How which gears affected your 1st gen Tundra MPG?
Discussion in '1st Gen Tundras (2000-2006)' started by RUSTYNUTS, Oct 22, 2022.
  1. Oct 22, 2022 at 9:32 PM
    RUSTYNUTS
    RUSTYNUTS [OP] Diagnosed: incurable
    Rusty
    sOCal
    to be continued...
    We all know bigger tires burn more gas. It would make sense to think shorter gears would do the same as they require higher RPM for any given speed. I recently changed my gears from the stock 3.91's. I had available- a set of 4.10's, and a set of 4.88's. Due to the fear of horrible gas mileage, I opted to install the 4.10's. I've since noticed that I'm actually getting better MPG on the freeway, and about the same in the city stop-and-go stuff. I'm curious what #'s other 1st gen owners are getting who have changed gears on their 1st gen Tundras, and on what tire size, as I plan to make the jump to either 4.56's or 4.88's.
    I'm asking for true MPG #s, so don’t forget to input tire size into whatever app or scangauge you’re getting the data from, unless you’re on stock size tires.
    I am on 35" tires and use scangauge
    bmf4069 and FrenchToasty like this.
  2. Oct 22, 2022 at 9:56 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    https://www.tundras.com/threads/re-geared-to-4-10s-on-oe-tires.80540/#post-2182011
    City mileage went from 12-13mpg to 16mpg going from 3.91 to 4.10's on stock tires.
    17-18mpg to 18-20mpg freeway around 65-68mph (best I saw was 20.5mpg, but that was at 60mph for testing).
    With 35's you should have gone to the 4.88's. Mechanical advantage > higher rpms for fuel mileage. Engine may spin faster but there is less load (ie: less throttle) when cruising.
  3. Oct 22, 2022 at 10:02 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    stock gears. before the headers i could eek 19mpg on the highway with 33s.
    post headers im lucky to get 15 highway... really need to fix the running rich issue..
    i plan on 4.10s honestly. just a slight bump. and next set of tires i'll probably just go 32s. the 33s are no longer needed since i uh.. bought too many tacomas to not just use them offroad. LOL
  4. Oct 22, 2022 at 11:37 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Hindsight I should've also asked speeds, and I thank you for mentioning yours. I've noticed that whether I'm traveling at 60, or 80mph, the difference in MPG isn't significant, as long as the speed is consistent. Fluctuating speed within any range costs more fuel than a constant 90 mph on a straight. And where the hell were you when I was trying to decide on gears? From a table graph I saw somewhere, 4.56's on 35's is a near perfectly matched ratio to stock gears on stock tires. You still think the 4.88's are a better choice? I should mention the majority of my miles are freeway averaging 85'ish mph.
  5. Oct 22, 2022 at 11:46 PM
    I’m on “33s” but I definitely want to go 488, all the weight, and being a ridgeline, I think it will be a good combo
    I think darkness runs 456 on the same size tire, and love them, but not as much weight, so I bet that’s perfect for him
    5N0W808 and des2mtn like this.
  6. Oct 22, 2022 at 11:53 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    3.90's are taller than 4.10s.
    bigger tires are like having taller gears, but also heavier and usually wider adding to extra rolling resistance.
    imagine riding a bicycle up hill, taller gears are more difficult, and require more effort, but spinning the pedals with shorter gears is easier.
    and the 4.7 is a spinner, not a weightlifter. Non-VVTI has peak torque at ?3400?rpm. Thats where the engine uses its fuel the most efficiently. I mean, i havent seen any cylinder pressure mapsfor the 2uz, but its usually pretty close to peak tq rpm.
  7. Oct 23, 2022 at 12:16 AM
    Maybe that’s why better mileage is seen at highway speeds vs normal in town.
    Which doesn’t help me
  8. Oct 23, 2022 at 12:26 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
  9. Oct 23, 2022 at 12:30 AM
    92.7% of my driving is under 45-50mph
  10. Oct 23, 2022 at 12:46 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Turning off OD is like having 5.33's
  11. Oct 23, 2022 at 8:57 AM
    Casper421
    In the woods
    06 DC
  12. Oct 23, 2022 at 9:55 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    30% underdriven?
  13. Oct 23, 2022 at 9:59 AM
    What would cause it to run rich?
  14. Oct 23, 2022 at 10:09 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Knew I might have fukt that up, edited to correct. Thx. Still don’t understand what’s taller about a lower ratio with less teeth on the ring gear. :notsure:
  15. Oct 23, 2022 at 10:13 AM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    Longer legs.
    I'm 5'10", and take appropriate sized steps, theres some 6' something behemoths walking like they're hurdling, and some 4' something chicks shuffling their little legs as fast as they can manage.
  16. Oct 23, 2022 at 12:01 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    That's because you're not in an efficient range of the engine/fuel map the way your engine is loaded with current gearing and tires.
    Fluctuation eats gas because extra fuel is put in every time you tip the throttle in. This is to prevent engine damage from leaning out if you stab the throttle.
    No idea, did you post anything? Lol.
    Numerically 4.56's match. But it doesn't take into account the significantly heavier tires and increased wind resistance from being taller. Go 4.88's.
