Cat Back Exhaust
Discussion in 'Performance and Tuning' started by capt Craig, Oct 26, 2022.
  1. Oct 26, 2022 at 5:35 AM
    capt Craig
    capt Craig [OP] New Member
    2019 Tundra Quicksand
    Not yet
    Whats the best cat back performance exhaust out there? Cold air intake?
    2019 Double cab 5.7 Liter.
  2. Oct 26, 2022 at 5:49 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    @dirtydeeds has the best exhaust. Can get it from quiet to loud, adds up to 10HP and 20TQ, no loss of low end. Cold air intake- don't bother. You will not gain anything unless you have forced induction and the stock air setup is already a CAI, so save your $ on that to go for something else.
    Here are the exhaust options. Many of us chose the standard stainless systems, muffler length determines sound, smaller the muffler the louder the exhaust. But you can get aluminized for less coin or a dumped setup for even less, but the dumped exhaust is louder, maybe too loud for you. Keith from DD can assist or answer any questions.
    https://dirtydeedsindustries.com/store/ols/categories/toyota-tundra
  3. Oct 26, 2022 at 5:49 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    There are lots of threads you can find here on exhaust and almost all of them will tell you to call up dirty deeds industries and they will work with you for sound levels that you are looking for. Most other cat back exhausts cause you to lose torque.
    Lots of threads on intakes as well. The intake on the Tundra is already pulling cold air from the fender on the passenger side, a drop in filter from K&N will increase air flow but I have seen some studies and chances are you will be sucking more dirt in so I'd plan on changing engine oil more often. The ONLY 2 intakes I've seen recommended is the TRD intake and the Stillen intake. I can recommend the Stillen but it will have a high pitch whistle at certain RPM's/loads like most cold air intakes. The Stillen does allow the intake air temp to drop about 10 seconds faster when you start moving over the stock intake. It has extra volume in the intake box over the stock intake but I'm not sure that makes much of a difference.
    I do not have any experience with the TRD intake.
    Be careful with oiled filters as they can mess up your MAF sensor. I went with a dry filter I will replace rather than a clean and oil.
    dirtydeeds likes this.
  4. Oct 26, 2022 at 8:23 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    dirtydeeds and Jim LE 1301 like this.
  5. Oct 26, 2022 at 8:25 AM
