  1. Oct 31, 2022 at 1:06 PM
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    I thought I took pics, but I can't find them. I'll look some more for the pics. It's pretty straight forward once you start looking at it. I used a nylon spacer to create another pin (I'll get the size later). I located it 9mm from the outer ridge around the original pin, which is left in place. Since our ports are oval, not round, I had to grind the top & bottom of the plastic bezel. I had to remove more from the bottom edge, possibly if you mounted the new pin below the centerline of the sides, less grinding would be required. I also had to slightly file the square hole for the adjuster. There is a gap on the sides which I haven't addressed yet, but it doesn't really bother me.
  2. Oct 31, 2022 at 1:22 PM
    Ghostly.-
    Ghostly.- Tragic.
    Mitchell
    Montana
  3. Oct 31, 2022 at 2:31 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Some dude on YT 3d printed some and made it work. I don't know if they are the same as blanks though. I'd like to have better fogs but if it's gonna be a deal where I have to have it 3d printed I'll pass. Have enough projects going on..
  4. Oct 31, 2022 at 2:34 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    Looks good. I have wheel envy at the moment. Been talking to the guy at FN wheels the last few days. Really close to blowing some money..shit adds up. New wheels, tpms sensors, mount and balance...I guess buy once cry once?
  5. Oct 31, 2022 at 2:39 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Whelp I went to get my inspection done. They told me nope. Some BS about my headlights. I have retrofitted projectors. I painted the reflector and projector shroud black. Apparently this is not kosher. Also he told me I couldn't have LED lights. Moron. I have HID bulbs in my projectors. Stupid inspections. Dammitt. Now because it's in the system, I have to "fix" them by putting cheap chrome halogens in before another shop will pass me. Pfft, my retrofits work way better than the stock halogen setup. :mad:
  6. Oct 31, 2022 at 2:48 PM
    artsr2002
    'Yonder
    Also my stupid check engine light came back on and lo and behold 1442, 1445, and 2441 again. Dammitt. Guess I'm gonna have to go with the Hewitt kit this time. :mad:
    Jack McCarthy and Cummins3500 like this.
  7. Oct 31, 2022 at 3:17 PM
    SoCalPaul
    Paul
    The needed modifications to the kit I got were fairly minor. The first one took about 45 min to figure out, the second one was 10-15 min.
  8. Oct 31, 2022 at 3:20 PM
    SoCalPaul
    Paul
    I found a local place that I was able to get 4 for $900 ($225 ea) instead of the $330-$350 ea most places are charging. I have several sets of 4Runner/FJ Cruiser wheels that I'll be selling to offset the price of these wheels.
  9. Oct 31, 2022 at 4:07 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    This is a pisser...
  10. Oct 31, 2022 at 4:08 PM
    abcinv
    Tommy
    South of ATL
    Geeshhhhh dude, not your day...
    Good luck!
  11. Oct 31, 2022 at 6:22 PM
    danmurphymn
    danmurphymn New Member
    Minneapolis, MN
    Black 2004 DC TRD
    I geeked out a bit recently & built out a section of my truck bed camping build. Lots more to come...
    Pull out drawer with access from the inside & adjustable compartments. Stove section with additional pullout cutting board / utensil storage. Side "dump bins". And my favorite part, my removable tool box. I got a little carried away & now I'm conflicted. I don't want to actually put tools in it...
  12. Oct 31, 2022 at 6:47 PM
    Hi06silver
    2006 DC 4x4 Waltrip
    Awesome. I'm probably going the FNW route. Guy is super helpful and it's not that much more. My lift sorta dictates what I buy. And I'm not trying to do it wrong. Just trying to keep current tires and have quality wheels that don't cause me probs centering and what not
    SoCalPaul[QUOTED] likes this.
  13. Oct 31, 2022 at 7:13 PM
    artsr2002
    'Yonder
  14. Oct 31, 2022 at 9:58 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    worked next to it.
    txagg, bmf4069 and daveeasa like this.
  15. Nov 1, 2022 at 6:02 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Damn that looks good and very clever/practical design. I dont even know how people work with wood so well, great job man!
  16. Nov 1, 2022 at 8:16 AM
    zoomspeed05
    zoomspeed05 New Member
    marc
    2006 tundra double cab sr5 4WD
    I have skinny 35s on my tundra, with minimal trimming and clearance done. its not that hard to fit with the right offset wheels
  17. Nov 1, 2022 at 8:34 AM
    oscardog86
    Southern California
    What size are they?
  18. Nov 1, 2022 at 8:40 AM
    I look at my truck and wonder how I could fit anything larger than 33s even if leveled since the front-to-back length of my wheel arch is no greater than 33 in. on my fender.
  19. Nov 1, 2022 at 8:47 AM
    Zoomed in, looks like 35x10.5 R17 LT
    5N0W808 and oscardog86[QUOTED] like this.
  20. Nov 1, 2022 at 10:48 AM
    zoomspeed05
    marc
    Bingo,
    Kenda Klever RT 35x10.50r17
    5N0W808 likes this.
  21. Nov 1, 2022 at 11:52 AM
    Casper421
    In the woods
    06 DC
    What’s your definition of “fit”? I want some pics of those tires stuffed before you say they “fit”.
    RUSTYNUTS, 805Tundra, 5N0W808 and 4 others like this.
  22. Nov 1, 2022 at 12:13 PM
    zoomspeed05
    marc
    Hammered pinch weld flat, trimmed the inner liner where the pinch weld, caster adjusted towards the front. front bumper inner liner trimmed, I dont go mudding or rock crawling so for the trail rides/ camping and off road i do it doesnt rub.
    RUSTYNUTS, 5N0W808 and oscardog86 like this.
  23. Nov 1, 2022 at 12:38 PM
    Yeah, baby! :bananadance:
    I’ll take each small victory I have with rust.
    txagg, bmf4069, Mr.bee and 8 others like this.
  24. Nov 1, 2022 at 12:40 PM
    Fill that hole!
  25. Nov 1, 2022 at 12:42 PM
    Yeah, I forgot to mention the fluid looks like it’s only down an inch from the hole. I’ll know later when I take it elsewhere to change it. Don’t want the neighbors seeing me. :spy:
  26. Nov 1, 2022 at 1:02 PM
    Maintenance day.
    -Air filter in both vehicles
    -Seafoam in crankcase on the Tundra
    I'll change the oil in 300 miles or less. I mentioned it in the other threads but Wal-Mart has good prices on Mobil 1 right now.
    bmf4069, 5N0W808, 805Tundra and 7 others like this.
  27. Nov 1, 2022 at 1:08 PM
    artsr2002
    'Yonder
    bfunke likes this.
  28. Nov 1, 2022 at 2:25 PM
    I think I got close to 500m on my last go-round with Seafoam high mileage in my crankcase. But I've got a little more going on in mine than yours, I'm sure. I need to pope my filler neck off soon and look at how much less (I hope) varnish there is, or how much lighter in color it is after 1 treatment and 500 miles of running.
  29. Nov 1, 2022 at 2:48 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I looked at crackie, and the V6 as I backed out of the driveway in the virus. I still need to call mcgeorge or Roman or someone to see if we can figure out that whole bolt debacle thing.
    RUSTYNUTS and shifty` like this.
  30. Nov 1, 2022 at 2:49 PM
    bfunke
    bfunke Tundra Curmudgeon
    @artsr2002 agree with you. Sequoia front end is nicer
