Am I the only one who can't properly seed this piece?
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundyFromDownUndy, Oct 21, 2022.
  1. Oct 21, 2022 at 8:50 AM
    TundyFromDownUndy
    TundyFromDownUndy [OP] New Member
    2020 Platinum Tundra
    No matter what I do, this part never sits flush. It's so annoying.
  2. Oct 21, 2022 at 8:57 AM
    koditten
    Kirk
    Midland of the Mitten
    Mine sits the same. Been that way for 7 years. I guess it wasn't worth worrying about.
    IA_Tundra and Tundra'25 like this.
  3. Oct 21, 2022 at 8:57 AM
    Taco-Spike
    Two Trucks
    There are white clips that may need to be removed from the removable kick panel, inserted to the clasps where it mates to, then push the panel back on. Might take a few trials and errors to get it flush or some variation of where the clips sit first.
    LS3, Spyker, Tripleconpanna and 6 others like this.
  4. Oct 21, 2022 at 8:59 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    ^This
    These are an exercise in patience for certain, but it's possible to get them back in place.
    Tripleconpanna and Taco-Spike like this.
  5. Oct 21, 2022 at 9:03 AM
    TundyFromDownUndy
    A stroke of genius! Thank you will try this. The OCD in me can't get over it sitting improperly.
  6. Oct 21, 2022 at 9:06 AM
    Taco-Spike
    Two Trucks
    Good Luck!
    It's easier said than done. Just work with it
    Wynnded likes this.
  7. Oct 21, 2022 at 9:37 AM
    pursuit2550
    pursuit2550 New Member
    Are you sure you don’t mean to remove them from the body mounts and reinstall them in the panel? That’s what always happens to me. The white clips stay on the body mounts. I remove them and put them back in the panel and just reinstall. Pretty easy.
  8. Oct 21, 2022 at 9:44 AM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Yup, from my experience the clip gets stuck on the frames fender side and will need to be removed and seated into the black panel in order to get that panel back in flush.
    WILLINH and Taco-Spike[QUOTED] like this.
  9. Oct 21, 2022 at 9:49 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    That’s how mine is. Now I know how to get it back in place. Thanks guy’s !
  10. Oct 21, 2022 at 9:55 AM
    There are 2 clips on those. When the panel is removed, 99% of the time the clips pop out of the panel and stay in the mounting hole as seen in pic 2. Just pop it out and slide it back into the panel and you will be good to go.
  11. Oct 21, 2022 at 10:02 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    If you're pulling kick plates or door panels, this is a must..
    I've yet to pull either off and not have a clip stuck in the hole.
    Amazon.com: XBRN Auto Trim Removal Tool Kit, Fastener Car Panel Door Window Tool, Auto Clip Fastener Remover Pry Tool, Clip Puller Rivet Removal Tool : Automotive
    Some spare clips are nice to have as well.
    Amazon.com: 15 Ct. Replacement Clips For Door Trim Panel 90467-A0005 (Lexus /Toyota) : Automotive
    Although the kickplate has a weird angled one on it, I don't know the part number..
  12. Oct 21, 2022 at 10:12 AM
    Made me go look at mine
  13. Oct 21, 2022 at 10:25 AM
    TTund16
    TTund16 New Member
    I thought that was the side effect of anytime fog light ... you want anytime fog light, you get a semi-flush panel. :monocle:
    Good reminder. I had previously read that I have to remove something and stick it somewhere else ... but it's been on my to-do list for the past few years. :D
  14. Oct 21, 2022 at 11:21 AM
    RedGreen
    RedGreen New Member
    2018 SR5 4x4 DC LB
    Yup. Some careful application of electrical tape can help keep these in place while you re seat the clips. This drove me crazy
    Taco-Spike[QUOTED] likes this.
  15. Oct 21, 2022 at 11:33 AM
    TundyFromDownUndy
    Baja Designs likes this.
  16. Oct 21, 2022 at 11:36 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Every. Single. Time. Pull clips from body, insert in panel, reinstall panel as stated above. Cumbersome but will sit straight again!
  17. Oct 21, 2022 at 4:31 PM
    TundyFromDownUndy
    Sounds easy enough to give me some peace of mind. Yall are geniuses
  18. Oct 23, 2022 at 4:13 PM
    737fixer
    737fixer New Member
    First, I need to apologize since I cracked up at your post cause mine has looked identical since I installed the CarLink Remote Start. I've given up trying to fix it. Second, thanks for asking the question so I can give it another go.
    AGSport and bgdv1 like this.
  19. Oct 23, 2022 at 4:41 PM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    Same hear, just detailed the truck yesterday and tried putting the dam panel in place and gave up. Been that way for 3 years now after adding remote start. Try every now and again and get frustrated and say F...it
    AGSport likes this.
  20. Oct 23, 2022 at 5:02 PM
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    Have to admit, mine looks like the OPs ever since I added the bedlight kit.
    AGSport likes this.
  21. Oct 24, 2022 at 6:13 AM
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
  22. Oct 24, 2022 at 6:32 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I properly seeded the same piece twice. That's how I ended up with two kids.
    LS3, NDTundra18, JMB and 7 others like this.
  23. Oct 24, 2022 at 6:34 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    The upper clip needs to be removed from the truck and attached to the panel. The lower one works best in my experience if it stays on the truck and you attach the panel to it while reattaching the panel.
    I’ve had mine off so many times I can get it back on fully in my sleep.
    bulldog93 likes this.
  24. Oct 24, 2022 at 6:37 AM
    RainMan_PNW
    Casey
    Clark County, WA
    Me too.
    Then we decided to clip the tubes to my seed maker
    GODZILLA and hagrid[QUOTED] like this.
  25. Oct 24, 2022 at 6:41 AM
    You in fact are the….
  26. Oct 24, 2022 at 6:45 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I, also, in addition to you had my cobra de-fanged. My urologist said I would notice no difference.
    I, Spraynard, can tell you that I notice a difference. If I had a wayback machine my piece would be getting her fangs pulled.
  27. Nov 25, 2022 at 11:43 AM
    Rustedfenders
    Rustedfenders If it ain't broke, don't fix it.
    Wally
    Rosedale Md.
    2016 Blazing Blue Pearl TRD Tundra Crew Max
    Aries 4" Bull Bar, 3-2 Level Lift Havoc Stainless hoop steps.
    I had the same problem. I pushed the panel in then i replaced the plastic nut on the floor with a real nut and tightned it, so far its still in place.
  28. Nov 25, 2022 at 1:10 PM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    Mine looks the same, right after I installed the AMP Powersteps wiring..I just left it..
  29. Nov 25, 2022 at 1:44 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Mine sits flush and smooth. It does not hang out like that.
