Going to buy a used one soon
Discussion in 'New Member Introductions' started by Catimann, Oct 18, 2022.
  1. Oct 18, 2022 at 1:02 PM
    Catimann
    Catimann [OP] New Member
    Andrs
    Vancouver BC
    Hi joined to get some info and read up on some of the advice already posted here.
    I did find a thread on MPG and noted it covered a lot but I did not see if having a Cab hight canopy would improve mpg.
    Also so far I have seen 5 4x4 Tundras, 1 plain jane double cab LBed, A Sport double cab TRD, a SR5 double cab and a 1794 crewmax. All had under 60k mi. What surprised me was the amount of surface rust on things like hose clamps and along every frame weld.
  2. Oct 18, 2022 at 1:09 PM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Those long bed double cabs are cool.
    Good luck with your search!
    SPP
  3. Oct 18, 2022 at 1:15 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Just keep looking, check out towns or states close to you as well. You will find the right one.
    and on MPG, only thing you can do to enhance MPG with a tundra is to keep it stock height and roll on stock size, standard load tires. That will get you 13-18MPG depending. Doing what we normally do to trucks, lift and some larger tires, will drop MPG of course.
  4. Oct 18, 2022 at 1:27 PM
    Catimann
    Andrs
    Vancouver BC
    Thanks I plan to more or less keep it stock. Maybe TRD suspension when it needs new.
  5. Oct 18, 2022 at 1:32 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    I'd guess the rust issues would have a lot to do with where you live.
    I'm in Dallas and I don't have much rust on my 2014..
    Good luck in your search..
  6. Oct 18, 2022 at 1:38 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Where are you located?
  7. Oct 18, 2022 at 3:36 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! The only mention of MPG's and any type of canopy (camper/shell, etc.) that I remember seeing basically stated that any aerodynamic help was offset by the additional weight.
  8. Oct 18, 2022 at 5:03 PM
    RoadtripJim
    RoadtripJim New Member
    Cedar, MN
    2021 Silver SR5 - TRD Double Cab
    Welcome to the forum, and good luck in your search.
  9. Oct 18, 2022 at 6:10 PM
    Catimann
    Andrs
    Vancouver BC
    I am in Vancouver BC (updated my profile) I have been looking at mostly certified dealer trucks. I can possibly buy a under 60k mi truck for about half what the new ones are going for. I also think the high prices of the "supply chain" issue is coming to an end. Around here the prices listed on the Toyota Canada web site are usually discounted when you look up the dealers own web site.
  10. Oct 19, 2022 at 12:41 PM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Welcome from the Basin of Arizona...Mesa!
  11. Oct 21, 2022 at 7:47 PM
  12. Oct 30, 2022 at 7:52 AM
    mattgecko
    mattgecko The LED Light Guy... MattGeckoLEDs.com
    South San Jose, CA
    2011 Tacoma, Off road, super charged 4x4
    Welcome!
  13. Oct 30, 2022 at 8:22 AM
    Belated welcome from NY.
