CONSTANT Clicking Noise Coming from Windshield?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 1794Mike, Dec 13, 2021.
  1. Dec 13, 2021 at 8:09 AM
    1794Mike
    1794Mike [OP] New Member
    Eastern Pennsylvania
    2021 Army Green Tundra 1794
    Hi all,
    I meant to ask this question last year, but then as the weather warmed here in PA it seemed to be less of an issue. Now that temps are back in the 30s during the day, I’m reminding of the horror of a constant clicking noise coming from what I think is the sensor compartment behind the rear view mirror. Now, I’m not a car/truck expert like many of you, and this is one of those noises where depending on where you look, you can convince yourself that that is the spot where it’s coming from. But I think I’ve narrowed it down to the sensor area. I’ve taken off the plastic cap on the wiring and sensors to see if anything is loose and all seems fine. I’ve held the plastic cap while driving to see if it’s rubbing against the glass and the clicking continues. This is one of those things where it’s driving me insane and I know if I bring it to dealer they’ll tell me they don’t hear it. In addition, from the first day I bought my truck(14 months ago, 34k miles) it has made clicking noises turning, going over bumps, etc. Two trips to two dealerships and they both told me all looks good and it might be the strut bars. Is this community buying that, especially with the threads about bent axles and power steering rack recalls? I thank any and all help in advance.
    gabex35 likes this.
  2. Dec 13, 2021 at 9:56 AM
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    next time it making the noise adjust your rearview mirror. turn it a little and see if it goes away
  3. Dec 13, 2021 at 11:51 AM
    YorkT
    YorkT New Member
    I recall seeing a post similar to this a couple of years ago. You may have to do some searching.
  4. Dec 14, 2021 at 12:10 PM
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    I recently noticed this too on my 2020. I dont think it was always there but i drive so infrequently that I haven’t looked into what it might be. Subbed
  5. Dec 14, 2021 at 12:32 PM
    rockon34x
    rockon34x New Member
    I had the same issue, but magically has gone away after I hit some dirt and shook everything up. I think this might be the thread you are looking for https://www.tundras.com/threads/fixed-ticking-sound-in-dash-windshield-area.45650/. There is a link in there to another forum that actually goes through how to do the fix, but back in 2008 there was a TSB on this so it may be possible for a dealer to get it done for you since you should be under warranty.
  6. Dec 14, 2021 at 1:09 PM
    frichco228
    frichco228 Valued Member
    Frank
    Virginia
    2016 Crewmax 4WD, TRD Offroad
    I had a similar noise at times. Got some chips and a bad crack in the windshield and it got worse. Had the windshield replaced, no more noise.
    1794Mike[OP] likes this.
  7. Dec 14, 2021 at 1:11 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Do you have a TRD skid plate?
  8. Dec 14, 2021 at 1:23 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Is the plastic cowl surrounding the wiper arms flapping at all? I've had that cause these annoying sounds before...
  9. Dec 14, 2021 at 2:27 PM
    RickPlatinum2020
    RickPlatinum2020 New Member
    Rick
    Eastern PA
    2020 Barcelona Red Platinum 4x4
    Front and rear TRD sway bars, 18" TRD OR wheels. ESP underseat storage
    No noise on 2020 with 18k in Eastern PA. Good luck!
  10. Dec 15, 2021 at 4:17 AM
    1794Mike
    I do.
  11. Dec 15, 2021 at 4:18 AM
    1794Mike
    Tried that trick many times but no luck.
  12. Dec 15, 2021 at 7:03 AM
    19TurdPro
    2019 Tundra TRD Pro
    Tighten the two rear bolts on it and see if the popping goes away. If they are loose, it will bind against the cross member and pop when you turn.
  13. Dec 15, 2021 at 7:13 AM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I thought I saw a thread or post somewhere that a guy found two plastic tabs at the top of the windshield where it joins with the cab / header? I also saw another post where people were putting foam backing rod on the bottom between the windshield and the dash.
    I feel for you as I am super sensitive to noises and they can echo terrible and sound like they are coming from somewhere else.
