Blown engine
Discussion in '3rd Gen Tundras (2022+)' started by northerntundra1, Oct 29, 2022.
  1. Oct 29, 2022 at 4:32 PM
    northerntundra1
    northerntundra1 [OP] New Member
    alex
    2022 tundra
    Hey all wanted to share some information with the community and see if anyone else has had an engine failure.
    2022 tundra limited 4x4 bought in February and about 16k miles on it.
    went to run a small errand today and on the drive back home I started hearing some metal on metal noises coming from the engine bay. I turned into a side street right away aiming for a clear area to pull off the road and starting losing power, rpm began to bump up and down and lost almost all oil pressure. I turned the car off right away and towed it to the nearest dealer. waiting to hear back Monday. I also checked the fluids and everything was at the right levels. I do my oil changes at 5k miles and use top of the line oil. I've been driving toyota pick ups for 15 years and have never been let down but I guess there's a first time for everything. I did notice this week while starting the vehicle before i would head to work in the morning there wouldnt be any smoke but a strong odour as if the car was straight piped. The car had all the other small issues from shutting down at low speeds and saying power steering fluid is low to slamming on the brakes with the parking assist.
  2. Oct 29, 2022 at 4:47 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    Its a brand new drivetrain. Its not Northern Tundra's fault but you do have to expect that some unfortunate souls will be part of the development process this first year of production.
  3. Oct 29, 2022 at 4:53 PM
    Krusher22plat
    Krusher22plat New Member
    22plat
    Nice first post…lol…interesting stuff
  4. Oct 29, 2022 at 4:54 PM
    northerntundra1
    alex
    2022 tundra
    Absolutely ill let you guys know what ends up happening
    TK1979, Kap1 and X42069 like this.
  5. Oct 29, 2022 at 4:55 PM
    northerntundra1
    alex
    2022 tundra
    I was under the impression this the tacoma engine just with a compression change for the turbos?
    My tacomas have been rock solid over the years
    TK1979 likes this.
  6. Oct 29, 2022 at 5:04 PM
    JimboSlice413
    Bakersfield
    They're not identical in operation. The only Lexus that carried this drivetrain is the flagship LS 500, which is made exclusively in Japan. The Tundra, along with its V35A, is made in the US
  7. Oct 29, 2022 at 5:21 PM
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    Brutal man. Hope they look after you. Interested to hear what they have to say
  8. Oct 29, 2022 at 5:22 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Holy cow!!! WOW! That would get me upset!
  9. Oct 30, 2022 at 12:59 AM
    qudex
    qudex New Member
    2022 tundra blueprint
    Method r20 305 , 285 Falken at3w , icon stage 4 lift
    What ended up happening? Mine sounds like metal on metal when I start it up and had a pull over and call the dealership message come on today. It started with a rough idling and burnt oil smell
  10. Oct 30, 2022 at 6:35 AM
    Kentucky Tundra
    Kentucky Tundra New Member
    2022 Tundra SR5 TRD Offroad 6.5ft Crewmax Super Sonic Red
    Where is everyone else's oil pressure? Mine is typically only at a 1/4 of the gauge which concerned me. Usually Toyotas are at the 1/2 way mark
    Black@Blue19 likes this.
  11. Oct 30, 2022 at 6:40 AM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    Do these new engines use that ridiculous 0w16 oil like my wife’s 19’ Rav4 or is it still 0w20?
  12. Oct 30, 2022 at 7:45 AM
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    Mine stays at 1/4 as well. Keep in mind that this is relative to the overall pressure rating of the gauge. I’m guessing now that the engine is turbo they’ve broadened the range of the gauge, so normal operating pressure is likely the same as always.
  13. Oct 30, 2022 at 7:55 AM
    Kentucky Tundra
    Good to hear it seems normal. A little concerned the pump may be undersized relative to the additional flow required for the turbo.
  14. Oct 30, 2022 at 8:13 AM
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    Although possible I would think it highly unlikely the automotive engineers would make a major mistake on or overlook that calculation.
