2022 Tundra Limited Crew Cab, TRD. Not impressed after 16k miles
Discussion in '3rd Gen Tundras (2022+)' started by NaplesDraw, Oct 22, 2022.
  1. Oct 22, 2022 at 7:14 PM
    NaplesDraw
    NaplesDraw [OP] New Member
    Don
    2022 Tundra Limited TRD
    I have had my new 2022 Tundra Limited Crew Cab TRD for about 8 months, I am now at 16.5k miles. Not impressed so far. I have owned 2 prior Tundras and Lexus LX 470's and the quality of this truck is slipping. The side of the seat broke after about 5k miles. I like the new engine, better gas mileage, electronics are awesome, great style, but overall just not as solid as the other Tundras I have owed. For the price, should be made more solid.
    Tundra_361 and Metro14536 like this.
  2. Oct 22, 2022 at 7:28 PM
    X42069
    X42069 New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    How did the seat break?
    Abraham5G likes this.
  3. Oct 22, 2022 at 7:30 PM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Seat base notwithstanding, what else is "not solid"
  4. Oct 22, 2022 at 7:47 PM
    NaplesDraw
    Don
    Also, a section of the trim on top of tailgate has come loose, overall the truck feels not as solid as my other tundras. I still have my 2016 tundra limited crew cab. Example, when I shut the doors the old tundra just feels much more solid built overall. Hard to explain.
    Metro14536 likes this.
  5. Oct 22, 2022 at 7:59 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Obviously I don't know but looks to be from some sort on impact. Does not look like the other ones I have seen on here w/a vertical crack.
  6. Oct 22, 2022 at 8:49 PM
    xc_tc
    xc_tc New Member
    “More solid” yeah because the old Tundra doors were made with heavy ass steel
    TTund16 and JUNNEL20 like this.
  7. Oct 23, 2022 at 6:27 AM
    X42069
    X42069 New Member
    M
    Yeah OP doesn't seem too keen on answering that I've. I know there have been issues with that part of the seats but I have to wonder if it was self inflicted
  8. Oct 23, 2022 at 7:22 AM
    usfdrohead
    usfdrohead New Member
    I’ve seen the plastic seat trim crack, but yours is a perfectly cut square. Super weird.
    Abraham5G, Gene5253, catalac and 2 others like this.
  9. Oct 23, 2022 at 7:41 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    :notsure::notsure:If you don’t like the 2022 Tundra than sell it?
  10. Oct 23, 2022 at 3:48 PM
    Point Man
    Point Man New Member
    Mark
    Racecity USA Mooresville, NC
    2023 1794 MGM
    Tonneau Cover, Cat Shield, Power Boards, Bed Mat, Rear Light Bar
    And the piece that broke went into the hole like it was done from the outside.
    Gene5253[QUOTED] likes this.
  11. Oct 23, 2022 at 3:56 PM
    outlaw.taco
    outlaw.taco New Member
    Houston
    2 post count
    PermaFrostTRD and Gene5253 like this.
  12. Oct 23, 2022 at 4:16 PM
    RLHULK
    RLHULK Too many gamma rays in all that BBQ smoke.
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    The seat trim is a known issue. Mine has it.
  13. Oct 23, 2022 at 6:43 PM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    Bet it dos not look like the op's
    X42069 likes this.
  14. Oct 26, 2022 at 7:05 AM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I put hands on a new 2022 this morning. Quick walk around, truck looked nice but noticed the sheet metal is way thinner than my 2016. I could easily push in the hood and door panels with a little pressure from my thumb. They felt thin, pushed in about 1/8th, 1/4 inch very easily.
    The bed caps were loose. Seemed like they would rattle when driving. They were attached, clipped in. Pushed on one slightly with my thumb and it popped right off! It clipped right back in, so working as designed but was very loose and ill fitting.
    Certainly didnt expect a 50-60k SR5 truck to feel like that, kinda cheap. I would be disappointed if it was my truck and the price they are going for.
    PermaFrostTRD likes this.
  15. Oct 26, 2022 at 10:18 AM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    Honestly, this is the direction that all trucks are going. Everything will get cheaper, weaker and softer.
    Buildn and TNtundra22 like this.
  16. Oct 26, 2022 at 11:38 AM
    frichco228
    Frank
    Virginia
    I checked the hood and rear door panels, same give in both areas, again much thinner metal than what I expected based on earlier toyotas I own, a 2006 and 2016. Guess it is the new normal across manufacturers.
  17. Oct 26, 2022 at 11:51 AM
    X42069
    X42069 New Member
    M
    I think part of the reasoning is that for most people who only use their truck to get groceries, don't drive off road etc (myself included not flaming anyone) it is fine and lighter than metal meaning better fuel economy.
    That being said I can understand people not being impressed
  18. Oct 26, 2022 at 12:20 PM
    Breathing Borla
    AZ
    the main reason and likely only reason is CAFE, they had to lighten it up, has nothing to do with off-road
    22whatwedo, DFS and ryanwgregg like this.
  19. Oct 26, 2022 at 3:54 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    It looks like it initially cracked horizontally, and he made it worse messing with it.
