2007 transfer case actuator
Discussion in '2nd Gen Tundras (2007-2013)' started by '7740, Oct 19, 2022.
  1. Oct 19, 2022 at 4:20 PM
    '7740
    '7740 [OP] New Member
    07 tundra
    My '07 has no 4wd, and after reading everything I can find about it I'm pretty positive the problem is in the actuator. I was trying to remove the low and high covers to clean, diagnose and repair but when I went to remove the covers I found 2 of the screw heads completely corroded. Another one I was able to get the philips screwdriver into, and once applying serious pressure the head snapped off. I need remove the entire actuator assembly now. Can any of you give me direction on how to do that or steer me to an existing thread on it? It can't be as easy as removing the 3 bolts and pulling it off..?
  2. Oct 20, 2022 at 9:46 AM
    bobothegreat
    bobothegreat New Member
    jason
    07 super white tundra
    I am actually 100% in this exact situation! Following
  3. Oct 20, 2022 at 12:43 PM
    huntertn
    huntertn New Member
    Tennessee
    2008 White CrewMax Limited 4x4
    You can’t take the complete actuator off without disassembling the transfer case. But you can cheat. You can take the actuator apart and leave the rods in the transfer case. The guy in this video kinda shows enough to help you figure it out. He does not show taking it apart but does show putting it back together. It is not in English and the part I think you will want to see starts around 10:30. I hope it helps.
    https://youtu.be/8blixRQT4zQ
    baraynavab likes this.
  4. Oct 23, 2022 at 9:43 AM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    2007 Tundra CrewMax 4x4 5.7L V8
    Always used your 4x4s like on a monthly basis to ensure it works properly.
    How you figure this one out.
