TRD Lift Kit Pricing
Discussion in '3rd Gen Tundras (2022+)' started by ddrosness, Nov 3, 2021.
  1. Oct 22, 2022 at 7:07 PM
    #181
    Snipdingle
    Snipdingle New Member
    22 CM limited 6.5 Army Green 2007 FJ Cruiser, mods. 1986 Toyota pickup, lockers etc. Subarus and a DR650 for forest roads
    Taikowaza likes this.
  2. Oct 22, 2022 at 7:18 PM
    #182
    Snipdingle
    FD09CAC1-00F5-42B5-9BC8-A3D1DBCA6161.jpg AF3EC18F-9ACE-4237-9002-BB290C2ABE49.jpg I can measure from ground to top of wheel well for you. I have 285/70/17”s. Your wheel and tire package may differ from mine so you won’t get an exact height from me that is the same as your potential new height. I don’t have a way to measure from the top of the antenna to the ground without a second person but I will see if my wife is up to helping sometime next week when she isn’t working 12 hour shifts. Fort what it’s worth, I don’t park in my garage. My wife parks our fj in there and it is mildly lifted on bilstein 6112’s and 285/70/17 bfg’s like my tundra. It barely makes it, I had to take the hi lift jack off the roof rack to squeeze it in.
    Here’s a few pics for those who asked for some. This was my first drive down some dirt roads the kit handles washboard and babyhead rocks like they’re nothing huge improvement over the trd offroad setup I am very pleased I won’t be doing any expeditions or hard wheeling in this truck for at least 10 years so this is perfect for me if you wanna go 100mph in the desert then maybe fox or king or something would be more suitable to you but that’s not my thing 11DFD263-A4E9-4507-9507-E72B282BD6D2.jpg
    RookieEP, chaztizer, Yaboy and 3 others like this.
  3. Oct 22, 2022 at 7:21 PM
    #183
    Snipdingle
    Now I have some perfectly good trd offroad shocks/struts and coils up for grabs. Axles too if you like to have spares in case you break one wheeling. Hit me up
  4. Oct 22, 2022 at 8:13 PM
    #184
    Taikowaza
    Taikowaza New Member
    SD your truck looks amazing! The lift looks incredible. Thanks so much for posting! I’m reaching out to my local dealerships to determine if it makes more sense to buy my parts from Sparks or BAM, or via the dealer for a less expensive install.
    Snipdingle likes this.
  5. Oct 23, 2022 at 1:27 PM
    #185
    Maharisc
    Maharisc w/Patty
    Karl
    Build date: 12/05/22
    I have the Limited TRD-OR with the TRD Lift running stock rims & tires, still, change coming soon. Since my drive way is sloped, I measured in the garage from fin to ceiling and ceiling to floor.
    Fin-Ceiling= 32.5"
    Ceiling-Floor=112.5
    Truck sits at 80" tall.
    Joodokick, dutch2112 and iiawah808 like this.
  6. Oct 23, 2022 at 9:46 PM
    #186
    TexasTondra
    TexasTondra New Member
    @Maharisc..... perfect information, thank you. And based on the Toyota brochure you have Falken Wildpeak A/T's - 265/60/20, which according to the Falken website the tires are 32.5" tall, 10.2" wide and 58.2 lbs. The Platinum's come with the Yokohama Geolander X-CV 265/60/20 but are a little different (according to the Yokohama website: 32.6" 10.5" 37.5lbs). So based on the measurements I should be able to install the TRD lift kit and have almost an inch to spare. Which leaves me with the dilemma of tire purchase as I can't stand those "all weather Yokohama's". I have my mind set on the Nitto Recon Grapplers, if I stay with the factory size (265/60/20) I can definitely get the lift and it looks like the maximum tire size would be 285/60/20 (33.46"), giving me a smidgen of room to get in. Or.........I could skip the lift, save a bunch of money and get the LT285/65R20 (34.57") and just call it a day. Love the TRD look, but in reality, it's just for looks at this point of my life. Four wheel'n in the Colorado Rockies are no longer part of my life.
