Third Brake Light Assembly
Discussion in 'Lighting' started by 2point5seconds, Oct 21, 2022.
  1. Oct 21, 2022 at 12:25 PM
    2point5seconds
    2point5seconds [OP] Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    2019 Tundra 5.7l 4WD SR5 TRD DC
    The screws for the cover on my Third Brake light assembly doesn't seem to be tightening up like they used to. I'm thinking that the holes may be stripped.
    I've had to open the cover 100 times to replace the VLEDs bulbs that I have in there. They keep going out and VLEDs keeps saying they know of the issue.
    Is there any way to fix this without having to change out the whole assembly? Which I do not want to do. A couple of the screws are barely in there.
  2. Oct 21, 2022 at 12:46 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    How many screws are there? I thought they only came with 2.
  3. Oct 21, 2022 at 12:53 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Find some screws the same length that are a tad thicker and paint them black.
    For example like from a 6 to an 8..
  4. Oct 21, 2022 at 12:56 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Blue loctite???
  5. Oct 21, 2022 at 12:56 PM
    2point5seconds
    Sensei
    Nor Cal
    There are four all together
  6. Oct 21, 2022 at 12:57 PM
    2point5seconds
    Sensei
    Nor Cal
    Yeah I may try that. It's not grabbing towards the end so wasn't sure if that would help. I'm going to wait until I get the new bulbs then try it. Thanks!
  7. Oct 21, 2022 at 12:59 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Or try the old guitar repair stripped screw method of inserting a toothpick in the hole..:p
    I've done that on many a household project over the years.
    The toothpick gives the screw something to bite into..
    Does Loctite work on plastic?
  8. Oct 21, 2022 at 12:59 PM
    Fill the holes with a hot glue gun, when it dries screw in screws.
  9. Oct 21, 2022 at 1:23 PM
    2point5seconds
    Sensei
    Nor Cal
    I've done the toothpick thing with my door frame and the screws.
    1lowlife[QUOTED] likes this.
  10. Oct 21, 2022 at 1:24 PM
    2point5seconds
    Sensei
    Nor Cal
    Will I be able to pull the screws out later if a bulb goes out?
  11. Oct 21, 2022 at 3:36 PM
    Yes