    Think of the max speed each gear set will reach.
    Shorter gears mean a lower top speed and reaching that top speed in a shorter amount of time. Taller means higher top speed and taking longer to get there.
    I think the terms were originally coined by those drag racing.
    RUSTYNUTS[QUOTED][OP] likes this.
  17. Oct 23, 2022 at 12:37 PM
    Maybe a 2 speed rear end would be the best of both worlds?
    Now if they only made them to fit a pickup truck and could make it shift either manually or automatically based on need.
    5N0W808 likes this.
  18. Oct 23, 2022 at 1:02 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Thank you. All very helpful stuff. And I think you just talked me into the 4.88’s. Bonus is I already have them and would need to buy 4.56’s if I went that route.
    Here’s a fun fact that you @assassin10000 should get a kick out of; the 4.88’s that I have, are the Motives that you sold to @chrisb a while back. Without knowing it you just talked me into installing your old gears into my truck.
    5N0W808, bmf4069, Mr.bee and 2 others like this.
  19. Oct 23, 2022 at 1:10 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Nice!
    Solid pinion spacer the diff while you're in there.
  20. Oct 23, 2022 at 1:26 PM
    empty_lord
    05 rollover special
    X pipe.
    seems to be a common occurrence
    5N0W808 likes this.
  21. Oct 23, 2022 at 5:10 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    I've actually got an extra 3rd member to use, and will be building it when i get my hands on a locker of some kind. you wouldn't happen to have one layin around huh? but yes, solid spacer. When I recently went from the 391's to 4.10's, I had also picked up an LSD to install. That's why i hunted down an extra 3rd, so I could build it, then swap it in with no real down time. Now I've got my original 3rd on the bench, which is where I'll install the 4.88's and locker (and solid spacer). When I was just building the LSD diff, I was having a difficult time sourcing the solid spacer, and running out of time, I just had to use the crush sleeve. It was a bit confusing because the 8.4 was also in the T100's and certain years of the taco's, and that's how the parts are listed on the sites. In other words, I was having to search for T100 or whatever years of tacoma parts to find parts for the 8.4. Then, sometimes (not always) 1st gen tundras would be listed as compatible, even tho that search came up empty. Anyways, all that being said, Got a link for the solid spacer for an 8.4 diff?
    Another question I have is; what, if anything, is compatible between the 8" and the 8.4"? I read that toyota labeled them as such only for identification, and the ring gears are actually the same diameter, but the 8 is 10 bolts and the 8.4 is 12 bolts. And there's also a 8.2". Anyone know and care to elaborate?
  22. Oct 23, 2022 at 5:22 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Gears are the same, housings are different iirc. Maybe some of the bearings/internals too.
    I got my solid pinion spacer from here or 4wp (had to call and order, wasn't on the website a couple years ago:
    https://trail-gear.com/toyota-solid-pinion-spacer-kit.html
  23. Oct 23, 2022 at 5:34 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    Yeah, people always think higher RPM means lower mpg. If the load on the engine is high at low rpm, you’re going to burn more fuel.
    As always, there is a point of diminished returns.
  24. Oct 23, 2022 at 5:38 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Not to hijack a thread but what is a Ridgeline Tundra?
    Jack McCarthy likes this.
  25. Oct 23, 2022 at 5:40 PM
    The best of the best, the double cab
  26. Oct 24, 2022 at 6:51 AM
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    I'm on 285/75/17 (33.8") with 4.88's and I'm getting about 15-17 MPG on average, according to the Fuelly app and my Scangauge. You can use a simple math formula to help you choose gears to get you close to stock. For me, 4.56 would probably have been best but I do plan on towing and for that reason, I went with 4.88's.
    Also, I installed the YellowBox tire calibration module and my odometer is dead on, so my scangauge should be giving me an accurate readings of my MPG.
    This picture below was from a 2 hour drive/145 miles. Mixed with Traffic and open road.
  27. Oct 24, 2022 at 1:06 PM
    Riverdale21
    OTP ATL
    I have never heard of it being called that. Thanks for the info.
  28. Oct 24, 2022 at 1:33 PM
    I thought it meant a Tundra that's never driven off-road, kinda like a Ridgeline. :notsure:
  29. Oct 24, 2022 at 1:44 PM
    Mr.bee
    Mr.bee King Turdra
    '02 AC TRD
    The body positive movement was built on the doublecab truck. Look at how big a half ton is. My single cab ranger does half ton things, but its not bloated with gizmo's (distractions) and like all 1gt's didnt need to be approved by a dude with a beard.
    JasonC. and shifty` like this.
  30. Oct 28, 2022 at 12:18 AM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    There is an option in the scangauge settings to input % of change to ratio due to non-stock tire size. Unnecessary for you, but helpful for anyone without the yellowbox. Once set up, the scangauge will show actual mph and mpg, despite the speedo being incorrect. Yellowbox is the way to go for sure, I just haven't gone there yet
    Never heard a double cab called what? a ridgeline? or the best of the best? Neither are truly accurate..:rofl:
    2006Tundra[QUOTED] likes this.