  15. Oct 30, 2022 at 12:23 PM
    pursuit2550
    pursuit2550 New Member
    Doesn't really matter. Toyota is using this crap just please the EPA/CAFE standards. Its been shown that this watered down oil is only used in the US basically. If you look at other countries, thicker oil is used, all the way to 40 or 50w. I switched over to 10W-30 on my 20 Tundra since first or second oil change. Engine sounds so much better.
    CMikeB, TundyMcTunra and 07DCLimited like this.
  16. Oct 30, 2022 at 12:58 PM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    You know you don't have to use 0-16 in the Rav. Its strictly a fuel economy thing. 0-16 is difficult to find in my area so I've been using 0-20 for 40k plus miles in my Rav with zero issues.
  17. Oct 30, 2022 at 1:21 PM
    Silver17
    Northeast
    Yeah I know, next change i’m putting 0w20. I put 5w30 in my tundra and it’s a bit quieter. My wife’s engine sounds like it has marbles in it sometimes and I can’t help but think the thin oil doesn’t help.
    TundyMcTunra[QUOTED] likes this.
  18. Oct 31, 2022 at 7:19 AM
    Silver17
    Northeast
    I wonder if the cause was an oil pump failure. I saw someone on Facebook report that happened at 26k miles and subsequently blew the engine. Anecdotal of course, but could make sense for how you described the failure occurring.
    ColoradoTJ likes this.
  19. Oct 31, 2022 at 9:33 AM
    mmasse
    mmasse Digital Forensics Cowboy
    Idaho
    2022 Magnetic Grey Tundra
    Still no reply from OP?
  20. Oct 31, 2022 at 10:45 AM
    mass-hole
    mass-hole New Member
    What about the broken valve springs in the 5.7L?
    2mchfun likes this.
  21. Oct 31, 2022 at 3:08 PM
    Engine teardown on Youtube shows one. Someone with an account on here had one also.
  22. Oct 31, 2022 at 3:47 PM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Do the same with my Wifes 20 Rav4.
  23. Oct 31, 2022 at 6:31 PM
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    What’s he supposed to post less than 6 hours into the first business day since his truck broke down?
    Sixty9Four20, TK1979, Donas and 3 others like this.
  24. Oct 31, 2022 at 6:47 PM
    mmasse
    Idaho
    Figure that the mechanics have had some time to diagnose what is going on yes.
  25. Oct 31, 2022 at 7:13 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    He was actually supposed to live stream the entire experience at the dealership ... It's appalling that he did not...
    Jk
  26. Oct 31, 2022 at 7:38 PM
    X42069
    X42069 New Member
    M
    The internet never disappoints lol
  27. Oct 31, 2022 at 11:23 PM
    I think this is the first one I have heard of. :notsure: Sucks nonetheless.
    Hopefully we get a reply and hopefully a warranty claim that takes care of the OP’s truck.
    @qudex
    @northerntundra1
    CHOSCAM, TK1979 and Tripleconpanna like this.
  28. Nov 1, 2022 at 1:33 AM
    CMikeB
    CMikeB New Member
    I know it's probably just me but I get a little concerned, when someone calls their Tundra a "CAR":confused::D
    fuzzamungus, CHOSCAM, $Bill and 5 others like this.
  29. Nov 1, 2022 at 1:49 AM
    :canada:
  30. Nov 2, 2022 at 7:26 PM
    northerntundra1
    alex
    2022 tundra
    Hey all just an update. First dealer refused to offer me a rental at all and I didn't want to waste arguing with them. I then towed it to the mega dealer I bought it from in the city. They promised to give me a rental as soon as toyota agrees to warranty it. I had to gather my receipts for my oil changes and submit them. Service manager says it's bottom end for sure but doesn't seem to think it's a spun bearing like I do. As soon as toyota approves it he will do a teardown and I will do my best to get pictures and paperwork.
