2012 Tundra died after long ride
Discussion in '2nd Gen Tundras (2007-2013)' started by P-Town Tundra, Oct 17, 2022.
  1. Oct 17, 2022 at 8:36 AM
    P-Town Tundra
    P-Town Tundra [OP] New Member
    2012 Tundra
    New to the forum, and hoping y'all might help diagnose. Had taken a 3 hour trip (mainly highway) in my 2012 Tundra and at the end of the trip, all of a sudden the emergency brake light and traction control light came on while driving and the radio died. Truck was still running fine. Drove it for about 1/2 mile to get to a safe area to pull off and turned truck off. When trying to restart, getting the dreaded click, click, click sound. Truck has plenty of gas and only has 100K miles. Never had any other issues. Tried unhooking the battery cable and trying to reset - no luck. Anyone have any ideas?
  2. Oct 17, 2022 at 8:56 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Bad batteries / alternators cause all kinds weird issues in modern vehicles.
    baraynavab likes this.
  3. Oct 17, 2022 at 9:00 AM
    P-Town Tundra
    2012 Tundra
    Yeah, doubt it is battery as headlights come on at full power and interior lights all come on as well.
  4. Oct 17, 2022 at 9:29 AM
    Retired...finally
    Not my usual way to test batteries and charging systems but to each his own.
    MT Madman likes this.
  5. Oct 17, 2022 at 9:33 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Click click click usually means there’s not enough charge to handle the starter load. You can have enough voltage to turn on the headlights (especially if they are LED) and still be short of the power necessary to crank the engine. A quick trip to your local Pep Boys, Auto Zone, etc for a free battery load test will confirm or deny the issue. That’s the easiest place to start your troubleshooting IMO.
  6. Oct 17, 2022 at 9:34 AM
    Could be a bad battery or cable as others have mentioned. These trucks behave this way when batteries go bad from age and start to get voltage drop. They also behave this way when the battery cables become corroded producing poor current and poor grounding. Worth listening to the advice you sought here.
  7. Oct 17, 2022 at 9:42 AM
    e30cabrio
    Another solution is don't turn the key. No click click click
  8. Oct 17, 2022 at 9:50 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    it doesn't matter if lights work, starter needs way more juice than headlights. The only way it's not battery would be if you just got new one. If it's older one than most likely is the culprit. Try to jump start it
  9. Oct 17, 2022 at 11:17 PM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