    And then there's the suggestion by the Toyota parts department: get the ICON Stage 4 suspension system 2-3.5" and this will allow you to have multiple tire options to accommodate your garage opening limitation. Hmmmmmm.........brain now on overload, need to get the truck first.
    Good info, great forum, I'll be posting once I get the truck and figure it out.
  7. Oct 24, 2022 at 6:44 AM
    #187
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Trying to digest what you said there:
    “The Toyota parts department is advising you to get the Icon Stage 4 setup…and not their own OEM lift?”
    Not saying it’s right or wrong…just surprised.
  8. Oct 24, 2022 at 7:08 AM
    #188
    Maharisc
    Maharisc w/Patty
    Karl
    @TexasTondra I do have the Falken Wildpeaks but they are the A/T3WA, with the A, the tread design is a little different, less aggressive, not sure on the dimensions as TireRack doesn't list all the specs. I looked at ICON stage 4, with it being adjustable may work out well for you and it will be an improvement to the stock ride.
  9. Oct 24, 2022 at 7:33 AM
    #189
    Maharisc
    Maharisc w/Patty
    Karl
  10. Oct 24, 2022 at 8:41 AM
    #190
    Taikowaza
    4895950F-BD00-4834-B2B7-739E94527982.jpg Thanks for linking to this video Maharisc! Best overview of the kit I’ve seen. For 2500 this kit is an unbelievable value.
    I measured the distance I have available between my fin and the top of the garage door. I have 5” clearance available riding on 285/65R20 w/TRD OR suspension, which I think will be plenty for the change to the TRD lift.
    I’m not sure exactly how much increase from TRD OR suspension to the TRD 3” kit but I’m thinking a little less than 3”, hopefully I’m GTG
  11. Oct 24, 2022 at 8:51 AM
    #191
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    $2500? That's a steal if it comes with all they showed in the video.
    Taikowaza and jpod like this.
  12. Oct 24, 2022 at 9:27 AM
    #192
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Local dealerships will nearly always sing their own song about why you should get parts from them. Go with the better price, and as long as they're OEM stamped parts, you're good.
  13. Oct 24, 2022 at 9:54 AM
    #193
    Taikowaza
    It does come with all those parts in my understanding. Here’s the list:
    ryanwgregg likes this.
  14. Oct 24, 2022 at 10:22 AM
    #194
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Then I'd be all over that if I were yall
  15. Oct 24, 2022 at 4:46 PM
    #195
    Taikowaza
    I visited my local dealership today, spoke with one of the service managers. Not the best talk but a start. Good news is he indicated they would install the TRD lift kit if it is Toyota OEM and I bring it.
    Lots of concerning statements after that however like - we can’t warranty lift kits, - it opens us up for liability, - “ in our area we only have the one shop rate of $157.10.” I explained the TRD lift kit comes with a warranty, he said that’s only if factory installed (sigh). Requested they read the fine print.
    Their accessory installation rate is 130, but —that’s only for mudflaps, tonneau covers etc. I wasn’t really impressed with this first meeting, I don’t appreciate it when people’s first reactions are fairly negative. I’ll be given a callback tomorrow after he learns more. Any suggestions or ways I could address this welcomed, but the best suggestion may be to inquire at other dealerships.
  16. Oct 24, 2022 at 5:06 PM
    #196
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd find another dealership that's more interested in, you know, making money and customer service
    Hammerdog and Taikowaza[QUOTED] like this.
  17. Oct 24, 2022 at 5:37 PM
    #197
    bigjuice
    WA State
    2024 Terra TRD Pro
    Really good video…here are some takeaways
    D1148079-6A37-4070-94C6-365B75972D74.jpg 9F6CB4FD-1B4A-4E0D-AD76-0591930AB9B4.jpg 2EA971F9-B23E-4698-B51A-0FFCA3FDF7C5.jpg 16591E37-436A-4520-8765-2F53EB6F2ECD.jpg
  18. Oct 24, 2022 at 5:58 PM
    #198
    NLCB
    NLCB New Member
    It maybe cheaper to use Sparks... but has anyone sourced a Canadian dealer for the TRD lift?
