2001 4.7 over heating after timing belt change
Discussion in '1st Gen Tundras (2000-2006)' started by Kevin Bodmer, Nov 2, 2022.
  1. Nov 2, 2022 at 11:56 AM
    Kevin Bodmer
    Kevin Bodmer [OP] New Member
    2001 Tundra 4.7
    Just completed the 100,000 timing belt /water pump service. Belt was fine before I just figured it was time. Everything went smoothly Cams lined up with crank shaft ,rotated motor everything still lined up. but it back together and running like new but now it's over heating. Changed the stat still overheating.
  2. Nov 2, 2022 at 11:56 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Is the jiggle valve at 12 o'clock position?
    The coolant loop can't bleed air properly if it's not "upright."
    shifty` likes this.
  3. Nov 2, 2022 at 12:21 PM
    Coolant can't flow if there's air in the system, either, to your latter point.
    I suspect it's one of the two: tstat isn't clocked correctly, or air bubbles in the system. @Kevin Bodmer did you keep the heat on full-blast while filling, and what method did you use to fill?
  4. Nov 2, 2022 at 12:35 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  5. Nov 2, 2022 at 5:35 PM
    Kevin Bodmer
    2001 Tundra 4.7
    Yes Thanks, that is what the problem was. I replaced the stat position and then "burped" the cooling system with the heat on full. Just completed the front rack replacement, And Timing/water pump service. Pulled the bed sanded ,POR'd the frame , new rear bed. new cat's and exhaust back. It's like a new truck!
    Dook55, bmf4069, w666 and 2 others like this.
  6. Nov 2, 2022 at 5:36 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Congrats!
  7. Nov 2, 2022 at 5:39 PM
    If you don't see overheats the next couple of weeks, do us a favor as a "thanks!" ... come back and update this post after a couple of weeks, just to say, "yep, that was it!"
    Those four words could really help a future traveler here in the future.
    bmf4069 and Tundra2 like this.
  8. Nov 3, 2022 at 2:18 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Nice. Maybe share some pictures with us...we like looking at other people's stuff.
  9. Jul 27, 2025 at 8:34 PM
    Nimitz_
    Nimitz_ LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    Can confirm, from the future and not fulfilled.
    P.S invest in NVIDEA
    Upshot Knothole likes this.
  10. Jul 28, 2025 at 7:34 AM
    Yeah, it's weird, 3 years later, I see @Kevin Bodmer 's last login was 12 days after posting the thread in early Nov 2022
    I guess this worked, or he would've posted 12 days alter he was still overheating eh.
  11. Jul 28, 2025 at 7:50 AM
    Nimitz_
    Sam
    Seattle-ish
    The ol’ hit and quit. Typical.
    shifty`[QUOTED] likes this.
