Baja design vs Diode Dynamics fogs
Discussion in 'Lighting' started by king.cong.1119, Oct 27, 2022.
  1. Oct 27, 2022 at 6:45 AM
    king.cong.1119
    king.cong.1119 [OP] New Member
    Finally got my baja design fogs mounted next to the diode dynamics. Baja is the squadron sport wide cornering amber and diode is the ss3 pro amber fog. I am not going to spoil the results just yet, please comment which one do you think looks better for fog lights.
    bulldog93 and PermaFrostTRD like this.
  2. Oct 27, 2022 at 6:48 AM
    PermaFrostTRD
    Northern NY
    king.cong.1119[OP] likes this.
  3. Oct 27, 2022 at 6:53 AM
    Sunnier
    Sunny
    San Diego, CA
    Appearance while turned off: BD
  4. Oct 27, 2022 at 7:08 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Can't go wrong with either. I'm running SS3 fogs on mine
    BiggHertz and king.cong.1119[OP] like this.
  5. Oct 27, 2022 at 7:10 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    I prefer the look of the BDs.
  6. Oct 27, 2022 at 7:30 AM
    Taco-Spike
    Two Trucks
  7. Oct 27, 2022 at 8:05 AM
    PermaFrostTRD
    Northern NY
    For my needs, this is the pattern that would suit me best. my OEM LED pro's handle all of the driving light I need, so my "fogs" would be strictly for whiteout conditions. I'd likely go with the product that is responsible for this image. :spending:
    edit - didnt realize both "beam cutoff" shots were 1 image. I'm talking about the lower/bottom pic of the 2.
  8. Oct 27, 2022 at 8:14 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I might not be understanding the question correctly, but I guess I’ll choose the SS3 since it’s the only one that is a fog light.
    Also, you should flip the bezel on that squadron sport so that the writing is right-side up! :D
  9. Oct 27, 2022 at 8:27 AM
    king.cong.1119
    Haha, I tried but I don't thinks it will work right side up with the bracket pointing down?
    Baja Designs likes this.
  10. Oct 27, 2022 at 8:27 AM
    king.cong.1119
    I will keep the suspense for a little bit longer then definitely let you know. :)
    PermaFrostTRD[QUOTED] likes this.
  11. Oct 27, 2022 at 8:30 AM
    crazyjohnny
    crazyjohnny New Member
    Johnny
    2017 TRD Pro
    Shimmed, 1.5" Shackles, Viair Onboard air, Firestone Air bags, CBI Sliders
    Honestly not very happy with my Baja designs. The output of the last SAE was worse than the factory head lights. Don’t like using the wide cornering due to blinding other people. And yes, I had both! Looking forward to trying the SS3s!
    EDIT - offroad they are great! Just wish the Wide Cornering were better on road, or that BD had a better on road option.
  12. Oct 27, 2022 at 8:34 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    DD for me and I have owned both. BD’s are super bright but the cutoff doesn’t compare, making the DD’s usable (AKA not blinding on coming motorists) during normal driving.
    EDIT:
    My apologies to everyone, I honestly thought OP was comparing the non SAE Baja Designs to the SAE Diode Dynamics. Nothing more nothing less…
    I meant no offense to Baja Designs and own/owned quite a few products of theirs.
  13. Oct 27, 2022 at 8:36 AM
    memario1214
    Colton
    Missoula, MT
    Just pull the screws and rotate both the lens and the black bezel. I promise you it will work (as long as you don’t strip the screws), and you’ll have upright writing on the black bezel as well as an upright BD logo in the center of the lens.
  14. Oct 27, 2022 at 8:42 AM
    AZBoatHauler
    So.Arizona
    Were you running the SAE Baja design fogs? I’ve had mine about 3.5 years and think I’ve oy been flashed once or twice. Of course I have to show the brights just to prove I’m in low beams. :cool:
    Baja Designs, Tundra'25 and reywcms like this.
  15. Oct 27, 2022 at 9:52 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    No I was running the Squadron Sport wide cornering. My bad, I though OP was comparing the non SAE.
  16. Oct 27, 2022 at 10:54 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    San Marcos, CA
    Hey @Oey12, Which lights of ours were you comparing to the DD lights?
