Tundra worn wheel hole
Discussion in 'General Tundra Discussion' started by philnj, Oct 27, 2022.
  1. Oct 27, 2022 at 5:30 PM
    philnj
    philnj [OP] New Member
    So someone didn’t torque the wheel down properly and my wheel almost fell off. So I have 18’’ trd off road rims and the holes where the wheel studs go through are worn now, not really bad but you can slightly see it. Should i order new rims? I also had wheel spacers on and the threads on the wheel studs got messed up close to the actual spacer. Put everything back on but am a little worried about driving the truck around now.
  2. Oct 27, 2022 at 5:33 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    New wheels new studs and lugnuts take spacers off unless installed correctly and torqued.
  3. Oct 27, 2022 at 5:36 PM
    Mr Badwrench
    Mr Badwrench New Member
    You didn't use acorns (steel rim lugs) on alloys did you?
  4. Oct 27, 2022 at 5:36 PM
    philnj
    It’s the oem lugs, i have a trd off road
  5. Oct 28, 2022 at 6:27 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Once a rim has the holes hogged out like that they are dangerous. Won't hold correct torque and can have play. You will need to replace the affected wheels and as mentioned above, check out the studs, they may have damage as well. I had the exact same thing happen once with a 95 Ram.
    Taco-Spike likes this.
  6. Oct 28, 2022 at 6:51 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Worn hole, eh? There's a joke in there I bet.
    Retired...finally likes this.
  7. Oct 28, 2022 at 8:13 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    As to OEM alloy wheels:
    Some use acorn nuts..
    Some use flat washer nuts.
  8. Oct 28, 2022 at 8:14 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Simmer down you wheel hole..:eek2:
    hagrid[QUOTED] likes this.
