Bilstein 6112 1.9" setting
Discussion in 'Suspension' started by NSURIT, Oct 21, 2022.
  1. Oct 21, 2022 at 5:41 PM
    NSURIT
    NSURIT [OP] New Member
    Todd
    2021 CREW
    Truck is currently on order.
    Does the 1.9" setting on a 6112 Bilstein put a Tundra level? I'm referencing a 2021 4wd CM Tundra.
  2. Oct 21, 2022 at 5:46 PM
    AZBoatHauler
    So.Arizona
    Approximately. I put on CB+2 extended shackles and have just over an inch of rake empty.
  3. Oct 21, 2022 at 6:01 PM
    Bo Dangles
    Bo Dangles New Member
    Jesse
    Canada
    2021 Tundra TRD Sport Premium
    I did the exact same, I felt the front end was actually a little high without the +2 shackles
  4. Oct 22, 2022 at 7:40 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    Stock 2.5 gens, with good springs, no sag, no extra weight anywhere have 2 inches of rake. So lifting the front 2 inches levels the truck. Same height as the TRD PRO model, which is higher in the front by 2 inches than the other models, leveling the truck.
  5. Oct 24, 2022 at 1:20 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Yup, this was my old 19 with 6112’s at 1.9” and 5160’s in the rear with no lift.
  6. Oct 24, 2022 at 1:44 PM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    6112/5160 set up; top setting in front, nothing in the rear except the 5160's Slightly nose high if you measure.
  7. Oct 26, 2022 at 1:48 PM
    MistrRoboto
    MistrRoboto '17 MGM SR5 TRD CrewMax
    Virginia Beach, VA
    Mine measures completely level at 1.9 (with nothing in the bed).
  8. Nov 18, 2022 at 6:28 PM
    Robster80
    Robster80 New Member
    Thats exactly the look im goin for with my truck. What size tires u running?
  9. Nov 19, 2022 at 7:08 AM
    Heath423
    Heath423 New Member
    Heath
    Chattanooga, TN
    2020 Magnetic Gray CM SR5 4WD
    Console tray/dividers, Interior LED's
    Good looking truck. Looking for this look also. I have a 20 SR5 CM that I put those OEM TRD wheels on. Now looking to go a size or two up on tire size and will need to do level/lift to achieve as I understand it. Truck typically stays on the pavement with an exception of hunting season. However, even during hunting season it doesn't really see "Off-roading".