  14. Dec 15, 2021 at 8:15 AM
    YorkT
    YorkT New Member
    Here is one thread.
    https://www.tundras.com/threads/dash-windshield-ticking-noise.84218/#post-2125545
  15. Dec 19, 2021 at 3:21 PM
    Ship_Wreck
    Ship_Wreck New Member
    Dave
    Ship_Wreck said:
    [​IMG] [​IMG]
    So here’s what I found after driving around a little bit more. The upper corner in the passenger side headliner had some factory glue that was squeaking on the windshield I was able to get a small plastic tool up there and pull down the headliner and pull it off and my squeaking issue is no more.
    gabex35 and boostedtrdpro like this.
  16. Feb 28, 2022 at 5:17 PM
    LJOHNS
    LJOHNS New Member
    Reviving this thread. I have a ticking noise. Mine sounds like it is coming from the lower side of the windshield where it meets the dash. I had to add some cork in my old 2007 under the dash to fix that one. Drives me crazy!
  17. Mar 1, 2022 at 7:53 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    2014 Crewmax 1794 4WD
    After pulling apart the dash 4 times, I am still having the same issue. Mine sounds like a tapping/clacking noise of plastic or metal. Its defintely not the dash/windshield. Driving me nuts!!!
  18. Oct 18, 2022 at 9:00 AM
    allen_rubin
    allen_rubin New Member
    Allen
    2016 SR5 TRD 4x4 Crew Max
    King 2.5's with Camburg Uniball UCA Deaver u748 w/ TC Shackle Fuel Hype 17X8.5 10MM 37X12.5-17 BFG KO2 "Stock Gears" Alpha REX Pro Headlight and Tail Lights Custom Carven Side Exit exhaust ADD Front & Rear Bumpers along with Side Steps Westin Topper / Westin Power side steps
    mom having the same issue in my 2016…. Taken everything apart. Zip tied the windshield cowl, next I guess mess with windshield tabs
  19. Oct 18, 2022 at 9:07 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    Dude! I solved mine. Never would have guessed but it was the drivers side hood hinge. Still dont know why but I packed some rubber garage door material in between the hinge so its tight when closed. Silent for 4 months.
    bulldog93 likes this.
  20. Oct 18, 2022 at 9:17 AM
    allen_rubin
    Allen
    Ima have to check that out! It’s driving me nuts! Have had the truck for 2 months lol first noise I got fixed was the TRD intake tapping inside the fender, now this one drivin me nuts and it’s only at super low speeds I can hear it
  21. Oct 18, 2022 at 9:46 AM
    Boisefly
    Boisefly New Member
    Boise, ID
    yeah, I was going insane too. maybe yours if different but just throwing it out there. Let me know how yours works out. Mine was also only noticeable under 20mph but only happened when hitting bumps.
  22. Oct 18, 2022 at 10:19 AM
    allen_rubin
    Allen
    Yea mines 5 mph, even 1mph barely rolling. Tap tap tap lol
  23. Oct 18, 2022 at 12:47 PM
    IowaGuy
    IowaGuy New Member
    In Process
    The sounds inside the cab can resonate and travel so much that even the slightest little noise in one area can sound like it is coming from another area. I have mysophonia where certain small sounds drive me nuts. I have spent a lot of time trying go rid my ride of all its noises.
    the SR5 badge on my center console lid was loose and made a noise
    the matt in the center dash tray was making a noise from vibrating
    my rear seatbelts plastic where they go into the pillar was making a noise
    the front seatbelts on the pillars were making noise
    sunglasses in the center upper console were rattling
    the plastic box cover under the passenger seat
    the glove box tray insert
    rear passenger windows not rolled up tight
    plastic water bottle in the cupholder
    wiring harness next to the firewall on passenger side
    center console lid
  24. Oct 22, 2022 at 9:43 AM
    allen_rubin
    Allen
    Ok removed the cowl and sound was still present, so I went to the passenger side firewall where the ECU is, starting wiggling wires and the wires going into the little fuse box right there replicates the sound, guess the sound travels through the wires into the cab. Zip tied them up and sound is finally gone