    If you solely drive on flat narrow surfaces the DD solutions are a great candidate. If your adventures involve elevation change and you would prefer to drive off-road aggressively the sharp horizontal and vertical cutoffs will leave you wishing you had the transitional spill light of Baja Designs. The majority of our products are designed for off-roading specifically and we do offer an SAE version of our Squadron that does have sharper cutoffs than the other options. Depending on the light you are comparing, it would be similar to comparing apples to oranges. Both lights are built for two different applications.
    Best,
    Brandon
    BiggHertz likes this.
  17. Oct 27, 2022 at 10:57 AM
    Baja Designs
    San Marcos, CA
    Hey @king.cong.1119, you can definitely rotate the bezel on this light so the writing is right side up. Just unscrew the 4 bezel bolts and rotate the bezel and re-insert those bolts.
    Best,
    Brandon
  18. Oct 27, 2022 at 11:12 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    ^this - the abrupt cut off when bouncing around off-road is absolutely distracting to the eyes, which is why I opted for the BD sports in a W/C pattern. I've been running them on my rig for quite some time and have yet to be flashed. It might have something to do that I run them at "10%" PWM control via SP9100 when on the road...but no regrets.
  19. Oct 27, 2022 at 11:20 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I don't think I've run into a BD lens setup that is indexed where it would prevent you from orienting your lens anyway you'd like. Can confirm first hand that is not the case with some of the DDs :/
    Case in point...S1s with mounting bracket vertical and lenses rotated 90 for W/C pattern..
  20. Oct 27, 2022 at 11:25 AM
    king.cong.1119
    sounds like I need a spod in my life!
    AZBoatHauler and Baja Designs like this.
  21. Oct 27, 2022 at 11:28 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    or a switch-pro...can't go wrong with either.
  22. Oct 27, 2022 at 11:29 AM
    king.cong.1119
    Ahh I got you now, Thank you! the upside down lettering doesnt bother me that much yet, but I will certainly keep that in mind.
    Baja Designs[QUOTED] likes this.
  23. Oct 27, 2022 at 11:29 AM
    king.cong.1119
    true, I keep getting those two confused, and still do.
  24. Oct 27, 2022 at 11:34 AM
    Baja Designs
    San Marcos, CA
    Well said @BiggHertz.
  25. Oct 27, 2022 at 11:40 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    lol...I went full BD on the truck, minus the Cyclone V2s under the truck for rock lights. Planning my next push for Front and Rear Bumper upgrades, along with roof rack (potentially) and will be replacing existing BD with more BD.
    DD makes one hell of a product as does RI,KC...but there is something about BD that I know I can rely upon. Similar to buying a Surefire vs Streamlight...
    YMMV, but just build your package for your majority use case and within your budget...
    -JS
    bulldog93, Baja Designs and Mater like this.
  26. Nov 4, 2022 at 7:25 AM
    king.cong.1119
    Baja design squadron sport (wide cornering) vs Diode dynamics ss3 pro fog. Screen shot of the comparison from the video I am working on. Pick ur preference, each pictures order isn’t consistent as a blind test should be. Haha
    35660331-B1DD-4823-AC9A-803F1F7B019B.jpg 07DE84CF-9554-4939-A183-A98E4040C774.jpg 653FB6A2-74A2-4B43-B6B2-BE6B833436FD.jpg 214BE314-8B64-43F8-A41D-232CA251EF9D.jpg
  27. Nov 10, 2022 at 10:11 AM
    SharkDog
    SharkDog New Member
    Denver
    2006 Gray DC Tundra SR5
    Dobinson Twin Tubes. Stock.
    I like photos 2, 3, 6, & 8. Hopefully, that is flipflopping between the two. If you can lock the settings on your camera it will create a better comparison.
    Edit: Thanks for doing this! The camera comment wasn't supposed to be shitty, and I appreciate your time.
  28. Nov 10, 2022 at 10:14 AM
    king.cong.1119
    haha no problem, I am fairly familiar with the camera setting, so all vs photo settings are locked (manual everything) even to the white balance. cheers
  29. Nov 10, 2022 at 10:17 AM
    SharkDog
    SharkDog New Member
    Denver
    Sweet! The difference in your low beams in photos 1 and 2 had me thinking otherwise.
  30. Nov 10, 2022 at 10:17 AM
    king.cong.1119
    all your pick points to BAJA squadron sport wide cornering amber! good eye
