2005 Double Cab 16x9 -25mm W/ 285/70R17?
Discussion in 'Wheels & Tires' started by bnag0, Oct 21, 2022.
  1. Oct 21, 2022 at 9:34 PM
    bnag0
    bnag0 [OP] New Member
    So from all the research I have done it seems like this is a possibility with just a 2" lift in the front? Will have to remove mud flaps and do some trimming here and there but should be good to go. Was hoping someone had some photos and experience to share
    Wheels I would like to go with....
    https://sswoffroad.com/collections/dakar-wheels/products/dakar-bronze-17x9-0-25
    Tires
    https://www.discounttire.com/buy-tires/falken-wildpeak-a-t3w/p/26808
    Similarish Setups:
    https://www.customwheeloffset.com/w...-tundra-fuel-vector-tuff-country-leveling-kit
    https://www.customwheeloffset.com/w...tundra-moto-metal-mo970-bilstein-leveling-kit
    Sexy Videos
    https://youtu.be/RF7jJVlVP7Q
    https://youtu.be/l4SVCNm9sYs
  2. Oct 22, 2022 at 10:53 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    That negative 25mm offset is going to make it a bit harder to fit unless our interpretation of “a little trimming here and there” differ.
    That tire will easily fit if you did a +25mm offset…
