSequioa007 likes this.
  25. Nov 5, 2022 at 10:48 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I'm pretty sure I loosened my rear end diff with a 24mm too. Fill also. WS Plug on trans also a 24mm.
    oscardog86 and FrenchToasty like this.
  26. Nov 5, 2022 at 10:50 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    Rear pics of bolts.
  27. Nov 5, 2022 at 10:50 AM
    Did you notice if the 24 mm fill plug didn’t fit tightly or not?
  28. Nov 5, 2022 at 10:56 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    It's a bit loose but good enough to loosen or tightened.
  29. Nov 5, 2022 at 11:03 AM
    Okay, so it isn’t just me. Good to know.
  30. Nov 5, 2022 at 11:05 AM
    KingSequioa007
    San Diego, CA
    07 Sequoia SR5
    I think a 23.5mm would be perfect but that's a wierd size and custom socket. Lol.
