Clicking in wheels
Discussion in 'Wheels & Tires' started by ToyAddict802, Jul 28, 2021.
  1. Jul 28, 2021 at 7:01 AM
    ToyAddict802
    ToyAddict802 [OP] #ShallowPockets w/BigDreams
    GreenMt. State
    2023 SR5 DC,2023 Tacoma Sr5
    3.5 TRD Lift, TRD 20” wheels with 295/60/20 Falken Wildpeaks
    Anyone have experienced a clicking noise at very low speeds coming from your wheels?
    I installed slotted rotors and HD brakes a little while back. Just started to hear a clicking from the front and rear wheels area on the driver side of my truck. Took it to the garage and them said it is do from the slotted rotor catching the brake pads as it is rotating. Don’t seem to hear it at faster speeds just when the truck is barely moving.
  2. Jul 28, 2021 at 7:11 AM
    des2mtn
    Shady Grove
    2004 Black DC Limited 4x4
    Tonto cover
    Possibly the dust shields are bent in and contacting the rotors?
  3. Jul 28, 2021 at 7:30 AM
    ToyAddict802
    GreenMt. State
    I need to replace my dust shields as they are mostly rusted away but they are not touching anywhere. The garage told me the only fix would be the replace the slotted rotors with OEM rotors.
  4. Jul 28, 2021 at 3:06 PM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Check for a stone stuck between the shield.
  5. Jul 28, 2021 at 3:26 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Just cut the shield out, I ran my other cars without dust shield. It cool the brake more
  6. Jul 28, 2021 at 3:29 PM
    biebs96
    PA
    I had an experience with a low speed clicking when I had RW wheels on my last tundra.
    on the face of the hub, there was an excessive amount of anti-seize grease and upon cleaning up that and properly torquing the lugs, the clicking went away.
    and yes, I think I know what you are referring too. Because I first noticed the sound when sitting in stop and go traffic on a high barriered road.
    Hope this helps.
    MTRock and ToyAddict802[OP] like this.
  7. Aug 8, 2021 at 10:33 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Interesting. Might be why i have the noise. Thanks
    biebs96[QUOTED] likes this.
  8. Aug 8, 2021 at 10:37 AM
    GreatBasinTundra
    GreatBasinTundra Beer Me!
    Reno, NV
    2020 Tundra SR5 DC
    Kings f/r, TC UCAs, RCI skids, RCI sliders, C4 bumpers f/r, Warn 12s winch, 35s on 17” Rebounds, softopper, wet okole covers
    Any chance your center cap is a bit loose? This can cause a low speed clicking noise. If the rotor was catching the pad as the shop suggested it would most likely be chipping the pads and that would be visible.
    MTRock likes this.
  9. Aug 8, 2021 at 11:08 AM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
    ^^Had a clicking also…it was the center caps.
  10. Sep 30, 2022 at 11:14 AM
    1015K9
    1015K9 Austin
    Temecula, California
    2013 Rock Warrior
    Bringing an old thread back.. I'm getting a clicking noise from my rock warrior wheels. When you say it's coming from the center cap, what do you mean. Center caps seem secure. What'd you do to fix this?
    thanks.
  11. Sep 30, 2022 at 1:12 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    clicking can be many things, rock in tire tread, loose wheel weight, rim not seated/torqued correctly, loose lug nuts, brake shields etc.
    If you can isolate the issue to one wheel, remove it, make sure the center cap it secure, clean any dirt, grease, corrosion, rust off the hub and wheel and then reinstall with correct torque and see if that takes care of your issue.
  12. Sep 30, 2022 at 1:57 PM
    1015K9
    1015K9 Austin
    2013 Rock Warrior
    Cool thanks.
    I've already checked everything else I could visually. Nothin. I'll check the hubs.
  13. Nov 3, 2022 at 7:29 PM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    You end up getting this sorted? Thanks!
