Will 33x12.50x20 fit on Platinum wheels and no leveling?
Discussion in '3rd Gen Tundras (2022+)' started by 38Thumper, Nov 3, 2022.
  1. Nov 3, 2022 at 10:19 AM
    38Thumper
    38Thumper [OP] New Member
    I did a search and didn't find this size on a platinum. I am thinking about Kenda Klever RT's. Just want to make sure they wouldn't rub and if anyone has insight on the tire also.
    Thanks
  2. Nov 3, 2022 at 10:24 AM
    king.cong.1119
    king.cong.1119 New Member
    You should be fine, as long as the 12.5 clears your upper control arm with the stock offset wheels.
  3. Nov 3, 2022 at 11:09 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    1250 tires generally hit uca with the +60 wheels. May be ok with 33s, but 35s do have clearance issues with stock rims. If you do have an issue, easy fix with 1 inch wheel spacers from spidertrax or bora
