Wheel Spacers Poll
Discussion in '3rd Gen Tundras (2022+)' started by PwrMMA, Oct 6, 2022.
  1. Oct 6, 2022 at 12:34 PM
    PwrMMA
    PwrMMA [OP] New Member
    2022 Toyota Tundra SR5 TRD Offroad
    I ran wheel spacers to get a little better stance on previous trucks which admittedly, were pavement princess' that essentially never saw anything other than a gravel driveway for off road and some New England potholes. Trucks never had any issue.
    My current job entails frequent (couple of times a week) driving legitimately off road through roughly graded developments and some solid off road terrain. It's one of the reasons I picked this truck. Having the 4 wheel coil spring makes going off road 100x better than the old leaf spring design.
    I want to get that nice wide stance with this truck, I love the stock wheels so I don't have any plan to swap them out. Mildly worried about the spacers being a weak point though off roading. Anyone run spacers on any truck that actually saw some legit off road conditions consistantly?
  2. Oct 19, 2022 at 1:20 PM
    PwrMMA
    Anyone wanna weigh in? lol
    DarthTRDPro likes this.
  3. Oct 19, 2022 at 1:23 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I and multiple people I know, and tons on this forum, run spacers and do lots of offroading. Never had an issue. I even raced the King of the Hammers with wheel spacers, have had long travel trucks with spacers, and daily driven vehicles. As long as they're installed correctly and are hub centric, I would have no issues running them. Their only weakness is they're an extra failure point over an equivalent offset wheel.
  4. Oct 19, 2022 at 4:32 PM
    Kyles22tundra
    Kyles22tundra New Member
    I have never had wheel spacers. Do they affect your turning radius?
  5. Oct 19, 2022 at 4:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Yes they do affect the turning radius. I ran spidertrax spacers on my gen 1 tundra long travel in rear, now ive run them for years on my gen 2. Ive also run lug centric wheels on both trucks at times as well. I actually feel better about spacers+oe wheels than i did with method wheels. I like hub centric spacers and hub centric wheels. No science to back it up but it seems to all fit nice and snug
    Tundra'25 and Kyles22tundra like this.
  6. Oct 19, 2022 at 4:36 PM
    Ckatz53
    Ckatz53 Newish
    MD
    www.fouroneodetailing.com
    +1 for spacers through all sorts of conditions. Hubcentric and you won't have any issues.
  7. Oct 19, 2022 at 5:59 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Practically all long travel tundras run spacers in the rear.
    Black Wolf, Tundra'25 and Hbjeff like this.
  8. Oct 20, 2022 at 4:52 AM
    JoeInMinn
    JoeInMinn New Member
    2022 1794 Trd
    Quality Spacers like BORA are built amazingly well, many off-road jeeps and trucks use them. Make sure its good quality with rated studs and is built hub centric for your truck.
  9. Oct 20, 2022 at 6:53 AM
    Musashi66
    Musashi66 New Member
    2022 DC TRD Sport Lunar Rock
    Just some extra info - around Fort Collins, CO, not a single tire shop will work on your truck if you have spacers. Discount tire, Big O, Les Schwab, Costco refuses to even touch your truck, so it makes buying and installing tires a pain and tire rotations are a pain also.
    Not sure if you’d have the same issue or if you’d even care, but as much as I loved the look, I got rid of my spidertrax from my 1st Gen as it was too inconvenient.
  10. Oct 20, 2022 at 6:59 AM
    15 years of use with some heavy towing (7200# camper) and light off roading with my spacers on my FGT. Buy quality, install properly with a torque wrench and you shouldn’t worry about them failing.
    Tundra'25 likes this.
  11. Oct 20, 2022 at 7:04 AM
    Sunnier
    Sunny
    San Diego, CA
    I’m not sure why this would be, because some of those are national chains… Discount is happy to keep rotating/ installing their *certified* tires on my Tundra that has BORA spacers in back. Maybe there’s a law in CO-? :monocle:
  12. Oct 20, 2022 at 7:06 AM
    Maybe it’s the altitude. Just too high there
    1lowlife, Musashi66 and Tundra'25 like this.
  13. Oct 20, 2022 at 7:38 AM
    JoeInMinn
    2022 1794 Trd
    Highly odd considering discount will tell you its not against there policy with hubcentric spacers if you ask on there national forum. Costco also has no policy against it.
  14. Oct 20, 2022 at 9:16 AM
    Tundra'25
    Tundra'25 Well-Known Member
    Wincent
    Southern California
    hahaha :rofl:
  15. Oct 20, 2022 at 9:26 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    My tires have been replaced twice at discount tire with spidertrax spacers
  16. Oct 20, 2022 at 9:39 AM
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    Track width has a negligible impact on turning radius when the steering angle and wheelbase length stay the same. Especially if only widening the width used in normal wheel spacers application. You won’t notice a change at all.
    JoeInMinn likes this.
  17. Oct 20, 2022 at 10:50 AM
    Musashi66
    No clue. I called all locations before visiting and they wouldn’t do a tire rotation for me.
  18. Oct 20, 2022 at 10:51 AM
    Musashi66
    I couldn’t find a single thing in writing anywhere. This is just from the local shop, when I called and asked.
  19. Oct 20, 2022 at 5:03 PM
    Adam_1794
    Adam_1794 New Member
    MA
    22 1794 Metallic Black -Tow package/AVS/Air
    BORA Hubcentrics and you should be great. Ran a set on my 05 Xterra Off-road for years with no issues on/off the trail.
    I've got a 1" set on order that I plan to run with Method 705s depending on how the 18 offset looks.
    What are you running for tires?
    https://www.motorsport-tech.com/4DCGI/switchtruckmodel
  20. Oct 28, 2022 at 1:48 PM
    PwrMMA
    stock tires for now, I only have 2400 miles on the truck. ANyone know the specs on the spacer to look for? 5x___ ?
  21. Oct 28, 2022 at 1:53 PM
    Ckatz53
    Ckatz53 Newish
    MD
    It's whatever your bolts are. Unfamiliar with new Tundras.
  22. Oct 28, 2022 at 1:59 PM
    My local tire shop, Colorado Tire & Service, had no problem installing my lift and spacers on my 14 Tunny. They have been installing lifts here for years....
  23. Oct 28, 2022 at 2:07 PM
    Siblue
    Siblue Old member
    25 Tundra TRD pro