  19. Oct 24, 2022 at 8:06 PM
    #199
    TexasTondra
    They were VERY excited to do either kit and actually got on the phone with Toytec to see when the 3 Icon Stage 4 kits that they have on order would be sent. Gives me options and having a dealership excited and wanting to install has been a positive experience.
    bigjuice[QUOTED] likes this.
  20. Oct 24, 2022 at 8:45 PM
    #200
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    You will need something more robust than this kit- its just a spacer in the rear- worse than stock if running a heavy load
    google bilstein 5100 failure... not something I would run ever again (broke 3 on my 07 tundra doing very very mild off-roading)
  21. Oct 24, 2022 at 9:28 PM
    #201
    TexasTondra
    After some thought I'm struggling to understand how there was only a 3" gain at the fin. Supposedly the 3" lift only yields 2.6" in reality and if they went from Falken Wildpeak A/T 3W (265/60/20) with their published size of 32.52" inflated, to Nitto Recon Grappler (285/65/20) with their published size of 34.57" inflated, that's a gain of 2.05". So, 2.6" lift gain + 2.05 tire gain would put the Fin at 82.05". Yet it's claimed to be 81" at the Fin (based on them saying it was 78" when measured + the 3" gain with lift & tires). The math doesn't add up. Unless the tire gain of 2.05" is partially negated with the weight of the vehicle, maybe an inch? Just my thoughts to ponder / comment on.
  22. Oct 25, 2022 at 1:21 AM
    #202
    Taikowaza
    This is crazy to hear. Any way around this, is the TRD lift kit’s rear suspension truly not an upgrade at all but just a spacer worse than stock? Any way to make a parts swap in the rear to replace the spacer with something else or change the shock or spring length?
    what would you recommend instead, only other option I’ve been eyeing are the ICON stage 2, 3 etc. Nothing too major but would fit my needs. I’ve googled icon shock failure as well and definitely found some stories.[/QUOTE]
  23. Oct 25, 2022 at 4:36 AM
    #203
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Some folks haven't had a good experience with Icon springs. Do a search and check it out
  24. Oct 25, 2022 at 5:11 AM
    #204
    Taikowaza
    I’d really like to stick with the TRD lift. I like all it comes with for the money. Is the rear shock improved in any way over the stock TRD OR version? I can’t believe that it’s worse than stock. Does it reuse the stock spring? I’ve been seeing other rear spring offerings from ARB and Dobinsons. I wonder if using one of these might improve the TRD lift https://rogue-offroad.com/REAR-SPRINGS_c_4221.html
  25. Oct 25, 2022 at 5:52 AM
    #205
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Full spring replacement trumps blocks any day
  26. Oct 25, 2022 at 7:27 AM
    #206
    lsumatt1514
    lsumatt1514 New Member
    2020 Tundra Crewmax Platinum
    Can the TRD lift kit be installed on a Platinum as long as it doesn't have the AVS? Also, can you get a Platinum with the Heads Up Display, but No AVS? Thanks!
  27. Oct 25, 2022 at 10:15 AM
    #207
    kudzuking
    kudzuking New Member
    Two inches in increased tire diameter only raises the vehicle 1”……Ultimately, half of the diameter is from the center of the hub to the ground (which raises the stance) and the other half fills the wheel well (and doesn’t impact height of vehicle).
    Shieldsjared likes this.
  28. Oct 25, 2022 at 10:41 AM
    #208
    DFS
    DFS New Member
    2022 Capstone Tundra
    You can get Capstone with HUD and no AVS fyi
  29. Oct 25, 2022 at 10:51 AM
    #209
    DFS
    DFS New Member
    That's the advanced variable suspension, correct? The air suspension? If so, it is still an option. Happy to take a picture of my controls where the AVS controller would be, nothing there. But I may be misunderstanding AVS, but my truck definitely does not have the "adjustable air suspension".
  30. Oct 25, 2022 at 10:57 AM
    #210
    DFS
    DFS New Member
    I believe everything BUT AVS is standard on the capstone. Mine has everything but the AVS, including HUD with no options listed. Toyota makes it fairly difficult to keep track of...
